alucryd 318 Posted November 1, 2015 Posted November 1, 2015 Pacman should have offered to delete the file and retry, I assume you already tried several times. This package comes from OBS upon which I have no control, can you have a look at it guys? In any case, I just updated the package in [community], you can upgrade to that one instead.
3psus 3 Posted November 1, 2015 Posted November 1, 2015 (edited) Just a thought, have you tried deleting that file and running the upgrade again? The file might have just not downloaded correctly. If that doesn't work, let us know and I am sure alucryd will fix it. Pacman should have offered to delete the file and retry, I assume you already tried several times. This package comes from OBS upon which I have no control, can you have a look at it guys? In any case, I just updated the package in [community], you can upgrade to that one instead. Pacman did offer to delete and redownload, which didn't resolve the issue. I tried again this morning though, everything was clean and the update went through without any problem. Thank you Edit: That was still through home_emby_Arch_Extra repository though. I will switch to the community repo for future updates. Edited November 1, 2015 by 3psus
Petersonb88 0 Posted December 9, 2015 Posted December 9, 2015 Everytime I try to restart emby-server, it crashing and will not load again. The only fix I can find is to uninstall it via pacman and delete /var/lib/emby which wipes everything out. Here is a pastebin link with the journalctl output. Can anyone see what's going on here? http://pastebin.com/0n5A3xLA
zeug 0 Posted December 12, 2015 Posted December 12, 2015 (edited) I got Emby Server up and running on my Raspberry Pi B+ using Arch Linux. I can add libraries, add plugins, etc.. Only problem I have is that my media library on my NAS might be too big? I have some performance issues. Scanning my 2TB folder takes ages and shuts Emby Server down at around 50%. The Emby Webserver dashboards reacts very slow as well and crashes my Emby Server sometimes. Next to Emby Server I am running a TVHeadend-Backend with a USB DVB-T-Stick on my Pi. I overclocked my Pi using following settings: ##Turbo arm_freq=1000 core_freq=500 sdram_freq=500 over_voltage=6 gpu_mem=256 Is anyone else here running Emby Server on his Raspberry Pi and experiencing similar problems? Or is the Pi just not strong enough for Emby Server? Edited December 12, 2015 by zeug
alucryd 318 Posted December 20, 2015 Posted December 20, 2015 Everytime I try to restart emby-server, it crashing and will not load again. The only fix I can find is to uninstall it via pacman and delete /var/lib/emby which wipes everything out. Here is a pastebin link with the journalctl output. Can anyone see what's going on here? http://pastebin.com/0n5A3xLA It would seem like a missing file is the cause, but I have no idea which one. Maybe @@Luke will be able to pinpoint it. Have you tried deleting the emby user and group after uninstalling emby via pacman and deleting /var/lib/emby? Just to make sure you start from a vanilla state. I got Emby Server up and running on my Raspberry Pi B+ using Arch Linux. I can add libraries, add plugins, etc.. Only problem I have is that my media library on my NAS might be too big? I have some performance issues. Scanning my 2TB folder takes ages and shuts Emby Server down at around 50%. The Emby Webserver dashboards reacts very slow as well and crashes my Emby Server sometimes. Next to Emby Server I am running a TVHeadend-Backend with a USB DVB-T-Stick on my Pi. I overclocked my Pi using following settings: ##Turbo arm_freq=1000 core_freq=500 sdram_freq=500 over_voltage=6 gpu_mem=256 Is anyone else here running Emby Server on his Raspberry Pi and experiencing similar problems? Or is the Pi just not strong enough for Emby Server? I've never tried it on a RPi, but since your model only has 512MB of memory I'm guessing you're running out of it quite fast. At startup emby takes about 300MB on my server, and I've seen it go past twice that number.
