thostr 12 Posted January 17, 2019 Posted January 17, 2019 (edited) It looks to me latest version on Arch Linux is still at 3.5.3.0-1. Is 4.0 underway, or has Arch Linux been dropped as supported platform? Edited January 17, 2019 by thostr 1
Juan Simón 12 Posted January 17, 2019 Posted January 17, 2019 (edited) In the download page (https://emby.media/download.html https://github.com/MediaBrowser/Emby.Releases/releases)there are packages to download for several Linux distros ( Ubuntu, Debian, CentOS, Fedora, Linux Mint, OpenSUSE) but not for Arch Linux. Why ?In the official repositories is still version 3.5.3.0.On the other hand, package for Arch is very easy to generate but in this version there are important changes that may make it necessary for Emby developers to create the package. Edited January 17, 2019 by Juan Simón
Juan Simón 12 Posted January 17, 2019 Posted January 17, 2019 I have upgraded to server version 4 using the official PKGBUILD and changing the version number. I restarted the server and it seems that everything is correct but I'm not sure if the database upgrade operation was done because I accessed the web client immediately and it didn't show any message informing me about this. How can I test this?
Luke 42242 Posted January 17, 2019 Author Posted January 17, 2019 We'll have the arch package updated by the weekend. I'm not familiar with the method you used but you can check the version number in your server log. Thanks ! 4
thostr 12 Posted January 17, 2019 Posted January 17, 2019 (edited) Sounds great! Edited January 17, 2019 by thostr
Juan Simón 12 Posted January 18, 2019 Posted January 18, 2019 I'm not familiar with the method you used but you can check the version number in your server log. Thanks ! The version is updated. But in this blog post: https://emby.media/community/index.php?/blog/1/entry-447-announcing-emby-server-40/ you said: Important Upgrade Information After installing the update, the server will begin a database upgrade operation. If you attempt to open the web app during this time, you'll be given a friendly message informing you about this. This operation could take a little time, so please be patient with it. After this is complete, any plugins you may have installed will require updates, so please check the status of this on your server dashboard. If any plugins are updated, remember that Emby Server will need to be restarted. After all updates have been applied, we recommend that you run a library scan. The first scan following the update could take longer than usual, so please be patient. In my case, I'm not sure if this upgrade operation was done. Should this upgrade operation show any messages in the log?
Luke 42242 Posted January 18, 2019 Author Posted January 18, 2019 You were already on the beta before, right? So it already happened for you.
Juan Simón 12 Posted January 18, 2019 Posted January 18, 2019 You were already on the beta before, right? So it already happened for you. No, I've passed from 3.5.3.0 to 4.0.0.2 directly.
Luke 42242 Posted January 18, 2019 Author Posted January 18, 2019 Then your update must be already done.
Keltere 0 Posted January 18, 2019 Posted January 18, 2019 (edited) The version is updated. But in this blog post: https://emby.media/community/index.php?/blog/1/entry-447-announcing-emby-server-40/ you said: In my case, I'm not sure if this upgrade operation was done. Should this upgrade operation show any messages in the log? How did you do it? And do you get, on "transcoder" settings, the list of hardware decoders? Edited January 18, 2019 by Keltere
heciruam 30 Posted January 18, 2019 Posted January 18, 2019 How did you do it? And do you get, on "transcoder" settings, the list of hardware decoders? I believe you need to put it on advanced for them to show up. Just an assumption, as I haven't updated yet.
Keltere 0 Posted January 18, 2019 Posted January 18, 2019 I believe you need to put it on advanced for them to show up. Just an assumption, as I haven't updated yet. https://emby.media/community/index.php?/topic/67257-no-hevc-h265-encoder-vaapi/
chowbok 136 Posted February 10, 2019 Posted February 10, 2019 @@Luke, can we upgrade ffmpeg to 4.1 yet if we're tracking beta? I've had my server lock it on 4.0 for a while now, and it's starting to stop other packages from being able to update.
