zysljd 3 Posted August 15, 2024 Posted August 15, 2024 There is distortion (or crackling sound) in the audio when using the android TV version , which doesn’t happen on the android version. I'm playing the same movie, both in direct play mode, with speed 2X activated, and it makes a popping sound (zi~zi) at certain times on Android TV, but the same clip doesn't have this problem on Android Standard. When I call external player 2X to play in tv version, there is no such problem. I tested several speeds 1X OK 1.25X starts to make noise
zysljd 3 Posted August 15, 2024 Author Posted August 15, 2024 18 minutes ago, ebr said: Hi. Why not just use the standard app? "My playback device is a set-top box, and I control it with a remote. The remote is difficult to use on the standard version." 1
Solution ebr 16337 Posted August 15, 2024 Solution Posted August 15, 2024 24 minutes ago, zysljd said: The remote is difficult to use on the standard version Why? Make sure the app display mode is set to "TV".
zysljd 3 Posted August 15, 2024 Author Posted August 15, 2024 3 minutes ago, ebr said: Why? Make sure the app display mode is set to "TV". Okay, I just realized I can set the display mode. It works now. Thank you very much. I have another question, I used to play it with an external player, which leaves a history in the external player, and when I play the movie again through the history, I can watch it normally, but I can't see that it's being played in the console of the emby server. Is this a risk?
Luke 42243 Posted August 15, 2024 Posted August 15, 2024 1 hour ago, zysljd said: Okay, I just realized I can set the display mode. It works now. Thank you very much. I have another question, I used to play it with an external player, which leaves a history in the external player, and when I play the movie again through the history, I can watch it normally, but I can't see that it's being played in the console of the emby server. Is this a risk? HI, I wouldn't say so. It is just reusing the same video url as before.
zysljd 3 Posted August 15, 2024 Author Posted August 15, 2024 1 minute ago, Luke said: HI, I wouldn't say so. It is just reusing the same video url as before. Yes, the same URL, I saw it in the log. But the api_key is fully documented in the external player history, is it not a bit risky to use this api_key and not have it appear in the console? Maybe the permissions of the playback api_key should be segregated from the other api_keys? I don't know if that's too much to worry about.
Luke 42243 Posted August 15, 2024 Posted August 15, 2024 10 minutes ago, zysljd said: Yes, the same URL, I saw it in the log. But the api_key is fully documented in the external player history, is it not a bit risky to use this api_key and not have it appear in the console? Maybe the permissions of the playback api_key should be segregated from the other api_keys? I don't know if that's too much to worry about. Yes this would be ideal, for playback to get a temporary one. That's something we are planning on doing.
zysljd 3 Posted August 15, 2024 Author Posted August 15, 2024 2 minutes ago, Luke said: Yes this would be ideal, for playback to get a temporary one. That's something we are planning on doing. It would be great if this could be done, exposing the api_key with full permissions is too risky. Thanks a lot! 1