3psus 3 Posted January 5, 2016 Posted January 5, 2016 When making the switch to the community repo, I remember that I had to change /var/lib/emby-server to /var/lib/emby. The shadow service is now complaining about not finding /var/lib/emby-server. How can I point it to the new and good directory? Here is some output from systemctl: [epsus@[member="arch"] etc]$ sudo systemctl status shadow -l ● shadow.service - Verify integrity of password and group files Loaded: loaded (/usr/lib/systemd/system/shadow.service; static; vendor preset: disabled) Active: failed (Result: exit-code) since Mon 2016-01-04 19:43:59 EST; 17min ago Process: 30813 ExecStart=/usr/bin/pwck -r (code=exited, status=2) Main PID: 30813 (code=exited, status=2) Jan 04 19:43:59 Arch systemd[1]: Starting Verify integrity of password and group files... Jan 04 19:43:59 Arch pwck[30813]: user 'emby': directory '/var/lib/emby-server' does not exist
thefirstofthe300 292 Posted January 5, 2016 Posted January 5, 2016 When making the switch to the community repo, I remember that I had to change /var/lib/emby-server to /var/lib/emby. The shadow service is now complaining about not finding /var/lib/emby-server. How can I point it to the new and good directory? Here is some output from systemctl: [epsus@[member="arch"] etc]$ sudo systemctl status shadow -l ● shadow.service - Verify integrity of password and group files Loaded: loaded (/usr/lib/systemd/system/shadow.service; static; vendor preset: disabled) Active: failed (Result: exit-code) since Mon 2016-01-04 19:43:59 EST; 17min ago Process: 30813 ExecStart=/usr/bin/pwck -r (code=exited, status=2) Main PID: 30813 (code=exited, status=2) Jan 04 19:43:59 Arch systemd[1]: Starting Verify integrity of password and group files... Jan 04 19:43:59 Arch pwck[30813]: user 'emby': directory '/var/lib/emby-server' does not exist That error is caused because the home directory of the user "emby" no longer exists. If you stop Emby, delete the user, reinstall the emby-server package, and start Emby again, that error should go away. To test if it is gone, just run a "pwck".
alucryd 318 Posted January 5, 2016 Posted January 5, 2016 (edited) When making the switch to the community repo, I remember that I had to change /var/lib/emby-server to /var/lib/emby. The shadow service is now complaining about not finding /var/lib/emby-server. How can I point it to the new and good directory? Here is some output from systemctl: [epsus@[member="arch"] etc]$ sudo systemctl status shadow -l ● shadow.service - Verify integrity of password and group files Loaded: loaded (/usr/lib/systemd/system/shadow.service; static; vendor preset: disabled) Active: failed (Result: exit-code) since Mon 2016-01-04 19:43:59 EST; 17min ago Process: 30813 ExecStart=/usr/bin/pwck -r (code=exited, status=2) Main PID: 30813 (code=exited, status=2) Jan 04 19:43:59 Arch systemd[1]: Starting Verify integrity of password and group files... Jan 04 19:43:59 Arch pwck[30813]: user 'emby': directory '/var/lib/emby-server' does not exist As thefirstofthe300 said, but it still won't work because the database still points to the wrong directory. The proper migration steps are: Stop and uninstall emby-server Delete the emby user and group Install emby-server from [community] Use the provided emby-migrate-database script, in your case: sudo emby-migrate-database /var/lib/emby-server /var/lib/emby Delete your old database in /var/lib/emby-server Start emby-server BTW, make sure you manually move /var/lib/emby back to /var/lib/emby-server before you do all this. Edited January 5, 2016 by alucryd 1
3psus 3 Posted January 5, 2016 Posted January 5, 2016 Thanks for this detailed explanation. I knew I could just create /var/lib/emby-server and shadow would stop complaining, but this is obviously not the way to handle the situation. I'll follow your instructions and report after, thanks a lot
GeniusLoci 0 Posted January 5, 2016 Posted January 5, 2016 Hello, guys, Emby does not see the folders on my Arch (external HDD and internal folders). Please, help.
