khvalera 0 Posted November 20, 2021 Posted November 20, 2021 20 hours ago, softworkz said: ffdetect is there to detect video hardware acceleration. On Linux, it can detect VAAPI, QSV, Nvidia and AMF. From my state of knowledge, none of those are supported on arm platforms, that's why we don't have an ffdetect binary for arm. But things can change, that's why I was asking whether there's a specific case you are up to. I did not delve into the details of the program, but after building the package from the source, the server works for some time and crashes, in the logs I saw that the reason for this is ffdetect, which is not there. You have the ffdetect file for arm in the package https://github.com/MediaBrowser/Emby.Releases/releases/download/4.6.6.0/emby-server-deb_4.6.6.0_armhf.deb, I checked it works. But I did not find where I can get it separately, or better to collect the source code.
softworkz 5133 Posted November 20, 2021 Posted November 20, 2021 Emby Server does not crash when ffdetect is missing. We don't have it on several platforms (osx, android, rpi, ..). You may just need to remove it from the server startup command line.
Luke 42242 Posted November 20, 2021 Author Posted November 20, 2021 15 minutes ago, khvalera said: I did not delve into the details of the program, but after building the package from the source, the server works for some time and crashes, in the logs I saw that the reason for this is ffdetect, which is not there. You have the ffdetect file for arm in the package https://github.com/MediaBrowser/Emby.Releases/releases/download/4.6.6.0/emby-server-deb_4.6.6.0_armhf.deb, I checked it works. But I did not find where I can get it separately, or better to collect the source code. Hi, can you please attach the emby server log? It could be for some other reason. Thanks.
khvalera 0 Posted November 20, 2021 Posted November 20, 2021 1 hour ago, softworkz said: Emby Server does not crash when ffdetect is missing. We don't have it on several platforms (osx, android, rpi, ..). You may just need to remove it from the server startup command line. Thanks! This is useful information, I will try to search where ffdetect occurs and fix it.
softworkz 5133 Posted November 20, 2021 Posted November 20, 2021 it's in <installdir>/bin/emby-server
khvalera 0 Posted November 20, 2021 Posted November 20, 2021 2 hours ago, Luke said: Hi, can you please attach the emby server log? It could be for some other reason. Thanks. The server was started with the -ffdetect parameter. The fixed PKGBUILD is located at: https://github.com/snuglinux/pkgbuilds/tree/master/emby-server
khvalera 0 Posted November 20, 2021 Posted November 20, 2021 There is one more question. I noticed that when watching video from an arm device via the web interface, there are minor delays, and if you look through the emby-theater program, everything is fine. Is it related to the peculiarity of video stream processing? Can I fix it somehow?
Luke 42242 Posted November 21, 2021 Author Posted November 21, 2021 19 hours ago, khvalera said: There is one more question. I noticed that when watching video from an arm device via the web interface, there are minor delays, and if you look through the emby-theater program, everything is fine. Is it related to the peculiarity of video stream processing? Can I fix it somehow? The Theater app can direct play pretty much everything, whereas the web browser cannot and may sometimes require conversion on the server, so that is likely the difference.
dadquaris 0 Posted December 27, 2021 Posted December 27, 2021 (edited) emby-server (not AUR, community repo - https://archlinux.org/packages/community/x86_64/emby-server/ ) has been outdated on Arch for over a month. Is it possible to fork this to a more active maintainer? In the meanwhile, it is possible (but a PITA) to compile emby-server. mkdir emby-server cd emby-server svn checkout --depth=empty svn://svn.archlinux.org/community cd community svn update emby-server cd emby-server/trunk After this, you need to edit two lines in the PKGBUILD Change this line: pkgver=4.6.6.0 To this: pkgver=4.6.7.0 Change this line: b2sums=('082b675b3da8c44a914517ce7625f79d5a9388b2b99ce81f536e79526ba596cb6a7096ebb92352a8002c3dcd362c388448bd13bc64cc6efbe9524312b17427c1' To this: b2sums=('65edbbea3442682fb9443f706c0c588ceea6986bd62cf155dd286d18e000746ae2b716c3f5e8e970e956772f5246e0655a05afe27b677cce713a23379b79a247' Then build the package: makepkg -s If all goes well, install the package: makepkg -i This is not at all an ideal way to update emby-server, and I would not recommend using it. It worked for me. Edited December 27, 2021 by dadquaris
dadquaris 0 Posted December 31, 2021 Posted December 31, 2021 Nevermind, looks like it finally got updated yesterday.
