AGhost 0 Posted September 4, 2020 Posted September 4, 2020 (edited) On 9/2/2020 at 7:08 AM, AGhost said: Thought this was about the best place to post my issue. I just moved Sputnik (2020) to my movies from it's temporary location and I cannot get it to pull information when I select identify. I get no results at all. I decided to try on other movies in the library and it's the same even though everything else in the library and my other libraries are correct. Any idea why Emby might not be pulling data from any of the sites setup just for this? Steps attempted below. Thanks launched emby opened movies library found what sputnix was being called clicked the 3 dots selected identify searched for sputnik nothing searched for sputnik 2020 nothing searched by it's movie database number nothing embyserver.txt 523.98 kB · 1 download Can I please get some help with figuring out what is causing this issue? @ebr Edited September 4, 2020 by AGhost
Luke 42242 Posted September 4, 2020 Author Posted September 4, 2020 17 minutes ago, AGhost said: Can I please get some help with figuring out what is causing this issue? @ebr All of your outgoing communications to MovieDb are failing. Looks like an issue with the trust store on your system. Is that potentially out of date? I would make sure your system is fully up to date.
AGhost 0 Posted September 4, 2020 Posted September 4, 2020 (edited) 10 minutes ago, Luke said: All of your outgoing communications to MovieDb are failing. Looks like an issue with the trust store on your system. Is that potentially out of date? I would make sure your system is fully up to date. My system is fully up to date. What is this "trust store"? EDIT: Just checked full updates and other than 1 file fully updated. Edited September 4, 2020 by AGhost
Luke 42242 Posted September 4, 2020 Author Posted September 4, 2020 3 hours ago, AGhost said: My system is fully up to date. What is this "trust store"? EDIT: Just checked full updates and other than 1 file fully updated. Actually taking another look at the error it looks like it's being thrown by the .NET Core runtime. You can see it here: https://github.com/dotnet/corefx/pull/2806/files#diff-97146b006d1e7892c2cc8390444738bdR73 This is a little hacky but try creating an environment variable called HOME that points to your system user's home directory.
AGhost 0 Posted September 4, 2020 Posted September 4, 2020 I'll have to take your word on that cause that's beyond my skill level. Now this environment variable what is that exactly? By the way thanks for the feedback and help.
Seb8888 0 Posted September 4, 2020 Posted September 4, 2020 Possible skip password when i log to my tv ?
Luke 42242 Posted September 5, 2020 Author Posted September 5, 2020 10 hours ago, Luke said: Actually taking another look at the error it looks like it's being thrown by the .NET Core runtime. You can see it here: https://github.com/dotnet/corefx/pull/2806/files#diff-97146b006d1e7892c2cc8390444738bdR73 This is a little hacky but try creating an environment variable called HOME that points to your system user's home directory. This can help you set an environment variable: https://linuxize.com/post/how-to-set-and-list-environment-variables-in-linux/
MediaMogal 19 Posted October 2, 2020 Posted October 2, 2020 Noticed Emby attempted to update 4 times without success I'm not seeing any issues with the server itself. That seem to be working exactly as it should, so no idea why it's not updating. Resource temporarily unavailable at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at MediaBrowser.Common.Updates.GithubUpdater.CheckForUpdateResult(String organzation, String repository, Version minVersion, PackageVersionClass updateLevel, String assetFilename, String packageName, String targetFilename, TimeSpan cacheLength, CancellationToken cancellationToken) at Emby.Server.Implementations.ApplicationHost.CheckForApplicationUpdate(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.SystemUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Resource temporarily unavailable at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackagesWithoutRegistrationInfo(Boolean enableCache, CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePluginUpdates(Version applicationVersion, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.PluginUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Resource temporarily unavailable at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackagesWithoutRegistrationInfo(Boolean enableCache, CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePluginUpdates(Version applicationVersion, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.PluginUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Resource temporarily unavailable at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at MediaBrowser.Common.Updates.GithubUpdater.CheckForUpdateResult(String organzation, String repository, Version minVersion, PackageVersionClass updateLevel, String assetFilename, String packageName, String targetFilename, TimeSpan cacheLength, CancellationToken cancellationToken) at Emby.Server.Implementations.ApplicationHost.CheckForApplicationUpdate(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.SystemUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) embyserver.txt hardware_detection-63737207745.txt
