Happy2Play 9814 Posted August 25, 2024 Posted August 25, 2024 That would suggest that is the quality of your media. What is the media info for that item?
Zaydk 0 Posted August 25, 2024 Author Posted August 25, 2024 Hi, Where would I find the media info? This is the only show I have problems with in terms of quality, for example prior to this I watched Naruto at 1080p.
Luke 42288 Posted August 25, 2024 Posted August 25, 2024 Hi, is this your Emby Server, or someone else's?
Happy2Play 9814 Posted August 25, 2024 Posted August 25, 2024 Potentially whoever the server admin is will need to look at the media info for that particular item. Don't know if the TV apps show media info at the bottom of the item page.
Zaydk 0 Posted August 25, 2024 Author Posted August 25, 2024 What device can I use to find the media info?
Neminem 1630 Posted August 25, 2024 Posted August 25, 2024 10 hours ago, Happy2Play said: Potentially whoever the server admin is will need to look at the media info for that particular item.
RanmaCanada 503 Posted August 25, 2024 Posted August 25, 2024 1) Emby is not a site, it is a personal media server. If you are expecting free pirated content, then you were lied to by whomever owns the server. 2) this is a dvd remux. It's in 480i Mpeg2 format. 3) if this really is your family's media server as you claim, take it up with whatever family member set it up. They are responsible for the media, not Emby. If you really want to watch Naruto in 1080, then get a crunchyroll subscription, as they will gladly show you horribly upscaled Naruto. 1
