Jeansy 4 Posted August 13, 2024 Posted August 13, 2024 Hi, I use Emby for music streaming in my car and I have a problem with the shuffle function. When I go to one of my playlists and click "shuffle", only 50 songs from that playlist are added to the current playlist. As long as I don't restart my Emby server, those 50 songs will play in the same order every time I click the shuffle button on that playlist. (Even if I have played something else in between) I don't think this is the desired behavior. I would expect all songs to be added to the current playlist in a random order and the order to be changed every time I click the shuffle button. Keep up the great work, Jens
Luke 42242 Posted August 13, 2024 Posted August 13, 2024 Hi there, can you please provide an example? What version of Emby for Android are you on?
Jeansy 4 Posted August 13, 2024 Author Posted August 13, 2024 I am using the Emby Android app version 3.4.20. I have tried to reproduce the behavior and have not been able to. It seemed to work fine while my car is parked at home. But the problem definitely occurred when I was traveling in the last few weeks. Maybe it has something to do with the mobile connection not always being available or problems after a while when there were breaks between using Android Auto. I will try to reproduce the behavior in the near future and find out what could be the reason. If I find out, I will post my findings here. 1