Luke 42242 Posted October 2, 2020 Author Posted October 2, 2020 1 minute ago, MediaMogal said: Noticed Emby attempted to update 4 times without success I'm not seeing any issues with the server itself. That seem to be working exactly as it should, so no idea why it's not updating. Resource temporarily unavailable at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at MediaBrowser.Common.Updates.GithubUpdater.CheckForUpdateResult(String organzation, String repository, Version minVersion, PackageVersionClass updateLevel, String assetFilename, String packageName, String targetFilename, TimeSpan cacheLength, CancellationToken cancellationToken) at Emby.Server.Implementations.ApplicationHost.CheckForApplicationUpdate(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.SystemUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Resource temporarily unavailable at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackagesWithoutRegistrationInfo(Boolean enableCache, CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePluginUpdates(Version applicationVersion, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.PluginUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Resource temporarily unavailable at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackagesWithoutRegistrationInfo(Boolean enableCache, CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePluginUpdates(Version applicationVersion, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.PluginUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Resource temporarily unavailable at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at MediaBrowser.Common.Updates.GithubUpdater.CheckForUpdateResult(String organzation, String repository, Version minVersion, PackageVersionClass updateLevel, String assetFilename, String packageName, String targetFilename, TimeSpan cacheLength, CancellationToken cancellationToken) at Emby.Server.Implementations.ApplicationHost.CheckForApplicationUpdate(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.SystemUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) embyserver.txt 13.78 MB · 0 downloads hardware_detection-63737207745.txt 114.77 kB · 0 downloads The server doesn't automatically update on arch linux, rather it just checks for updates to notify you in the server dashboard when one is available. Plugins do automatically update though. As you can see, http requests to both github and our admin domain are coming back "resource temporarily unavailable". As this is happening with more than one domain, this suggests you have something on your system blocking or tampering with those requests, such as firewall, security software, or VPN. 1
MediaMogal 19 Posted October 2, 2020 Posted October 2, 2020 More likely like you said the update has to be done for the AUR side when they push the latest update. bet bottom dollar they're still post the 4.50 and not the 4.51. Right now I have no security software of any kind. EDIT: just checked Pamac and yea they're still on 4.50. Now about those instructions in the first post. Like I said I read that post several times and there are no Arch instructions.
Luke 42242 Posted October 2, 2020 Author Posted October 2, 2020 12 minutes ago, MediaMogal said: Now about those instructions in the first post. Like I said I read that post several times and there are no Arch instructions. Yes there are. You click the link to open the downloads page of our website. Select linux, then arch linux.
MediaMogal 19 Posted October 2, 2020 Posted October 2, 2020 23 minutes ago, Luke said: Yes there are. You click the link to open the downloads page of our website. Select linux, then arch linux. we must be looking at two different pages, cause the below does not have a link for download. https://emby.media/community/index.php?/topic/42868-emby-theater-for-linux/
Luke 42242 Posted October 3, 2020 Author Posted October 3, 2020 3 hours ago, MediaMogal said: we must be looking at two different pages, cause the below does not have a link for download. https://emby.media/community/index.php?/topic/42868-emby-theater-for-linux/ Ok this is the server section of the community.
kevaskous 0 Posted October 30, 2020 Posted October 30, 2020 (edited) The Emby-Server package in Arch Repo is very, very outdated. Any hope this gets resolved? Edited October 30, 2020 by kevaskous
Luke 42242 Posted October 30, 2020 Author Posted October 30, 2020 4 hours ago, kevaskous said: The Emby-Server package in Arch Repo is very, very outdated. Any hope this gets resolved? Hi, what version are you on?
