JPh 0 Posted January 17, 2017 Posted January 17, 2017 Oh it's a warning, nothing really urgent, and I purged my logs. Will give the full logs if I see it reappearing. Just wondering if I was alone or not.
leme 4 Posted March 6, 2017 Posted March 6, 2017 (edited) Got the following error in my Arch Linux journalctl emby-server.service: Mar 06 22:18:33 alarm systemd[1]: emby-server.service: Main process exited, code=exited, status=1/FAILURE Mar 06 22:18:33 alarm emby-server[12936]: [ERROR] FATAL UNHANDLED EXCEPTION: System.MissingMethodException: Method 'Array.Empty' not found. Mar 06 22:18:33 alarm emby-server[12936]: System.MissingMethodException: Method 'Array.Empty' not found. Mar 06 22:18:33 alarm emby-server[12936]: Unhandled Exception: Running latest version, emby-server 3.2.4-1. Any solution? Edit: known problem, mono version is too low. Please delete comment. Thanks Edited March 6, 2017 by leme
ax3l 7 Posted March 22, 2017 Posted March 22, 2017 I just got this error when upgrading to the current version "Emby is not compatible with the 10-bit versionof libx264. Please stick to the 8-bit version if you plan on using emby's transcoding features." Do i need to do anything to fix this? transcoding seems to still be working
psilocybe 0 Posted May 15, 2017 Posted May 15, 2017 Updating Mono to 5.0 seems to make Emby Server crash. Rolling back to latest 4.x works. System.AggregateException: One or more errors occurred. ---> System.NullReferenceException: Object reference not set to an instance of an object at Emby.Common.Implementations.BaseApplicationHost`1[TApplicationPathsType].GetTypes (System.Reflection.Assembly assembly) [0x0003d] in <9006177be51047bcacc3c0bd8243ee88>:0 at System.Linq.Enumerable+SelectManySingleSelectorIterator`2[TSource,TResult].MoveNext () [0x00051] in <a16ef142877c4302b96a103db87ba16b>:0 at System.Linq.Enumerable+WhereEnumerableIterator`1[TSource].ToArray () [0x00033] in <a16ef142877c4302b96a103db87ba16b>:0 at System.Linq.Enumerable.ToArray[TSource] (System.Collections.Generic.IEnumerable`1[T] source) [0x0001f] in <a16ef142877c4302b96a103db87ba16b>:0 at Emby.Common.Implementations.BaseApplicationHost`1[TApplicationPathsType].DiscoverTypes () [0x00097] in <9006177be51047bcacc3c0bd8243ee88>:0 at Emby.Common.Implementations.BaseApplicationHost`1+<Init>d__104[TApplicationPathsType].MoveNext () [0x0010c] in <9006177be51047bcacc3c0bd8243ee88>:0
Luke 42242 Posted May 15, 2017 Author Posted May 15, 2017 @@psilocybe, right now 4.8.1 is our recommended version. thanks.
jant90 15 Posted May 19, 2017 Posted May 19, 2017 @@psilocybe, right now 4.8.1 is our recommended version. thanks. Thanks, I'm currently holding back Mono to prevent automatically updating to 5.0 (as that one is in the 5.0 Arch repo's now). I'm wondering if the "update mono build configurations" in the latest beta's are to get Emby running under Mono 5.0? And does somebody in the Emby team maintain Emby in the Arch repo's? I'm asking because version 3.2.15.0 was uploaded only a day after it's release but it has been a week since version 3.2.16.0 now and it's still not in the Arch repo's (despite the out of date flag). As I recently switched to Arch/Manjaro I'm wondering how long it generally takes for Emby to be updated in their repo's.
Luke 42242 Posted May 19, 2017 Author Posted May 19, 2017 It is generally just a few days, but i will check with the maintainer. And no, the changes were not related to 5.0. 1
alucryd 318 Posted May 19, 2017 Posted May 19, 2017 @@jant90 I'm usually pretty quick to update emby for Arch Linux, but I was abroad for a few days with no access to a computer, which is why it took a bit longer. As for Manjaro, I have no idea how quickly they get their repos synced with ours. 1
jant90 15 Posted May 20, 2017 Posted May 20, 2017 @@jant90 I'm usually pretty quick to update emby for Arch Linux, but I was abroad for a few days with no access to a computer, which is why it took a bit longer. As for Manjaro, I have no idea how quickly they get their repos synced with ours. Alright, great. And thanks for updating again. As for Manjaro, they lag pretty far behind in their stable repo for some applications. So for Emby I just use the unstable repo (which is basically a clone of the Arch repo). This way I can keep Emby conveniently up-to-date on Manjaro.
