berrick 30 Posted August 25, 2024 Author Posted August 25, 2024 2 hours ago, Luke said: And the metadata fetchers? If metadata fetchers are Movie metadata downloaders. then see below
Luke 42288 Posted August 25, 2024 Posted August 25, 2024 Strange. Try unchecking and rechecking them. Then try refreshing metadata again on the movie or series.
berrick 30 Posted August 26, 2024 Author Posted August 26, 2024 Quote Try unchecking and rechecking them. Then try refreshing metadata again on the movie or series Tried but make no difference
Happy2Play 9814 Posted August 26, 2024 Posted August 26, 2024 Personally once a person has been imported I have never had a media refresh refresh the person. Requires person level refresh. So testing People is almost impossible as it is an only done once situation.
Luke 42288 Posted August 26, 2024 Posted August 26, 2024 10 hours ago, berrick said: Tried but make no difference What exactly did you do? What exactly happened?
berrick 30 Posted August 27, 2024 Author Posted August 27, 2024 Hi Both, Please can the following be answered. Does Emby process metadata for Music and movies differently. Quote once a person has been imported I have never had a media refresh refresh the person. Requires person level refresh. Luke is this correct. It seems this is what may be happening. What is the purpose of Emby's refresh metadata for movies if above is true. @Luke Quote What exactly did you do? What exactly happened I Scanned the movie library after unchecking Movie metadata downloaders Then re checked them and refreshed meta data for Trading places. This didnt attempt to go to the internet. Refreshing manually Dan Ackroyd and Emby went to internet and downloaded image. 1
Luke 42288 Posted August 28, 2024 Posted August 28, 2024 7 hours ago, berrick said: Hi Both, Please can the following be answered. Does Emby process metadata for Music and movies differently. Luke is this correct. It seems this is what may be happening. What is the purpose of Emby's refresh metadata for movies if above is true. @Luke I Scanned the movie library after unchecking Movie metadata downloaders Then re checked them and refreshed meta data for Trading places. This didnt attempt to go to the internet. Refreshing manually Dan Ackroyd and Emby went to internet and downloaded image. How many Emby libraries have you created, and what folder paths are added to each one?
berrick 30 Posted August 28, 2024 Author Posted August 28, 2024 Quote How many Emby libraries have you created, and what folder paths are added to each one? I have 8 libraries in total. All are on my Truenas Core NAS. On the Emby server there is a mapped drive Z: All libraries use the following Z:\cartoon, z:\ movies etc
Luke 42288 Posted August 28, 2024 Posted August 28, 2024 54 minutes ago, berrick said: I have 8 libraries in total. All are on my Truenas Core NAS. On the Emby server there is a mapped drive Z: All libraries use the following Z:\cartoon, z:\ movies etc HI, can you please list out the paths that are added to each library? Thanks.
berrick 30 Posted August 29, 2024 Author Posted August 29, 2024 Z:\cartoon Z:\Comedy Z:\video Z:\music Z:\photos Z:\TV Series Z:\workout Collections - Emby generated Z:\ = \\NAS\Media\
Luke 42288 Posted August 30, 2024 Posted August 30, 2024 Trading places is under z:\video, not z:\movies Is it possible you're getting the library options mixed up between the two? Can you please check the library settings for the z:\video library?
Happy2Play 9814 Posted August 30, 2024 Posted August 30, 2024 @Luketo the question at hand, does a movie item Refresh ever refresh people that are already in the database?
Luke 42288 Posted August 31, 2024 Posted August 31, 2024 3 hours ago, Happy2Play said: @Luketo the question at hand, does a movie item Refresh ever refresh people that are already in the database? The list of people for that movie, yes. If you don't currently have an image for any of those people, then it may pull in one from moviedb or tvdb. It doesn't do person-specific metadata at that time though.
Happy2Play 9814 Posted August 31, 2024 Posted August 31, 2024 8 minutes ago, Luke said: The list of people for that movie, yes. If you don't currently have an image for any of those people, then it may pull in one from moviedb or tvdb. It doesn't do person-specific metadata at that time though. Don't know the entire issue here as entering person image is gotten/displayed so will guess written in db on initial import. But OP is now forced to enter every person to have image displayed. Don't know it was an issue at import or not as people really are tricky when they do not work as expected. But download in advance is a factor here also during first import, correct?
Luke 42288 Posted August 31, 2024 Posted August 31, 2024 3 hours ago, Happy2Play said: Don't know it was an issue at import or not as people really are tricky when they do not work as expected. But download in advance is a factor here also during first import, correct? No, for people this option is not used as it could result in hammering moviedb/tvdb servers.
berrick 30 Posted September 6, 2024 Author Posted September 6, 2024 Quote Trading places is under z:\video, not z:\movies @Luke, My mistake Quote On the Emby server there is a mapped drive Z: All libraries use the following Z:\cartoon, z:\ movies etc It is Z:\video
berrick 30 Posted October 6, 2024 Author Posted October 6, 2024 Hi both, Any further update or are we saying this is working as it is suppose to?
Luke 42288 Posted October 7, 2024 Posted October 7, 2024 As a test, can you try spinning up a separate portable install and see how that compares?
Solution Luke 42288 Posted October 7, 2024 Solution Posted October 7, 2024 Do any of your movies and shows have their metadata locked?
berrick 30 Posted December 3, 2024 Author Posted December 3, 2024 HI all, Apologies for the long delay in providing any update. On 10/7/2024 at 11:47 PM, Luke said: Do any of your movies and shows have their metadata locked? FFS! yes......... am I mad at myself. Metadata was locked. Sometime ago I meant to put in a feature request asking to move the metadata lock option from the bottom of the list of options to the top and change the the colour of the menu option like the image below. To stop olde gits like me falling into this trap Whilst I haven't checked ever single movie, it is working better so will mark as resolved. Look forward to my request being considered. 1