alucryd 318 Posted October 30, 2020 Posted October 30, 2020 I would hardly call 2 minor versions very, very outdated, but I suppose I forgot the Arch Linux package with what's been happening lately. It is now up to date.
kevaskous 0 Posted November 10, 2020 Posted November 10, 2020 On 10/30/2020 at 3:29 PM, alucryd said: I would hardly call 2 minor versions very, very outdated, but I suppose I forgot the Arch Linux package with what's been happening lately. It is now up to date. it is when there is critical fixes and improvements in those versions from long ago that you need and run into daily. Thank you for the update!
rossome 3 Posted May 26, 2021 Posted May 26, 2021 Using an Nvidia, NVENC enable card, what dependencies are necessary to have HDR tonemapping enabled and accessible? HDR tonemapping is hidden/inaccessible on my arch box. hardware_detection-63757534721.txt
Luke 42242 Posted May 26, 2021 Author Posted May 26, 2021 13 hours ago, rossome said: Using an Nvidia, NVENC enable card, what dependencies are necessary to have HDR tonemapping enabled and accessible? HDR tonemapping is hidden/inaccessible on my arch box. hardware_detection-63757534721.txt 220.37 kB · 1 download Hi there, have you followed our hardware acceleration setup guide? https://support.emby.media/support/solutions/articles/44001160148-hardware-acceleration-overview
rossome 3 Posted May 26, 2021 Posted May 26, 2021 3 hours ago, Luke said: Hi there, have you followed our hardware acceleration setup guide? https://support.emby.media/support/solutions/articles/44001160148-hardware-acceleration-overview I have; and acceleration is working just fine, minus the ability to enable HDR tonemapping (disabled/hidden via html/css in my transcoding section). There is nothing in the hardware-acceleration-overview that states whether or not my configuration should support it. Hence the ask about potential missing dependencies. I have a xeon system (no igpu) and am relying on nvenc/nvdec solely (quadro p4000) for hardware acceleration. Any further information would be greatly appreciated.
Luke 42242 Posted June 4, 2021 Author Posted June 4, 2021 On 5/26/2021 at 4:05 PM, rossome said: I have; and acceleration is working just fine, minus the ability to enable HDR tonemapping (disabled/hidden via html/css in my transcoding section). There is nothing in the hardware-acceleration-overview that states whether or not my configuration should support it. Hence the ask about potential missing dependencies. I have a xeon system (no igpu) and am relying on nvenc/nvdec solely (quadro p4000) for hardware acceleration. Any further information would be greatly appreciated. Please attach the emby server log as well. thanks.
khvalera 0 Posted November 19, 2021 Posted November 19, 2021 Compiled the emby-server package for archlinux armv7l. Where to download or better collect the ffdetect file for arm? For x64, you can download it from here: https://mediabrowser.github.io/embytools/ffdetect-$ {_ffmpeg_ver }-x64.tar.xz
softworkz 5133 Posted November 19, 2021 Posted November 19, 2021 7 minutes ago, khvalera said: Compiled the emby-server package for archlinux armv7l. Where to download or better collect the ffdetect file for arm? For x64, you can download it from here: https://mediabrowser.github.io/embytools/ffdetect-$ {_ffmpeg_ver }-x64.tar.xz Which kind of video hwa do you expect to detect on an armv7 Linux?
khvalera 0 Posted November 19, 2021 Posted November 19, 2021 1 hour ago, softworkz said: Which kind of video hwa do you expect to detect on an armv7 Linux? I don’t understand your question?
softworkz 5133 Posted November 19, 2021 Posted November 19, 2021 ffdetect is there to detect video hardware acceleration. On Linux, it can detect VAAPI, QSV, Nvidia and AMF. From my state of knowledge, none of those are supported on arm platforms, that's why we don't have an ffdetect binary for arm. But things can change, that's why I was asking whether there's a specific case you are up to.
