Arch Linux
puithove
Yea, it "should" be as simple as moving the dir, and updating the .conf to point to the new location.  Doesn't seem to be that way unless I totally missed something (wouldn't be the first time).
puithove
On a positive note, it seems to be healthy enough after finishing a full refresh.  I had t also fire off the "people" task from the scheduler to get it to fill in actor images again.
The down side is I wonder if it has left a bunch of unused .jpg and other files hanging around in there now, or if it would have used the same name and overwrote the existing ones.
  • Like 1
thefirstofthe300
That is nice to hear. :)
I figure that for now, my plan is to just leave the old install intact in case people want to go your route. Otherwise, they can just rebuild their library from scratch. I assume that people who customize their nfo files are saving them to the media folders though. Probably not the best assumption. :(
  • 2 weeks later...
Hello, I installed git version from aur , everything work like expected but... There is an "emby" user created and used to launch the server, which can't access to my media folder owned by a normal user. So I have change the user used to launch the server in the systemd Script. But when I do it nothing works.
Anyone have a solution?
thefirstofthe300
That would probably be due to the fact that the emby user owns the default program data directory. I suppose that you have the option of chowning the data directory to be owned by the new user who is running the server. Your other option is to create another ProgramData directory and edit /etc/conf.d/emby-server.conf to point to that directory. The server will then use the newly defined directory and /etc/conf.d should remain the same during package updates.
Please update to the latest git package though before making any changes. If you aren't updated, then any change you make before updating will get overwritten. I had to make some changes to the package to make /etc/conf.d/emby-server unchanging during an update or package change (from git to beta, beta to stable, etc).
You are editing the service file by placing a copy of it at /etc/systemd/system/emby-server.service and editing that one, right? I am just checking to make sure you don't have to change your service file on every update.
Edited by DaBungalow
  • Like 1
Hi all, I have a problem accessing the emby server. What I did yesterday:
  • fresh arch linux installation on Raspberry PI (via Noobs)
  • pacman –Syu (have to fix after that a little bit)
  • pacman –Syy
  • pacman –S wget
  • pacman –S base-devel
  • pacman –S samba
  • download emby-server from tarball AUR
  • makepkg –s (sudo -u nobody makepkg -s)
  • makepkg –U emby-server-3.0.5572.0-2-armv6h.pkg.tar.xz
  • systemctl start emby-server.service
  • systemctl enable emby-server.service
when I run ‘ps –ef | grep emby’ I get:
avahi      174     1  0 19:07 ?        00:00:00 avahi-daemon: running [emby-server.local]
I think the installation looks fine Also when I restart the PI the service is running.  But when I try to access the emby server with
http://myembyserverIP:8096
the connection is refused. Did I miss something?
thefirstofthe300
I am trying to figure out what Avahi is doing running the server...That process just doesn't look right to me.
I am thinking an active firewall could be causing the problem, although vanilla Arch as far as I know doesn't activate a firewall. Second most likely issue is that you are attempting to connect to the wrong IP address. Are you attempting to connect via LAN address or via a WAN address? If the answer is WAN address, have you opened the port on your router?
If you are 100% certain that the problem isn't firewall or IP address related, is Emby generating any logs at /var/lib/emby-server/logs? If so could you post the latest one.
Also, what does the environment file (/etc/conf.d/emby-server) and service file (/usr/lib/systemd/system/emby-server.service OR /etc/systemd/system/emby-server if you are using a custom file) look like. Could you post those too?
puithove
It doesn't look like Avahi is running emby... that looks like the computer has been named "emby-server". "emby-server.local" is the hostname and that's just Avahi telling you what it is.  If that's the only occurrence of emby in the process list, then the service isn't running.
@@tipex - can you look at the output from:
sudo systemctl status emby-server.service
and
sudo journalctl -u emby-server.service
systemctl status will tell you the current status (running, failed, etc) along with the last few lines of console output and journalctl will give you all the console output from the unit going back into history - which should include any errors from the emby-server process.  It gets dumped into 'less' so you can page down/up through it
Edited by puithove
thefirstofthe300
Oh...Ok. that makes sense.
