Moejoe101 0 Posted August 12, 2024 Posted August 12, 2024 Does anyone know how to fix 2019 nvidia shield pro intermittent wifi connection
Luke 42237 Posted August 12, 2024 Posted August 12, 2024 Hi, what exactly happens? @CBersdoes this happen with your Shield?
Moejoe101 0 Posted August 12, 2024 Author Posted August 12, 2024 As I mentioned the wifi is lost intermittently and I get disconnected with no internet, I know the problem is not the router because other devices are connected and has speed of over 560 gb so it can't be slow internet Thanks
Luke 42237 Posted August 14, 2024 Posted August 14, 2024 @FrostBytedoes this happen with your Shield?
GWTPqZp6b 50 Posted August 14, 2024 Posted August 14, 2024 Maybe disable DFS channels on your wifi AP
FrostByte 5452 Posted August 14, 2024 Posted August 14, 2024 7 hours ago, Luke said: @FrostBytedoes this happen with your Shield? Sorry, I haven't used wifi on my Shield since I first got it because I found wifi 5 to be too slow when streaming remuxes for me. Instead, I have my NAS, Shield, TV, Xbox, etc all wired to a switch and then out a wifi 6 AP only for Internet. All streaming is wired though.
js28194 42 Posted August 19, 2024 Posted August 19, 2024 (edited) Zero issues here over WiFi.... Asus GT-AX11000 router. Devices in different rooms and upstairs. Is this a Serve issue or client issue? Edited August 19, 2024 by js28194
