Extreme ram (120gigs) and swap usage
System Configuration:
  • Processor: Intel(R) Xeon(R) CPU E5-2620 v4 @ 2.10GHz
  • RAM: 128 GB
  • Machine Type: Rack Mount Chassis
  • Operating System: Ubuntu 20.04.6 LTS
  • Storage: HP P440, HP P840ar, HP LOGICAL VOLUME (multiple disks)
  • Display Resolution: 1024x768 pixels
Issue:
Recently, I’ve noticed that the RAM and swap usage on my Emby server has suddenly spiked significantly. Previously, the RAM usage never exceeded 20-30 GB, though the swap would occasionally fill up. However, now the RAM usage quickly goes through the roof within a few minutes of starting the server, even after multiple reboots.
Steps Taken:
  • Rebooted the server multiple times.
Problem:
Despite the reboots, the RAM usage continues to escalate rapidly. I have attached the relevant logs.
Request:
Can anyone help me identify what might be causing this issue? Is there something wrong on my end, or is there a fix available for this problem?
embyserver.txt
Hi, how many users connect to this server?
15-30 users.
Ok we’ll take a look at it. Thanks for reporting.
Q-Droid
16 hours ago, Dalpuri said:
15-30 users.
  • Agree 1
Btw luke this was solved when i upgraded my Linux packages. Now ram usage is around 20-25% constant no matter how many streams. Basically like before.
  • Thanks 1