I don't have any experience with Avahi so thanks for correcting me. :)
puithove
My hostname is 'big1' - you can see that from my avahi daemon:
avahi     1481     1  0 13:10 ?        00:00:00 avahi-daemon: running [big1.local]
Whereas my emby (mediabrowser) processes are these:
emby      1752     1  0 13:10 ?        00:00:00 /bin/sh /usr/bin/emby-server
emby      1758  1752 11 13:10 ?        00:11:04 /usr/bin/mono /usr/lib/emby-server/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe
thefirstofthe300
Yeah. Those are what I am seeing. Too for emby.
OMG, my fault. hostname is emby-Server.
I tried now 'systemctl start emby-server.service'
Output of 'sudo systemctl status emby-server.service'
* emby-server.service - Media Browser Server is a home media server built
using other popular open source technologies.   Loaded: loaded
(/usr/lib/systemd/system/emby-server.service; enabled; vendor preset:
disabled)   Active: failed (Result: start-limit) since Fri
2015-04-10 21:05:44 CEST; 14s ago  Process: 352
ExecStart=/usr/bin/emby-server (code=exited, status=2) Main PID: 352
Apr 10 21:05:44 emby-server systemd[1]: Unit emby-server.service entered
failed state.Apr 10 21:05:44 emby-server systemd[1]: emby-server.service
failed.Apr 10 21:05:44 emby-server systemd[1]: emby-server.service holdoff
time over, scheduling restart.Apr 10 21:05:44 emby-server systemd[1]:
Stopping Media Browser Server is a home media server built using other popular
open source technologies....Apr 10 21:05:44 emby-server systemd[1]: Starting
Media Browser Server is a home media server built using other popular open
source technologies....Apr 10 21:05:44 emby-server systemd[1]: start request
repeated too quickly for emby-server.serviceApr 10 21:05:44 emby-server
systemd[1]: Failed to start Media Browser Server is a home media server built
using other popular open source technologies..Apr 10 21:05:44 emby-server
systemd[1]: Unit emby-server.service entered failed state.Apr 10 21:05:44
emby-server systemd[1]: emby-server.service failed.
Output of 'sudo journalctl -u emby-server.service' is
-- Logs begin at Thu 1970-01-01 01:00:06 CET, end
at Fri 2015-04-10 21:08:29 CEST. --Apr 10 19:05:52 emby-server systemd[1]:
Starting Media Browser Server is a home media server built using other popular
open source technologies....Apr 10 19:05:52 emby-server systemd[1]: Started
source technologies..Apr 10 19:05:52 emby-server emby-server[1483]: Cannot
open assembly '/usr/lib/emby-server/MediaBrowser.Server.Mono.exe': Permission
denied.Apr 10 19:05:52 emby-server systemd[1]: emby-server.service: main
process exited, code=exited, status=2/INVALIDARGUMENTApr 10 19:05:52
emby-server systemd[1]: Unit emby-server.service entered failed state.Apr 10
19:05:52 emby-server systemd[1]: emby-server.service failed.Apr 10 19:05:53
emby-server systemd[1]: emby-server.service holdoff time over, scheduling
restart.Apr 10 19:05:53 emby-server systemd[1]: Stopping Media Browser
Server is a home media server built using other popular open source
technologies....Apr 10 19:05:53 emby-server systemd[1]: Starting Media
Browser Server is a home media server built using other popular open source
technologies....Apr 10 19:05:53 emby-server systemd[1]: Started Media
technologies..Apr 10 19:05:53 emby-server emby-server[1488]: Cannot open
denied.Apr 10 19:05:53 emby-server systemd[1]: emby-server.service: main
process exited, code=exited, status=2/INVALIDARGUMENTApr 10 19:05:53
19:05:53 emby-server systemd[1]: emby-server.service failed.Apr 10 19:05:53
technologies..Apr 10 19:05:53 emby-server emby-server[1492]: Cannot open
19:05:53 emby-server systemd[1]: emby-server.service failed.Apr 10 19:05:54
restart.Apr 10 19:05:54 emby-server systemd[1]: Stopping Media Browser
technologies....Apr 10 19:05:54 emby-server systemd[1]: Starting Media
technologies....Apr 10 19:05:54 emby-server systemd[1]: Started Media
technologies..Apr 10 19:05:54 emby-server emby-server[1496]: Cannot open
denied.Apr 10 19:05:54 emby-server systemd[1]: emby-server.service: main
process exited, code=exited, status=2/INVALIDARGUMENTApr 10 19:05:54
19:05:54 emby-server systemd[1]: emby-server.service failed.Apr 10 19:05:54
technologies..Apr 10 19:05:54 emby-server emby-server[1500]: Cannot open
19:05:54 emby-server systemd[1]: emby-server.service failed.lines
1-39
The directory  /var/lib/emby-server is empty.
