Redshirt 1487 Posted November 17, 2014 Posted November 17, 2014 Well the request for a list of watched episodes from Trakt.tv is returning 0 items. So there's nothing to actually match.
mbc0 68 Posted November 17, 2014 Author Posted November 17, 2014 Even though trakt.tv is showing as watched? 2014-11-17 13:23:26.7119 Info - Trakt: Failed to match Episode: 3x4 'Fundraising' Series: null SeriesName: Bad Education
saitoh183 137 Posted November 17, 2014 Posted November 17, 2014 Well the request for a list of watched episodes from Trakt.tv is returning 0 items. So there's nothing to actually match. Ok, is this the plugin failing retrieve the info from the API? because like mbc0, my shows are scrobble or marked as seen.
Redshirt 1487 Posted November 17, 2014 Posted November 17, 2014 I misread mbc0's log. The returned shows was far greater than 0. I was looking at the output for the wrong user. I'm not sure what's going on yet. I've been testing it here and I can't get it to fail. There isn't any show being skipped that shouldn't be. 1
saitoh183 137 Posted November 17, 2014 Posted November 17, 2014 (edited) I misread mbc0's log. The returned shows was far greater than 0. I was looking at the output for the wrong user. I'm not sure what's going on yet. I've been testing it here and I can't get it to fail. There isn't any show being skipped that shouldn't be. What about my log? What does the Series= null mean? Edited November 17, 2014 by saitoh183
mbc0 68 Posted November 17, 2014 Author Posted November 17, 2014 Thanks for your time Redshirt I really appreciate it 1
saitoh183 137 Posted November 17, 2014 Posted November 17, 2014 Thanks for your time Redshirt I really appreciate it Yeah, thank you. I hope with our help you can figure it out 1
Redshirt 1487 Posted November 17, 2014 Posted November 17, 2014 Another new build up with tweaked logging. Please rinse and repeat.
saitoh183 137 Posted November 17, 2014 Posted November 17, 2014 https://www.dropbox.com/s/wlf8q4ef7dmczq7/server-63551817909.txt?dl=0
Redshirt 1487 Posted November 17, 2014 Posted November 17, 2014 I'll definitely need to remove that logging afterwords. The log files are huge. saitoh183. I need some context to that log. Can you give me some examples of the episodes that are scrobbled on trakt.tv that aren't being marked watched locally.
saitoh183 137 Posted November 17, 2014 Posted November 17, 2014 I'll definitely need to remove that logging afterwords. The log files are huge. saitoh183. I need some context to that log. Can you give me some examples of the episodes that are scrobbled on trakt.tv that aren't being marked watched locally. Doctor Who (2005) The Flash Ridiculousness
Redshirt 1487 Posted November 17, 2014 Posted November 17, 2014 Saitoh183 Please copy this version of trakt into your server plugins folder and then restart the server. It's going to go one step further and log the data that's received from trakt for some of the shows that aren't matching. The logs are getting large enough that I don't want to publish it for the general public to use.
mbc0 68 Posted November 18, 2014 Author Posted November 18, 2014 Your episodes are failing to match right at the onset. Based on the logging It looks like the local show meta is OK. I'm going to have to create a version that logs all the trakt.tv meta. Either that or just pick one show and see if I can log it's meta. Have you watched the majority of 'Dexter'? There's a bunch of those that didn't match anything. Hi, I have watched every episode of Dexter :-)
mbc0 68 Posted November 18, 2014 Author Posted November 18, 2014 If it has to be I will start again from scratch by uninstalling MB Server and removing all trace and start again.. I really need this working so am prepared to do whatever it takes just say the word!!
saitoh183 137 Posted November 18, 2014 Posted November 18, 2014 https://www.dropbox.com/s/wlf8q4ef7dmczq7/server-63551817909.txt?dl=0
mbc0 68 Posted November 18, 2014 Author Posted November 18, 2014 Hi Mate, I have disabled the other users from the plugin to make this easier to read and until it fixed, hopefully it will help, this is the log from the version on post 37, Cheers https://dl.dropboxusercontent.com/u/38473789/server-63551844244.txt
saitoh183 137 Posted November 18, 2014 Posted November 18, 2014 If it has to be I will start again from scratch by uninstalling MB Server and removing all trace and start again.. I really need this working so am prepared to do whatever it takes just say the word!! I did that...
