Raleblue 5 Posted August 12, 2024 Posted August 12, 2024 (edited) I have the same problem after the update 4.8.8.0. Before the update i had no problems with any sound, i have a Sony Bravia 4K tv and a Sony bluray with surround system. But there are now several movies where i get no sound, i watched some of the movies before, a few month ago and there was normal sound. Now, after the emby server update there are this same problems. I didn't change anything on the tv or surround settings that would cause these problems. When i switch to tv speaker, the sound works but when i switch to my surround system, there is no audio. I never had any problems with the app on my Sony Android tv, until now. My android emby app version is the newest 2.1.14g Edited August 12, 2024 by Raleblue
Luke 42242 Posted August 14, 2024 Posted August 14, 2024 @Raleblue Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! 1
Raleblue 5 Posted August 19, 2024 Author Posted August 19, 2024 Hy Luke, i send you here in the chat my logs from the tv app android and send it ti you directly her in the chat the ffpmeg logs. A few day ago and you can't solve this issue? Greetings
ebr 16335 Posted August 20, 2024 Posted August 20, 2024 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks. 1
Raleblue 5 Posted August 22, 2024 Author Posted August 22, 2024 Hi, i have a Sony Bravia Android and have installed the app back in 2022 and everthing was fine since 2 weeks ago. I don't have Amazon. For what Amazon?
Solution seanbuff 1356 Posted August 22, 2024 Solution Posted August 22, 2024 On 21/08/2024 at 03:27, ebr said: "Emby for Android on Google 23 minutes ago, Raleblue said: I don't have Amazon. For what Amazon? They are just advising you there is a different app in both the Amazon AND Google app stores. If you search "emb" in the Google Play store (remove the "y") -- you will see there are two apps, one named "Emby for Android" and one named "Emby for Android TV" Try the non-TV version, and see how it compares. 1
Luke 42242 Posted August 24, 2024 Posted August 24, 2024 @Raleblueplease let us know if this helps. Thanks ! 1
Raleblue 5 Posted August 25, 2024 Author Posted August 25, 2024 Oh i see. I found 2 apps. I am now installing the Emby for Android. I will let you know, thanks.
Raleblue 5 Posted August 25, 2024 Author Posted August 25, 2024 (edited) I can't believe it! With the Emby for Android the movies that didn't have surround sound, now they have It looks a little bit different but i have here all the admin options that i had only on my pc. Thanks to Seanbuff! Edited August 25, 2024 by Raleblue 1
