KeithA 5 Posted August 10, 2024 Posted August 10, 2024 Is it possible to display "Tags" in the limited first menu in the Android Auto interface? I have my music playlists sorted using tags and I cant use this configuration well currently. Thanks
Luke 42241 Posted August 14, 2024 Posted August 14, 2024 Hi, we'll look into it but I don't think so. The Android Auto user interface is coming from Google. We are only supplying the data and have limited ability to control how it looks.
KeithA 5 Posted September 2, 2024 Author Posted September 2, 2024 Thanks. I see your point regarding limited control of the menus however I see differing items in other Android Auto apps. The is a favorites menu but it doesn't list playlists. Is that something that can be added? Thanks
Luke 42241 Posted September 15, 2024 Posted September 15, 2024 Hi, did you try clicking on your music library in android auto? You should have Tags under there, no?
KeithA 5 Posted October 7, 2025 Author Posted October 7, 2025 The tags don't show when I open Emby on AA. However if I select my server, then select music there is a listing of items. I think this is where tags should be. If I select one of the items listed for example songs and then go back tags will then be show. This method always works. Is there a way to return to that position within the Emby menu each time I open AA? Is there a way to make the favorite menu in AA show favorited playlists? Thanks