Luke 42242 Posted December 31, 2021 Author Posted December 31, 2021 2 hours ago, dadquaris said: Nevermind, looks like it finally got updated yesterday. Yes it's updated now. Apologies for the delay. Thanks. 1
PhilipsTV 0 Posted December 31, 2021 Posted December 31, 2021 41 minutes ago, Luke said: Yes it's updated now. Apologies for the delay. Thanks. Eis gelegt
EmbyPenguin 17 Posted April 1, 2022 Posted April 1, 2022 (edited) Deleted. Edited April 1, 2022 by EmbyPenguin
10479 3 Posted May 7, 2022 Posted May 7, 2022 Are there any known issues with throttling right now? I did a search over the entire forum and didn't find anything directly related yet. Yesterday, I updated to Version 4.6.7.0 and since then, hardware transcode throttling doesn't work. I haven't dug into it too deeply yet because in all likelihood, I would just roll back a version in the meantime. I checked the change logs for the beta versions ahead and only saw a throttling fix for chromecast. So far it's happened with multiple clients remotely and if I force transcoding locally, I can reproduce it. Only steps I've taken so far are restarting the server and disabling and reenabling throttling, which haven't worked. The logs seem fairly normal, but I have attached a debug log of the transcode that I forced with a low bitrate locally. https://pastebin.com/a3AjSEae - transcoding log https://pastebin.com/YUbpXvK0 - emby-server log (start of stream only as it's all just the same repetitive info at the end) Let me know if there's anything else I should do or if it's already known. Thanks.
alucryd 318 Posted May 8, 2022 Posted May 8, 2022 @10479 The last update temporarily uses the system ffmpeg, the current tarball doesn't build against the latest libdav1d. This will be fixed in the upcoming release, it's just around the corner.
Carnival5353 0 Posted May 21, 2022 Posted May 21, 2022 The update to 4.7.0.60 on Arch is causing emby-server to fail due to a donet issue: emby-server.service - Emby brings together your videos, music, photos, and live television. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: disabled) Drop-In: /etc/systemd/system/emby-server.service.d └─override.conf, write-permissions.conf Active: failed (Result: exit-code) since Sat 2022-05-21 09:06:46 EDT; 47s ago Process: 1069 ExecStart=/usr/bin/emby-server (code=exited, status=150) Main PID: 1069 (code=exited, status=150) CPU: 16ms May 21 09:06:46 computer systemd[1]: Started Emby brings together your videos, music, photos, and live television.. May 21 09:06:46 computer emby-server[1069]: It was not possible to find any compatible framework version May 21 09:06:46 computer emby-server[1069]: The framework 'Microsoft.AspNetCore.App', version '6.0.0' (x64) was not found. May 21 09:06:46 computer emby-server[1069]: - No frameworks were found. May 21 09:06:46 computer emby-server[1069]: You can resolve the problem by installing the specified framework and/or SDK. May 21 09:06:46 computer emby-server[1069]: The specified framework can be found at: May 21 09:06:46 computer emby-server[1069]: - https://aka.ms/dotnet-core-applaunch?framework=Microsoft.AspNetCore.App&framework_version=6.0.0&arch=x64&rid=arch-x64 May 21 09:06:46 computer systemd[1]: emby-server.service: Main process exited, code=exited, status=150/n/a May 21 09:06:46 computer systemd[1]: emby-server.service: Failed with result 'exit-code'. Downgrading to 4.6.7.0-4 gets it up and running for me.
chowbok 136 Posted May 21, 2022 Posted May 21, 2022 You can get 4.7.0.60 to work by installing aspnet-runtime.
Carnival5353 0 Posted May 21, 2022 Posted May 21, 2022 Ah thanks! Wonder why it's not listed as a dependency then.
chowbok 136 Posted May 21, 2022 Posted May 21, 2022 Just an oversight. There's a bug report for it. 1
alucryd 318 Posted May 21, 2022 Posted May 21, 2022 Thanks for the heads up! Already had aspnet-runtime installed so I didn't run into this, fixing the package asap.
deeproot 0 Posted May 22, 2022 Posted May 22, 2022 (edited) wrong forum Edited May 22, 2022 by deeproot
dadquaris 0 Posted June 5, 2022 Posted June 5, 2022 On 12/31/2021 at 10:01 AM, Luke said: Yes it's updated now. Apologies for the delay. Thanks. Heads up, emby is out of date again, for over a week.
10479 3 Posted June 5, 2022 Posted June 5, 2022 8 minutes ago, dadquaris said: Heads up, emby is out of date again, for over a week. https://github.com/archlinux/svntogit-community/tree/packages/emby-server/trunk If you're desperate enough...
dadquaris 0 Posted June 5, 2022 Posted June 5, 2022 (edited) 1 minute ago, 10479 said: https://github.com/archlinux/svntogit-community/tree/packages/emby-server/trunk If you're desperate enough... Heh, I just used the procedure I outlined a bit above. Honestly, I might just make an AUR package. Edited June 5, 2022 by dadquaris
