Luke 42239 Posted August 17, 2024 Posted August 17, 2024 1 hour ago, Bash103 said: This update broke the “Fill” aspect ratio. Hi there, can you please describe your issue in more detail? Thanks.
Bash103 7 Posted August 17, 2024 Author Posted August 17, 2024 When you’re watching a show in the old, 4x3 aspect ration you used to be able to click the settings button ( lower right of screen) and change the aspect ratio from “auto” to “fill” and it stretch the image to fill the screen. Now it doesn’t do anything.
seanbuff 1356 Posted August 17, 2024 Posted August 17, 2024 7 minutes ago, Bash103 said: When you’re watching a show in the old, 4x3 aspect ration you used to be able to click the settings button ( lower right of screen) and change the aspect ratio from “auto” to “fill” and it stretch the image to fill the screen. Now it doesn’t do anything. That looks like the mobile app (Android app). This topic is specifically for the Apple TV app. Does your issue still apply?
Bash103 7 Posted August 17, 2024 Author Posted August 17, 2024 That is the iOS app. It was easier to do the screenshots there. It is now broken in both apps. Here are photos of the TV app.
Bash103 7 Posted August 18, 2024 Author Posted August 18, 2024 (edited) Those are screenshots and photos taken with the camera. Can you not see them? Or are you taking about the actual show files? They are mkvs. Edited August 18, 2024 by Bash103
Luke 42239 Posted August 20, 2024 Posted August 20, 2024 On 8/18/2024 at 12:35 AM, Bash103 said: Those are screenshots and photos taken with the camera. Can you not see them? Or are you taking about the actual show files? They are mkvs. OK we'll take a look at it. Thanks.
Bash103 7 Posted August 28, 2024 Author Posted August 28, 2024 Could you also look into making the aspect setting "sticky" to the TV Show/ Movie? It sucks having to set it every time you come back to watch another episode. It sticks until you switch apps, or even just shows/movie. Would be great if it would "stick" the show/movie like Infuse does. You totally close the app for months and when you come back it is still set.
Luke 42239 Posted September 3, 2024 Posted September 3, 2024 On 8/27/2024 at 9:58 PM, Bash103 said: Could you also look into making the aspect setting "sticky" to the TV Show/ Movie? It sucks having to set it every time you come back to watch another episode. It sticks until you switch apps, or even just shows/movie. Would be great if it would "stick" the show/movie like Infuse does. You totally close the app for months and when you come back it is still set. Hi, yes the idea of remembering has come up before and is certainly possible for the future. Thanks.