3psus 3 Posted January 5, 2016 Posted January 5, 2016 Hello, guys, Emby does not see the folders on my Arch (external HDD and internal folders). Please, help. Have you made sure permissions were sufficient?
GeniusLoci 0 Posted January 6, 2016 Posted January 6, 2016 Have you made sure permissions were sufficient? I tried but it does not help. Maybe I was wrong to do so. Some advice (about permission)?
3psus 3 Posted January 6, 2016 Posted January 6, 2016 Well, the user "emby" certainly needs to have read access to the folders containing your media. For this, emby could be the owner of the folder or be part of the group that has access. You might appreciate this wiki page: https://wiki.archlinux.org/index.php/Users_and_groups When you say that emby does not see your folders, what do you mean exactly? When you add your media folders, is it that you cannot add them or that you really don't see them at all? What happens if you enter the path manually?
GeniusLoci 0 Posted January 6, 2016 Posted January 6, 2016 Well, the user "emby" certainly needs to have read access to the folders containing your media. For this, emby could be the owner of the folder or be part of the group that has access. You might appreciate this wiki page: https://wiki.archlinux.org/index.php/Users_and_groups When you say that emby does not see your folders, what do you mean exactly? When you add your media folders, is it that you cannot add them or that you really don't see them at all? What happens if you enter the path manually? Thanks for the reply. This is my folder "Home" - up here everything well. The same thing with external HDD. If I enter the path manually changes nothing.
Luke 42242 Posted January 6, 2016 Author Posted January 6, 2016 Can you grab the server log? http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ I think it is probably going to show an access failure, just want to confirm. Thanks.
GeniusLoci 0 Posted January 6, 2016 Posted January 6, 2016 2016-01-06 18:22:25.4223 Error HttpServer: Error processing request for /emby/Environment/DirectoryContents?includeDirectories=true&path=%2Frun%2Fmedia%2Fuser%2FHDD *** Error Report *** Version: 3.0.5783.0 Command line: /usr/lib/emby-server/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe Operating system: Unix 4.3.3.2 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby Mono: 4.2.2 (Stable 4.2.2.10/7b87787 Mon Dec 21 19:36:52 UTC 2015) Application Path: /usr/lib/emby-server/MediaBrowser.Server.Mono.exe Access to the path "/run/media/user/HDD" is denied. ServiceStack.HttpError No Stack Trace Available
Luke 42242 Posted January 6, 2016 Author Posted January 6, 2016 Yea there it is. So we need to figure out how to grant the emby user access to that path Access to the path "/run/media/user/HDD" is denied.
3psus 3 Posted January 6, 2016 Posted January 6, 2016 What is the output of ls -l /run/media/user | grep HDD
GeniusLoci 0 Posted January 7, 2016 Posted January 7, 2016 What is the output of ls -l /run/media/user | grep HDD drwxrwxrwx 1 user users 12288 Dec 26 19:49 HDD Yea there it is. So we need to figure out how to grant the emby user access to that path Access to the path "/run/media/user/HDD" is denied. How ? I cannot exit from this hell with the permissions.
alucryd 318 Posted January 7, 2016 Posted January 7, 2016 No offense but if you can't figure a basic permission issue by yourself you probably shouldn't be using Arch Linux in the first place. @@3psus gave you a link to start with, and I'm sensing you need to document yourself on file permissions too. Anyway, there are many ways to deal with this, each with their pros and cons: make the emby user the owner of that dir, add emby to the group owning that dir, or make it 776 or 777, but enough with the easy dirty not so good ideas. Create a new group, add your own user and emby to it, and make that group owner of the directory then add setgid recursively, that should give you read and access permissions to the share and any new file or dir created inside of it, you can play with the mod to add write permission as well if you want to store your metadata locally.