leoplanet 0 Posted May 24, 2017 Posted May 24, 2017 I am trying to install Emby on my ARM version of Arch linux installed on my Pogoplug v2. I am able to install and run plex on it. When i install Emby mono is installed as a dependency but does not install properly. I get the following error. Any help is appreciated. Native stacktrace: Debug info from gdb: mono_gdb_render_native_backtraces not supported on this platform, unable to find gdb or lldb ================================================================= Got a SIGILL while executing native code. This usually indicates a fatal error in the mono runtime or one of the native libraries used by your application. ================================================================= /tmp/alpm_YiLztr/.INSTALL: line 5: 26970 Aborted (core dumped) cert-sync /etc/ssl/certs/ca-certificates.crt error: command failed to execute correctly
Luke 42242 Posted May 25, 2017 Author Posted May 25, 2017 @@leoplanet do you happen to know what mono version it is trying to install? thanks !
David69220 0 Posted June 14, 2017 Posted June 14, 2017 (edited) Sorry wrong post Edited June 14, 2017 by David69220
ax3l 7 Posted June 27, 2017 Posted June 27, 2017 @@alucryd any idea when 3.2.20.0 will be available on Arch?
alucryd 318 Posted June 27, 2017 Posted June 27, 2017 3.2.20.0 didn't build on Arch at the time it came out, and I haven't had the time to look into it since then. It builds fine now though, so I just pushed it to [community]. 1
alucryd 318 Posted July 4, 2017 Posted July 4, 2017 @@Luke Hey, I have some trouble trying to run emby on Arch with mono 5.0.1.1, here are the exceptions I'm getting: https://paste.xinu.at/zBgX/ Have you got any idea what could the cause?
Luke 42242 Posted July 5, 2017 Author Posted July 5, 2017 I would try removing all plugin dlls from the server's plugins folder.
alucryd 318 Posted July 9, 2017 Posted July 9, 2017 (edited) @@Luke Thx, looks like the anime plugin was the culprit. Edited July 9, 2017 by alucryd
dbt816 2 Posted August 22, 2017 Posted August 22, 2017 Just upgraded to 3.2.28.0 and noticed that in the web UI, none of the cover art images for the libraries are showing up. Looked in the server log and there are numerous MissingMethodException errors as shown below. Haven't had this issue in 3.2.27 or any other previous version. *** Error Report *** Version: 3.2.28.0 Command line: /usr/lib/emby-server/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe Operating system: Unix 4.12.8.2 64-Bit OS: True 64-Bit Process: True Mono: 5.0.0 (Stable 5.0.0.100/9667aa6 Wed Jul 19 07:38:25 CDT 2017) Processor count: 8 Program data path: /var/lib/emby Application directory: /usr/lib/emby-server System.MissingMethodException: Method 'MediaBrowser.Controller.Entities.Video.get_DisplayMediaType' not found. at CoverArt.Enhancers.CoverArtFolderEnhancer.SupportsInternal (MediaBrowser.Controller.Entities.IHasMetadata item, MediaBrowser.Model.Entities.ImageType imageType) [0x00000] in <b93356f1c0214396a069a010cd9efddb>:0 at CoverArt.Enhancers.CoverArtBaseEnhancer.Supports (MediaBrowser.Controller.Entities.IHasMetadata item, MediaBrowser.Model.Entities.ImageType imageType) [0x0000e] in <b93356f1c0214396a069a010cd9efddb>:0 at MediaBrowser.Api.Images.ImageService+<>c__DisplayClass23_0.<GetImage>b__0 (MediaBrowser.Controller.Providers.IImageEnhancer i) [0x00012] in <d1d63300294140da83a17b13c585230b>:0 System.MissingMethodException at CoverArt.Enhancers.CoverArtFolderEnhancer.SupportsInternal (MediaBrowser.Controller.Entities.IHasMetadata item, MediaBrowser.Model.Entities.ImageType imageType) [0x00000] in <b93356f1c0214396a069a010cd9efddb>:0 at CoverArt.Enhancers.CoverArtBaseEnhancer.Supports (MediaBrowser.Controller.Entities.IHasMetadata item, MediaBrowser.Model.Entities.ImageType imageType) [0x0000e] in <b93356f1c0214396a069a010cd9efddb>:0 at MediaBrowser.Api.Images.ImageService+<>c__DisplayClass23_0.<GetImage>b__0 (MediaBrowser.Controller.Providers.IImageEnhancer i) [0x00012] in <d1d63300294140da83a17b13c585230b>:0
Luke 42242 Posted August 22, 2017 Author Posted August 22, 2017 @@dbt816 check that you're running the latest version of the cover art plugin. It probably just hadn't updated yet following the server update. Thanks.
dbt816 2 Posted August 22, 2017 Posted August 22, 2017 @@dbt816 check that you're running the latest version of the cover art plugin. It probably just hadn't updated yet following the server update. Thanks. 4.0.43.0 is installed and seems to be the latest version
