Spymaster 5 Posted December 27, 2025 Author Posted December 27, 2025 1 hour ago, Luke said: Did you try holding the buttons down? Yes. Holding the button down doesn't make any difference, it still just advances once and then continues at normal speed.
Spymaster 5 Posted December 28, 2025 Author Posted December 28, 2025 16 hours ago, Luke said: Did you try holding the buttons down? Yes. No difference. Testing some more, navigation is actually worse than it was before. Forgetting the FF button, when I navigate right using the direction button I now get a spinning blue circle for a couple of seconds and it may, or may not, speed forwards. Sometimes additional clicks speed things up, sometimes nothing happens at all. It's easily the worst aspect of an otherwise brilliant application.
Luke 42233 Posted December 28, 2025 Posted December 28, 2025 17 hours ago, Spymaster said: Yes. Holding the button down doesn't make any difference, it still just advances once and then continues at normal speed. Did you try holding the left or right button down?
Spymaster 5 Posted December 28, 2025 Author Posted December 28, 2025 5 hours ago, Luke said: Did you try holding the left or right button down? Yes. Holding down the left/right button doesn't do anything. I'm sure they worked better before the update. Only short presses appear to trigger quick navigation, with additional short presses increasing or decreasing the speed (after the spinning blue circle has disappeared).
SamES 1084 Posted December 28, 2025 Posted December 28, 2025 3 hours ago, Spymaster said: Only short presses appear to trigger quick navigation, with additional short presses increasing or decreasing the speed (after the spinning blue circle has disappeared). This sounds like the expected behaviour. Briefly holding down left/right triggers a slow seek, then each press of the left/right arrow prgresses to 2x ,3x then 4x speed. It changed to this maybe one or two releases ago. To be honest, I preferred the older behaviour where it was possible to manually move the position slider then 'jump' to the selected location as even 4x can be very slow if you want to jump a long way ahead.
Spymaster 5 Posted December 28, 2025 Author Posted December 28, 2025 11 minutes ago, SamES said: This sounds like the expected behaviour. Briefly holding down left/right triggers a slow seek, then each press of the left/right arrow prgresses to 2x ,3x then 4x speed. It changed to this maybe one or two releases ago. To be honest, I preferred the older behaviour where it was possible to manually move the position slider then 'jump' to the selected location as even 4x can be very slow if you want to jump a long way ahead. That would be fine if it wasn't for the spinning blue wheel of doom that accompanied it... 1
SamES 1084 Posted December 28, 2025 Posted December 28, 2025 7 minutes ago, Spymaster said: That would be fine if it wasn't for the spinning blue wheel of doom that accompanied it... I don't know why you would be a seeing the spinning blue wheel. I don't see that.
Luke 42233 Posted December 28, 2025 Posted December 28, 2025 One thing that is relatively new is that when the player signals that it's waiting for data, then we should the loading spinner. That could be what is happening.
Spymaster 5 Posted December 28, 2025 Author Posted December 28, 2025 26 minutes ago, Luke said: One thing that is relatively new is that when the player signals that it's waiting for data, then we should the loading spinner. That could be what is happening. It could well be, yes. I get the benefit of that, but not when I/we just want to navigate content...