emby-server.service
[Unit]
Description=Media Browser Server is a home media server built using
[Service]
EnvironmentFile=/etc/conf.d/emby-server
WorkingDirectory=/usr/lib/emby-server
User=emby
Group=emby
Restart=on-failure
[Unit]
After=network.target
[Install]
WantedBy=multi-user.target
MONO_EXECUTABLE=/usr/bin/mono
PROGRAM_DATA=/var/lib/emby-server
FFMPEG=/usr/bin/ffmpeg
FFPROBE=/usr/bin/ffprobe
It looks like that the service will not start, but I have no idea what was my mistake???
The PI is connected via LAN and I can ping it from Windows command line.
Sorry for bothering you!
Some formatting issues.
thefirstofthe300
It looks like permission somehow got botched.
Do a sudo chown -R emby:emby /usr/lib/emby-server.
I am thinking that will fix the issue.
Ignore the above, you need to run sudo systemctl stop emby-server followed by sudo systemctl start emby-server, otherwise you don't have the proper privileges to actually start the emby-server service.
Also, may I ask why the service file has two unit sections?
after I run 'sudo chown -R emby:emby /usr/lib/emby-server' it works.
now I have the Welcome to Emby Screen
Thanks a lot!
  • Like 1
Thank you very much, it's work, you are my Hero  :)
  • Like 1
  • 2 months later...
When trying to makepkg I am getting a bunch of 404 codes on dependencies.  I'm not sure that this is an emby issue itself, but I don't get that problem when trying top install other things.
==> Making package: emby-server 3.0.5621.4-1 (Mon Jun 15 20:50:18 MDT 2015)
==> Checking runtime dependencies...
==> Installing missing dependencies...
resolving dependencies...
:: There are 2 providers available for libx264.so=144-32:
:: Repository extra
   1) libx264  2) libx264-10bit
Enter a number (default=1): 1
looking for conflicting packages...
Packages (69) alsa-lib-1.0.29-1  cairo-1.14.2-1  damageproto-1.2.1-3
              elfutils-0.161-3  enca-1.16-1  flac-1.3.1-1  fontconfig-2.11.1-1
              freetype2-2.5.5-1  fribidi-0.19.6-2  giflib-5.1.1-1
              graphite-1:1.2.4-1  gsm-1.0.13-8  harfbuzz-0.9.40-2
              json-c-0.12-2  lame-3.99.5-2  lcms2-2.7-1  libass-0.12.2-1
              libasyncns-0.8-5  libbluray-0.8.1-1  libdrm-2.4.61-1
              libexif-0.6.21-2  libgdiplus-3.12-1  libjpeg-turbo-1.4.0-1
              liblqr-0.4.2-1  libmms-0.6.4-1  libmodplug-0.8.8.5-1
              libogg-1.3.2-1  libomxil-bellagio-0.9.3-1  libpciaccess-0.13.4-1
              libpng-1.6.16-1  libpulse-6.0-2  libsndfile-1.0.25-2
              libssh-0.7.0-2  libtheora-1.1.1-3  libtiff-4.0.3-5
              libtxc_dxtn-1.0.1-6  libva-1.5.1-1  libvdpau-1.1-1
              libvorbis-1.3.5-1  libvpx-1.4.0-2  libx264-2:144.20150223-1
              libxdamage-1.1.4-2  libxshmfence-1.2-1  libxxf86vm-1.1.4-1
              libzen-0.4.31-1  llvm-libs-3.6.1-1  mesa-10.5.6-1
              mesa-libgl-10.5.6-1  opencore-amr-0.1.3-2  openjpeg-1.5.2-1
              opus-1.1-1.1  orc-0.4.23-1  pixman-0.32.6-1  python-3.4.3-2
              recode-3.6-8  schroedinger-1.0.11-2  sdl-1.2.15-7  speex-1.2rc2-1
              speexdsp-1.2rc3-1  v4l-utils-1.6.3-1  wayland-1.7.0-1  x265-1.6-1
              xf86vidmodeproto-2.3.1-3  xvidcore-1.3.3-1  ffmpeg-1:2.6.3-1
              imagemagick-6.9.1.2-1  libmediainfo-0.7.74-1  mono-4.0.1.28-1
              sqlite-3.8.10.2-1
Total Download Size:    35.96 MiB
Total Installed Size:  324.35 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages ...
