Luke 42241 Posted May 21, 2025 Posted May 21, 2025 Hi, what do you mean by player is old? What player is old?
vfducky 4 Posted May 22, 2025 Posted May 22, 2025 I meen the old chipset: S905x3[2], more than 6 years old.
Luke 42241 Posted May 22, 2025 Posted May 22, 2025 Is the firmware for the device up to date? Are there any android OS updates available for it?
Luke 42241 Posted May 31, 2025 Posted May 31, 2025 HI @vfduckyare you still having an issue with this?
Luke 42241 Posted June 28, 2025 Posted June 28, 2025 On 6/15/2025 at 12:05 AM, vfducky said: Hi @Luke Yes, problem is still there. OK @vfduckycan you please provide an example? How to Report a Problem Thanks !
jan108 1 Posted July 15, 2025 Posted July 15, 2025 I do have exactly same problem. Few weeks ago AC3 audio worked fine, one week ago it stopped. Android TV version 2.1.23g, device is Strong Leap S1 (kind of older device). Looks like this might be widespread bug.
visproduction 335 Posted July 15, 2025 Posted July 15, 2025 EAC3 is very different from AC3 codec. Apparently some versions of EAC3 were supported in Andorid and it looks like some are not. Also Android support may have removed many versions of EAC3 around the end of 2024. I am sure if you dig deeper you can get more exact information or someone in the forum already knows exactly what happened. Here is a page that posts steps to convert a file from EAC3 back to another codec. I am sure that will probably fix these issues, but it seems this is not really the question. Why did the media playback before and now it doesn't? Is it the same exact media copy that failed or are you talking about other AC3 audio, which is not the same as EAC3? The posts above show screenshots of EAC3 and text questions about AC3. Which is it? They are not the same. https://www.guru99.com/eac3-audio-not-supported.html
jan108 1 Posted July 15, 2025 Posted July 15, 2025 (edited) I just found a solution that works for me. I tried older versions of Emby, but it did not help. However, playig with settings in Emby, if I go to to playback and select stereo audio output instead of auto, the AC3 sound is back. I do not understand what happened, I did not make any changes and it for whatever reason stopped working in auto audio output setting. Edited July 15, 2025 by jan108 1
visproduction 335 Posted July 15, 2025 Posted July 15, 2025 Jan, Interesting. Grabbing a log, when it didn't work, would have helped find the problem. The only Emby info page I found in the guide is: https://emby.media/support/articles/LG-Why-not-Atmos.html?q=EAC3 FYI: EAC3 Details: https://professional.dolby.com/technologies/dolby-digital-plus/
