user24 369 Posted September 5, 2024 Posted September 5, 2024 (edited) 55 minutes ago, JBloom91 said: What do you guys mean by pming? Send a Private Message (sometimes referred to as a Direct Message) to the relevant person with the file attached. You can do this from the Envelope icon at top RHS of forum pages. Edited September 5, 2024 by user24
JBloom91 31 Posted September 5, 2024 Author Posted September 5, 2024 Oh I'm dumb. I guess I just haven't heard that term in a while. So who would I PM in this case and what would I need to entail? I'm still a bit lost on that part.
user24 369 Posted September 5, 2024 Posted September 5, 2024 From reading back through all the previous posts, I think you are being asked to send the problem WAV files direct to @Happy2Play for testing. Any other files you have generated in the relevant Album folders may also be helpful (I'm not 100% sure on this). These would be the KENMORE CLASSIC and ux.exe Album files being discussed. Don't just send them as downloaded direct from Bandcamp. Send the ones from your library folder that you have already run through a tagging program (e.g. Picard, Mp3tag) or any other software conversions. If the problems can then be replicated using your specific files, perhaps they can be fixed? If not, the problems may be specific to your computer hardware/software setup? 1 1
