abdullah339 2 Posted August 17, 2024 Posted August 17, 2024 (edited) Hello everyone, I am facing a problem with transcoding. It does not work when playing the video. @Luke embyserver.txt Edited August 17, 2024 by abdullah339
Happy2Play 9798 Posted August 17, 2024 Posted August 17, 2024 (edited) Looks like you are having some database issues. 2024-08-17 17:24:44.066 Error SqliteItemRepository: Error saving items *** Error Report *** Version: 4.8.8.0 Command line: C:\Users\Admin\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19045 Framework: .NET 6.0.30 OS/Process: x64/x64 Runtime: C:/Users/Admin/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 12 Data path: C:\Users\Admin\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Admin\AppData\Roaming\Emby-Server\system SQLitePCL.pretty.SQLiteException: Constraint: FOREIGN KEY constraint failed SQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. at SQLitePCL.pretty.SQLiteException.CheckOk(sqlite3 db, Int32 rc) at SQLitePCL.pretty.StatementImpl.MoveNext() at SQLitePCL.pretty.DatabaseConnection.Execute(IDatabaseConnection This, String sql) at Emby.Server.Implementations.Data.SqliteItemRepository.SaveItemsInTranscation(IDatabaseConnection db, List`1 tuples, MetadataRefreshOptions metadataRefreshOptions) at Emby.Server.Implementations.Data.SqliteItemRepository.SaveItems(List`1 items, MetadataRefreshOptions metadataRefreshOptions, Action`1 afterSave, Boolean disableForeignKeys, CancellationToken cancellationToken) Source: SQLitePCL.pretty TargetSite: Void CheckOk(SQLitePCLEx.sqlite3, Int32) 2024-08-17 17:24:44.067 Error BaseItem: Error refreshing item الحلقة 3 9715 E:\emby\show_tv\Arabic\stc\Downtown\Downtown.S01E03.1080p.STC.WEB-DL.AAC2.0.H265-.mkv *** Error Report *** Version: 4.8.8.0 Command line: C:\Users\Admin\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19045 Framework: .NET 6.0.30 OS/Process: x64/x64 Runtime: C:/Users/Admin/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 12 Data path: C:\Users\Admin\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Admin\AppData\Roaming\Emby-Server\system SQLitePCL.pretty.SQLiteException: Constraint: FOREIGN KEY constraint failed SQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. at SQLitePCL.pretty.SQLiteException.CheckOk(sqlite3 db, Int32 rc) at SQLitePCL.pretty.StatementImpl.MoveNext() at SQLitePCL.pretty.DatabaseConnection.Execute(IDatabaseConnection This, String sql) at Emby.Server.Implementations.Data.SqliteItemRepository.SaveItemsInTranscation(IDatabaseConnection db, List`1 tuples, MetadataRefreshOptions metadataRefreshOptions) at Emby.Server.Implementations.Data.SqliteItemRepository.SaveItems(List`1 items, MetadataRefreshOptions metadataRefreshOptions, Action`1 afterSave, Boolean disableForeignKeys, CancellationToken cancellationToken) at Emby.Server.Implementations.Data.SqliteItemRepository.SaveItems(List`1 items, MetadataRefreshOptions metadataRefreshOptions, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.LibraryManager.UpdateItems(List`1 items, BaseItem parent, ItemUpdateType updateReason, Boolean setDateLastSaved, Boolean saveMetadata, MetadataRefreshOptions metadataRefreshOptions, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.LibraryManager.UpdateItem(BaseItem item, BaseItem parent, ItemUpdateType updateReason, MetadataRefreshOptions metadataRefreshOptions) at MediaBrowser.Controller.Entities.BaseItem.UpdateToRepository(ItemUpdateType updateReason, BaseItem parent, MetadataRefreshOptions metadataRefreshOptions) at MediaBrowser.Controller.Entities.BaseItem.UpdateToRepository(ItemUpdateType updateReason, MetadataRefreshOptions metadataRefreshOptions) at Emby.Providers.Manager.MetadataService`2.SaveItem(MetadataResult`1 result, Boolean isFirstRefresh, LibraryOptions libraryOptions, ItemUpdateType reason, IDirectoryService directoryService, MetadataRefreshOptions metadataRefreshOptions, CancellationToken cancellationToken) at Emby.Providers.Manager.MetadataService`2.RefreshMetadata(BaseItem item, MetadataRefreshOptions refreshOptions, BaseItem[] collectionFolders, LibraryOptions libraryOptions, CancellationToken