griffindodd 18 Posted August 11, 2024 Posted August 11, 2024 (edited) Fresh install of Server 4.8.8.0 on Ubuntu 22 Files on Synology NAS One of my movie folders keeps 'dropping off' my Emby library and I'm not sure why. I have four folders in my movie library, all have identical rights smb://<NAS-IP>/data/media/movies/HD Movie Archive smb://<NAS-IP>/data/media/movies/4k Movie Archive smb://<NAS-IP>/data/media/movies/HD Kid Friendly Movies smb://<NAS-IP>/data/media/movies/4K Kid Friendly Movies The Folder '4k Movie Archive' is the largest with 282 subfolders, and is the one that keeps dropping from the library whenever it does a new automatic scan. If I kick off a manual scan it will see the folder and add all the movies. but then the next time Emby scans the folders it misses the 4K folder and all the movies disappear from the library again. Below is an error report in the log when I start a manual scan. The file mentioned does exist on the server, the only difference I see is that it has an mkv extension. *** Error Report *** Version: 4.8.8.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 6.5.0-44-generic (buildd@lcy02-amd64-103) (x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0, GNU ld (GNU Binutils for Ubunt Framework: .NET 6.0.25 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 6 Data path: /var/lib/emby Application path: /opt/emby-server/system System.IO.IOException: System.IO.IOException: Create Handle Failed: media\movies\4k Movie Archive\Big.Fish.2003.2160p.UHD.BluRay.x265-bigfisHHH. NTStatus: FILE_DOES_NOT_EXIST at EzSmb.Transports.Shares.Handlers.Bases.HandlerBase..ctor(SmbType smbType, ISMBFileStore store, String path, HandleType handleType, NodeType nodeType, HandleArgs args) at EzSmb.Transports.Shares.Smb2Share.GetHandler(String path, HandleType handleType, NodeType nodeType, HandleArgs args) at EzSmb.Transports.Shares.Bases.ShareBase.CreateFolder(Node node, String folderName) at EzSmb.Node.CreateFolder(String folderName, String relatedPath) at Emby.Server.Implementations.IO.SmbFileSystem.CreateDirectory(String path) at NfoMetadata.Savers.BaseNfoSaver.SaveToFile(Stream stream, String path, LibraryOptions libraryOptions, CancellationToken cancellationToken) at NfoMetadata.Savers.BaseNfoSaver.Save(BaseItem item, LibraryOptions libraryOptions, CancellationToken cancellationToken) at Emby.Providers.Manager.ProviderManager.SaveMetadata(BaseItem item, LibraryOptions libraryOptions, ItemUpdateType updateType, IMetadataSaver[] savers, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void .ctor(EzSmb.Params.Enums.SmbType, SMBLibrary.Client.ISMBFileStore, System.String, EzSmb.Transports.Shares.Handlers.Enums.HandleType, EzSmb.NodeType, EzSmb.Transports.Shares.Handlers.HandleArgs) 2024-08-11 10:56:04.996 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /opt/emby-server/bin/ffprobe -i "http://127.0.0.1:8096/Items/File?Id=smb%3A%2F%2F192.168.68.111%2Fdata%2Fmedia%2Fmovies%2F4k+Movie+Archive%2FBlack.Panther.2018.2160p.UHD.BluRay.x265-EMERALD%2FBlack.Panther.2018.2160p.UHD.BluRay.x265.10bit.HDR.TrueHD.7.1.Atmos-RARBG.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data Edited August 11, 2024 by griffindodd
Solution Happy2Play 9812 Posted August 11, 2024 Solution Posted August 11, 2024 smb paths don't always play well with Emby. Dev will recommend mounting them locally. 1
griffindodd 18 Posted August 11, 2024 Author Posted August 11, 2024 OK thanks for the help, I will mount the folder in Ubuntu and point to that instead. 1
griffindodd 18 Posted August 12, 2024 Author Posted August 12, 2024 Everything seems to be staying as it should now that I am using a CIFs mounted volume. 1