error: failed retrieving file 'libjpeg-turbo-1.4.0-1-arm.pkg.tar.xz' from mirror.archlinuxarm.org : The requested URL returned error: 404
warning: failed to retrieve some files
error: failed retrieving file 'wayland-1.7.0-1-arm.pkg.tar.xz' from mirror.archlinuxarm.org : The requested URL returned error: 404
error: failed retrieving file 'mesa-10.5.6-1-arm.pkg.tar.xz' from mirror.archlinuxarm.org : The requested URL returned error: 404
error: failed retrieving file 'mesa-libgl-10.5.6-1-arm.pkg.tar.xz' from mirror.archlinuxarm.org : The requested URL returned error: 404
error: failed retrieving file 'mono-4.0.1.28-1-arm.pkg.tar.xz' from mirror.archlinuxarm.org : The requested URL returned error: 404
error: failed retrieving file 'x265-1.6-1-arm.pkg.tar.xz' from mirror.archlinuxarm.org : The requested URL returned error: 404
error: failed retrieving file 'ffmpeg-1:2.6.3-1-arm.pkg.tar.xz' from mirror.archlinuxarm.org : The requested URL returned error: 404
error: failed to commit transaction (unexpected error)
Errors occurred, no packages were upgraded.
==> ERROR: 'pacman' failed to install missing dependencies.
Any guidance you could provide? Thanks.
EDIT:  I figured it out I think and it was a silly mistake.  I needed to update the system using
pacman -Syyu
Edited by manok
  • 3 weeks later...
Guys im trying to install in a clean arch. Im getting error when is cheking the tarball.
How I can change the md5 checksum to get the installed?
Thanks in advance.
thefirstofthe300
Just run updpkgsums in the folder that is extracted from the tarball. That is the easy way.
The hard way is manually updating the md5sums in the order the sources are listed in the PKGBUILD.
I will take a look when I get back to my server on Sunday.
Sent from my Nexus 7 using Tapatalk
DaBungalow thanks for the reply. In both cases do the updpkgsums and updating manually the md5sums in PKGBUILD im getting this error.
sed: can not read /home/hmelero/tmp/emby-server/src/MediaBrowser-3.0.5641.4/MediaBrowser.Server.Mono/ImageMagickSharp.dll.config: There is no such file or directory
EDIT: I was able to get it installed entering in the folder src and reming from Emby-3.0.5641.4 to MediaBrowser-3.0.5641.4
The only problem that i see for now is I can't change the language from english to spanish.
Edited by jamesdm
Double post sorry.
Edited by jamesdm
thefirstofthe300
I am updating the packages now. Apparently, Luke changed the repo name on me. :)
thefirstofthe300
So the packages are now updated. Let me know if anything else is off.
  • Like 1
  • 1 month later...
I tried to makepkg on my raspberry pi 2 (armv7), I added 'armv7h' to arch, but I got a segmentation fault at xbuild:
PKGBUILD: line 28:   195 Segmentation fault      (core dumped) xbuild /p:Configuration="Release Mono" /p:Platform="Any CPU" /p:OutputPath="${srcdir}/usr/lib/emby-server" /t:build MediaBrowser.Mono.sln
I also tried to add ARCH=arm to xbuild, but that didn't change anything. Is there a way to compile for my raspberry pi 2?
Edited by Semi
This is out of date on the AUR. There's also a few edits that need to be made once it is brought up to date. (Currently 5675.1)
On lines: 25, 29 and 31:
Change: MediaBrowser-${pkgver}
To: Emby-${pkgver}
Thanks for the response, although my problem was something different. It turned out to be caused by grsecurity/pax. Running pax with softmode solved the problem - I have a highly specific system so its basically my own fault ;)