Luke 42242 Posted February 10, 2019 Author Posted February 10, 2019 No, we haven't tested 4.1 yet, but hopefully soon. Thanks.
cpt 0 Posted March 5, 2019 Posted March 5, 2019 Is there a problem with the latest Arch linux emby-server package and hardware encoding? I have installed Emby on Arch Linux using the emby-server package that is part of Arch Linux - emby-server 4.0.2.0-2. I have not been able to use hardware encoding. Previously running Plex on the same hardware with encoding working. Looking at the emby log I see it is failing to run this command /usr/bin/ffmpeg-emby -init_hw_device vaapi=vad0:/dev/dri/renderD128 -filter_hw_device vad0 -hwaccel vaapi -hwaccel_device /dev/dri/renderD128 -hwaccel_output_format yuv420p -f matroska -i file:"/g/Movies/BluRay/Back to the Future Part III (1990).mkv" -map 0:0 -map 0:1 -c:v:0 h264_vaapi -force_key_frames "expr:gte(t,n_forced*5)" -copyts -filter_complex "[0:3]scale=1920:1080:force_original_aspect_ratio=decrease[sub];[0:0][sub]overlay,format=nv12|vaapi,hwupload" -avoid_negative_ts disabled -start_at_zero -b:v:0 7616001 -maxrate 7616001 -bufsize 15232002 -profile high -level 4.1 -look_ahead 0 -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 ac3 -metadata:s:a:0 language=eng -disposition:a:0 default -ac:a:0 6 -ab:a:0 384000 -ar:a:0 48000 "/var/lib/emby/transcoding-temp/2af3f6097635c5b67431fe2d61ecb47c.mkv" Running the same command from the shell I get this error ffmpeg version 4.0.2-emby_p_2018_12_01 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 8.2.1 (GCC) 20181127 configuration: --disable-doc --disable-ffplay --disable-shared --disable-vdpau --disable-libxcb --disable-lzma --disable-sdl2 --disable-xlib --enable-fontconfig --enable-gmp --enable-gnutls --enable-gpl --enable-libaom --enable-libass --enable-libdrm --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-version3 --enable-nvdec --enable-nvenc --enable-static --enable-vaapi libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 Unrecognized option 'look_ahead'. Error splitting the argument list: Option not found If I remove the look_ahead option, it seems to create the mkv and CPU usage is quite low indicating that hardware encoding as in fact working.
Luke 42242 Posted March 6, 2019 Author Posted March 6, 2019 Hi there @@cpt can you please attach a complete ffmpeg log example? thanks.
cpt 0 Posted March 6, 2019 Posted March 6, 2019 (edited) ffmpeg log attached ffmpeg.log Edited March 6, 2019 by cpt
alucryd 318 Posted March 6, 2019 Posted March 6, 2019 @@cpt Does the system ffmpeg work? You can modify /etc/conf.d/emby-server to point to /usr/bin/ffmpeg and then restart emby.
Luke 42242 Posted March 6, 2019 Author Posted March 6, 2019 The system ffmepg will not work if it is ffmpeg 4.1, so make sure it is 4.0.3. We're looking into this though to see if we still even need to use that option. Thanks.
softworkz 5133 Posted March 7, 2019 Posted March 7, 2019 @@cpt - Thanks for reporting. This will be fixed in the next beta!
chowbok 136 Posted April 22, 2019 Posted April 22, 2019 Will we be getting an update of the release package soon? I've e-mailed @@alucryd but not gotten a response.
Luke 42242 Posted April 22, 2019 Author Posted April 22, 2019 Sorry, running a little behind, but it's on the way.
Rumbah 8 Posted April 29, 2019 Posted April 29, 2019 (edited) Will it be 4.1.1.0 or 4.1.0.26 first? Edited April 29, 2019 by Rumbah
Luke 42242 Posted April 29, 2019 Author Posted April 29, 2019 4.1.1 should be up tomorrow. Thanks guys.
Guest plexman Posted July 9, 2019 Posted July 9, 2019 (edited) I want to share this with everyone because it happened to me today. My server is a i5-6600 Skylake processor with an Intel HD 530, wich is supported for VAAPI transcoding either with libva-intel-driver (old one) or intel-media-driver (new one) packages. I installed the new one (intel-media-driver) and surprise! VAAPI wasn't working . After figuring out the problem and reading the amazing Arch Wiki, I found out that when using the new intel-media-driver you need to add an environment variable to tell the system to use the intel media driver. EZ solution, add this line to your /etc/conf.d/emby-server file: LIBVA_DRIVER_NAME=iHD restart the server and... Voilà! You have VAAPI working again! And in addition I tried using the system's ffmpeg (not ffmpeg-emby) wich now is version 4.1.3 and it works too! Hope it helps. References: https://wiki.archlinux.org/index.php/Hardware_video_acceleration Edited July 9, 2019 by plexman