GeniusLoci 0 Posted January 7, 2016 Posted January 7, 2016 No offense but if you can't figure a basic permission issue by yourself you probably shouldn't be using Arch Linux in the first place. @@3psus gave you a link to start with, and I'm sensing you need to document yourself on file permissions too. Anyway, there are many ways to deal with this, each with their pros and cons: make the emby user the owner of that dir, add emby to the group owning that dir, or make it 776 or 777, but enough with the easy dirty not so good ideas. Create a new group, add your own user and emby to it, and make that group owner of the directory then add setgid recursively, that should give you read and access permissions to the share and any new file or dir created inside of it, you can play with the mod to add write permission as well if you want to store your metadata locally. Thanks for the reply. Your answer did not sense - you could save. Everything that you have said already know. I was hoping that someone had this problem and I could help. The answer that I do not have to use linux and do proper permissions on folders and that very easy not helps me
alucryd 318 Posted January 7, 2016 Posted January 7, 2016 This is clearly a permission issue so everything I said is helpful, and like I said 777 is really dirty. Now have a look at '/run/media/user', you'll notice there's no way the permissions on that dir will allow emby to see the folders inside. Don't use your DE's automount feature and mount your HDD in some nice folder like '/mnt'.
GeniusLoci 0 Posted January 7, 2016 Posted January 7, 2016 Don't use your DE's automount feature and mount your HDD in some nice folder like '/mnt'. Thanks, that helps !
williamkray 1 Posted February 1, 2016 Posted February 1, 2016 (edited) i'm running into an issue lately where nothing will play in the web client if i'm not on a local connection. i think i've pinned it down to an ffmpeg issue, because that's where the breadcrumbs lead: /usr/bin/ffmpeg -fflags +genpts -noaccurate_seek -i file:"/home/media/movies/The.Martian.2015.720p.BluRay.DTS.x264-PriMeHD.mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_qsv -force_key_frames expr:gte(t,n_forced*5) -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -pix_fmt yuv420p -preset 7 -look_ahead 0 -b:v 2180000 -vsync vfr -profile:v high -level 4.1 -map_metadata -1 -threads 0 -codec:a:0 libmp3lame -ac 2 -ab 320000 -af "aresample=async=1,volume=2" -y "/var/lib/emby/transcoding-temp/6ae22cee14b1ce49036fb28e0f02abdf.mkv" ffmpeg version 2.8.5 Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --prefix=/usr --disable-debug --disable-static --disable-stripping --enable-avisynth --enable-avresample --enable-fontconfig --enable-gnutls --enable-gpl --enable-ladspa --enable-libass --enable-libbluray --enable-libdcadec --enable-libfreetype --enable-libfribidi --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libv4l2 --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-shared --enable-version3 --enable-x11grab libavutil 54. 31.100 / 54. 31.100 libavcodec 56. 60.100 / 56. 60.100 libavformat 56. 40.101 / 56. 40.101 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 40.101 / 5. 40.101 libavresample 2. 1. 0 / 2. 1. 0 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 2.101 / 1. 2.101 libpostproc 53. 3.100 / 53. 3.100 Unrecognized option 'look_ahead'. Error splitting the argument list: Option not found look_ahead appears to be not an argument that can be used... but arch repos don't appear to have a newer version of FFmpeg that might include this feature. everything was working fine previously, and i haven't updated my system since then, so i'm at a bit of a loss. does anyone have any input about what i'm doing wrong? EDIT: never mind, of course as soon as i ask for help i figure it out. i set transcode settings to auto, apparently my system doesn't support Intel Quick Sync. Edited February 1, 2016 by williamkray
ebike 13 Posted March 29, 2016 Posted March 29, 2016 (edited) I have the server working great on an Odroid-XU3 ARM device ... even transcoding works well ... worse case 50% CPU 1080p -> 1MB stream Would love to see a Home Theater client for Linux though .... and I can't get TvHeadend to work ... (Previously been a Plex user, but will shift if the TVHeadend client works ..) Edited March 29, 2016 by ebike
