richenginner 2 Posted August 12, 2024 Posted August 12, 2024 i upgraded emby db, but this process causes problems with users login, system need enter http before, login works without this protocol how to downgrade version?
pwhodges 2039 Posted August 12, 2024 Posted August 12, 2024 Upgraded what to what? What problems do you have with login? What do you mean by "enter http"? The only thing I can say that might relate to anything there is that you can't go back from the beta to the stable release without rebuilding all your libraries from scratch. Paul 1
Luke 42290 Posted August 12, 2024 Posted August 12, 2024 Hi, yes can you please describe your issue in more detail?