Redshirt 1487 Posted November 18, 2014 Posted November 18, 2014 https://www.dropbox.com/s/wlf8q4ef7dmczq7/server-63551817909.txt?dl=0 I think that's the wrong link. It's the log you posted earlier.
Redshirt 1487 Posted November 18, 2014 Posted November 18, 2014 Hi Mate, I have disabled the other users from the plugin to make this easier to read and until it fixed, hopefully it will help, this is the log from the version on post 37, Cheers https://dl.dropboxusercontent.com/u/38473789/server-63551844244.txt Your episodes are failing to match right at the onset. Based on the logging It looks like the local show meta is OK. I'm going to have to create a version that logs all the trakt.tv meta. Either that or just pick one show and see if I can log it's meta. Have you watched the majority of 'Dexter'? There's a bunch of those that didn't match anything.
saitoh183 137 Posted November 18, 2014 Posted November 18, 2014 I think that's the wrong link. It's the log you posted earlier. https://www.dropbox.com/s/dsu7ch3o334kr64/server-63551829385.txt?dl=0
saitoh183 137 Posted November 19, 2014 Posted November 19, 2014 The more data you give back to me the more baffled I am that this isn't working for you. Sticking with Dexter, the log message means that neither the local IMDB Id or TheTVDB Id at the Series level of Dexter's metadata could be matched to the values from Trakt.tv. Trakt provides this for Dexter. { "title":"Dexter", "year":2006, "url":"http://trakt.tv/show/dexter", "imdb_id":"tt0773262", "tvdb_id":"79349", "tvrage_id":"7926", "images": { "poster":"http://slurm.trakt.us/images/posters/97.27.jpg", "fanart":"http://slurm.trakt.us/images/fanart/97.27.jpg", "banner":"http://slurm.trakt.us/images/banners/97.27.jpg" }, "genres":["Drama","Thriller","Suspense","Crime","Mystery"], "seasons":[ {"season":8,"episodes":[1,2,3,4,5,6,7,8,9,10,11,12]}, {"season":7,"episodes":[1,2,3,4,5,6,7,8,9,10,11,12]}, {"season":6,"episodes":[1,2,3,4,5,6,7,8,9,10,11,12]}, {"season":5,"episodes":[1,2,3,4,5,6,7,8,9,10,11,12]}, {"season":4,"episodes":[1,2,3,4,5,6,7,8,9,10,11,12]}, {"season":3,"episodes":[1,2,3,4,5,6,7,8,9,10,11,12]}, {"season":2,"episodes":[1,2,3,4,5,6,7,8,9,10,11,12]}, {"season":1,"episodes":[1,2,3,4,5,6,7,8,9,10,11,12]} ] } If you go into the MB metadata manager and look at the Id's for this show, are they filled out and do they match the values from trakt.tv?
mbc0 68 Posted November 19, 2014 Author Posted November 19, 2014 here is my page from MBS, the only thing that stands out is the date added?
mbc0 68 Posted November 19, 2014 Author Posted November 19, 2014 (edited) I have other providers enabled but MBS is only showing TVDB? yours is showing a lot more? How do you get IMDB? it is not even an option in the settings? Edited November 18, 2014 by mbc0
Redshirt 1487 Posted November 19, 2014 Posted November 19, 2014 Damn The discrepancy in the available Id's stuck out to me as well. My guess would be that another program generated yours, XBMC, metabrowser, MCM? I'm running out of ideas, but I'm wondering if there's whitespace in the values. Let me just put a build together that filters that out.
saitoh183 137 Posted November 19, 2014 Posted November 19, 2014 The last few days exposed a bug that has now been corrected. I want to believe that any issues now lie in either configuration or available data. That being said. Let's pick one show in your library. one show that is watched on trakt.tv but not locally in MB. Confirm in MB that that show has either an imdb id or tvdb id at the series level. Also confirm that that show is actually in your collection in trakt.tv. The all and plays tabs aren't limited to what's in your collection. I want to eliminate the possibility that we have a show that is marked watched on trakt.tv but somehow isn't in your collection. your right... Dexter says i have 13 eps not in collection...here is what i find weird. Arrow says scrobbled but its not in my collection...shouldnt shows that you watch automatically be added to your collection? Same goes for Doctor who. So my only option is to fix them on trakt im guessing? 1
