Spymaster 5 Posted August 19, 2024 Posted August 19, 2024 When I select to play episodes continuously, via either my LG TV or Android phone, there's a slight "hiccup" between episodes when Emby returns to the menu screen for a split second before playing the next episode. Would it be possible to smooth this over, so that one episode ends, there's a blank screen, and then the next episode begins? Thank you!
ebr 16337 Posted August 19, 2024 Posted August 19, 2024 Hi. That's odd. Do you see that with any other of the apps?
Spymaster 5 Posted August 19, 2024 Author Posted August 19, 2024 12 minutes ago, ebr said: Hi. That's odd. Do you see that with any other of the apps? I haven't tested it with other apps, but it definitely happens on both the LG TV app and the app on my Samsung S21 Android smartphone - running the latest version of Emby off of my Synology NAS.
Luke 42245 Posted August 19, 2024 Posted August 19, 2024 HI, have you tried again with Emby for LG 1.0.44?
Spymaster 5 Posted August 20, 2024 Author Posted August 20, 2024 Hi - I've just tested it on today's updated software but it's just the same unfortunately.
Spymaster 5 Posted August 20, 2024 Author Posted August 20, 2024 I mean the page from which I originally selected the episode. The screen that would appear next if I'd chosen not to auto-play the next episode. It's hard to see exactly what's on it, because it appears and disappears to quickly, but it appears to be that.
Luke 42245 Posted August 20, 2024 Posted August 20, 2024 OK we'll take a look at it. Thanks for reporting.
arrbee99 1836 Posted August 20, 2024 Posted August 20, 2024 This wouldn't have anything to do with playing music videos where it puts up stills of the musicians between videos ? Music Video Transition mod.mp4
Spymaster 5 Posted August 20, 2024 Author Posted August 20, 2024 4 hours ago, Luke said: OK we'll take a look at it. Thanks for reporting. Thank you!
Spymaster 5 Posted August 20, 2024 Author Posted August 20, 2024 3 hours ago, arrbee99 said: This wouldn't have anything to do with playing music videos where it puts up stills of the musicians between videos ? Music Video Transition mod.mp4 13.26 MB · 0 downloads No, it's not that. It's happening between TV episodes. 1
Spymaster 5 Posted August 29, 2024 Author Posted August 29, 2024 Just to re-clarify what I meant above by "menu screen", I've checked this again and it's basically displaying the "background" image for a brief second, with no text or anything over the top of it.
ebr 16337 Posted August 29, 2024 Posted August 29, 2024 Okay, so it isn't going back - this is the standard behavior of showing an item's background while loading.
Spymaster 5 Posted August 30, 2024 Author Posted August 30, 2024 On 8/29/2024 at 4:03 PM, ebr said: Okay, so it isn't going back - this is the standard behavior of showing an item's background while loading. Ah, okay, that makes sense - though a blank screen would be less "clunky" when transitioning between episodes...