cancellationToken) at MediaBrowser.Controller.Entities.BaseItem.RefreshMetadata(MetadataRefreshOptions options, BaseItem[] collectionFolders, LibraryOptions libraryOptions, CancellationToken cancellationToken) at MediaBrowser.Controller.Entities.BaseItem.RefreshMetadataRecursive(BaseItem[] children, MetadataRefreshOptions refreshOptions, BaseItem[] collectionFolders, LibraryOptions libraryOptions, Boolean recursive, Dictionary`2 newItemIds, IProgress`1 progress, CancellationToken cancellationToken) Source: SQLitePCL.pretty TargetSite: Void CheckOk(SQLitePCLEx.sqlite3, Int32) But you appear to have created libraries that are not suppported ie child libraries of parent libraries creating database issues. Line 228: 2024-08-17 17:20:34.560 Info LibraryMonitor: E:\emby\Move\Arabic is already being watched by watcher for E:\emby\Move. Adding item 4498 Line 240: 2024-08-17 17:20:34.563 Info LibraryMonitor: E:\emby\show_tv\Arabic is already being watched by watcher for E:\emby\show_tv. Adding item 6 So you have to remove the Arabic library and provide a different structure for it outside existing libraries. Edited August 17, 2024 by Happy2Play
abdullah339 2 Posted August 25, 2024 Author Posted August 25, 2024 Actually the encryption worked suddenly without any intervention from me. @Luke I think your review is very useful thank you @Happy2Play I would like to ask what is the recommended structure to avoid such problems
Happy2Play 9798 Posted August 25, 2024 Posted August 25, 2024 4 minutes ago, abdullah339 said: I would like to ask what is the recommended structure to avoid such problems As long as no library has a path that is part of another library you will be good as there really is no correct answer.
abdullah339 2 Posted August 26, 2024 Author Posted August 26, 2024 If I want to display all the movies as a section that appears in the emby server, and at the same time I want to divide these movies into Arabic, Indian and Turkish, what is the correct way to do that? @Happy2Play
Luke 42184 Posted August 26, 2024 Posted August 26, 2024 1 minute ago, abdullah339 said: If I want to display all the movies as a section that appears in the emby server, and at the same time I want to divide these movies into Arabic, Indian and Turkish, what is the correct way to do that? @Happy2Play There are several options to do that such as separating by folder, or using tags or collections.
abdullah339 2 Posted August 26, 2024 Author Posted August 26, 2024 I use the following: Emby/ show_tv/ arabic/ Turkish/ Indian/ Is this structure good? @Luke
Happy2Play 9798 Posted August 26, 2024 Posted August 26, 2024 Yes that is good. Almost any structure is possible you just have to ensure when creating libraries no folder path include a path that already exist in an existing library.
abdullah339 2 Posted August 26, 2024 Author Posted August 26, 2024 (edited) I first include a library: Emby/show_tv/ Then I create a new library for Arabic and include a path: Emby/show_tv/arabic Then I create a new library for Hindi and include a path: Emby/show_tv/Turkish Then I create a new library for Turkish and include a path: Emby/show_tv/Indian @Happy2Play Is this good or what method do you advise me to follow? Edited August 26, 2024 by abdullah339
Happy2Play 9798 Posted August 26, 2024 Posted August 26, 2024 (edited) No you add all those folder under Show_TV, so one library with three folder. If you want three libraries then you would not create the Show_TV library at all. Each language would be its own library. Edited August 26, 2024 by Happy2Play
abdullah339 2 Posted August 26, 2024 Author Posted August 26, 2024 What if I want to display all libraries and at the same time create the partition that I mentioned to you previously? @Happy2Play
Happy2Play 9798 Posted August 26, 2024 Posted August 26, 2024 You have two options here Create a library and point it to Emby/show_tv/ or point it to each language folder (this method will have no media in root folder show_tv/. Emby/show_tv/arabic/ Emby/show_tv/Turkish/ Emby/show_tv/Indian/ So no other library can contain any path already used.
