keduncan3 4 Posted August 17, 2024 Posted August 17, 2024 Basically what the title states. I didn't opt to store thumbnails in the folders with the media. My CPU got overtaxed so I turned off thumbnails/intro skipping. Where can I find the saved data to delete it?
Solution Happy2Play 9811 Posted August 17, 2024 Solution Posted August 17, 2024 They are saved in /metadata/library/xx/xxxxxxxxxxxxxxxxxxxxxx folders. So you will have to do a generic search for fp files for intro markers and not sure what you are calling thumbnails if interval images then you will have to search for bif files.
keduncan3 4 Posted August 17, 2024 Author Posted August 17, 2024 Thumbnails are in reference to the video preview thumbnails for seeking. I have a follow-up question about collections primary art. All of my videos/TV shows have successfully fetched images, however my collections are not fetching covers for the collection as a whole. For instance, Olympus and London have fallen both have the correct metadata and images for each. They are grouped into the "Has Fallen" collection but the collection itself is not fetching a cover image (primary image). I can go in and locate them manually, but that's going to be very tedious for 1200 movies.
Happy2Play 9811 Posted August 17, 2024 Posted August 17, 2024 4 minutes ago, keduncan3 said: I have a follow-up question about collections primary art. All of my videos/TV shows have successfully fetched images, however my collections are not fetching covers for the collection as a whole. For instance, Olympus and London have fallen both have the correct metadata and images for each. They are grouped into the "Has Fallen" collection but the collection itself is not fetching a cover image (primary image). I can go in and locate them manually, but that's going to be very tedious for 1200 movies. First verify the Collections Library setting. If all enabled, I would toggle the options and refresh a Collection to see if Collection image and metadata are gotten. If not would need to see a server log for a specific example being refreshed.
