hoppel118 37 Posted February 25, 2018 Posted February 25, 2018 (edited) The emby omv-plugin is not working since more than a year now, if I remember right. This is the case for omv3 and omv4. You need to install it by command line or to use the docker container. I use the docker ce plugin and the emby docker container under omv4 since round about 2 months. Before omv4 I used the docker ce plugin and the emby container under omv3. It works really flawless. Greetings Hoppel Edited February 25, 2018 by hoppel118
/Ky 3 Posted February 25, 2018 Posted February 25, 2018 (edited) The emby omv-plugin is not working since more than a year now, if I remember right. This is the case for omv3 and omv4. You need to install it by command line or to use the docker container. I use the docker ce plugin and the emby docker container under omv4 since round about 2 months. Before omv4 I used the docker ce plugin and the emby container under omv3. It works really flawless. Greetings Hoppel Yep just figured that out as can't seem to get the Mono repo to work in OMV (using 3.x) although I wont bother if the plugin no longer works so whats the better way? I have never used Docker so havent got a clue where to start EDIT: So still unsure about which method to use but edging towards the Deb package way so would I have to download the package to OMV then simply execute the command via the CLI: dpkg -i emby-server-deb_3.3.0.0_amd64.debJust a side note though what folder would I have to place the Deb file within OMV? I'm getting used to Linux again as I have recently switched back on my main PC to Fedora as from what I recall I can download the pakcage also via dpkg can't I? This would save me from tranferring the file. Another thing which is kind of OCD but I hate having left over files and crap so say I wanted to uninstall Emby at a later date would I just run "dpkg --remove emby-server-deb_3.3.0.0_amd64"? I hate having residual files or crap left over lol. Edited February 25, 2018 by /Ky
ellnic 26 Posted February 25, 2018 Posted February 25, 2018 (edited) If you see mono near the top of the log then that means it is based on our legacy package and I would instead use either the .Deb or docker. Noted, I tend to piddle around quite a bit in the command line anyway and use OMV to simplify a lot of the mundane/time consuming day to day tasks. I'll check my Emby server later. The emby omv-plugin is not working since more than a year now, if I remember right. This is the case for omv3 and omv4. You need to install it by command line or to use the docker container. I use the docker ce plugin and the emby docker container under omv4 since round about 2 months. Before omv4 I used the docker ce plugin and the emby container under omv3. It works really flawless. Greetings Hoppel That'll be why I can't find it! So I stand corrected about it being updated regularly. Most stuff is to be fair - but I guess with the docker it was easier to let people use that. No point doubling efforts. @@/Ky I would use the .deb if you are ok with the command line. To install: wget https://github.com/MediaBrowser/Emby/releases/download/3.3.0.0/emby-server-deb_3.3.0.0_amd64.deb dpkg -i emby-server-deb_3.3.0.0_amd64.deb rm emby-server-deb_3.3.0.0_amd64.deb To remove: apt remove emby-server Or to clean up all config files too: apt remove --purge emby-server Edited February 25, 2018 by ellnic 1
hoppel118 37 Posted February 25, 2018 Posted February 25, 2018 Docker is not very complicated under omv. 1. activate the docker ce repo under "OMV-Extras": 2. install openmediavault-docker-gui from "Plugins": 3. pull the emby image under "Docker - Docker images repo": 4. run the image and configure your container settings: I configured my container the following way: Greetings Hoppel 4
/Ky 3 Posted February 25, 2018 Posted February 25, 2018 (edited) Noted, I tend to piddle around quite a bit in the command line anyway and use OMV to simplify a lot of the mundane/time consuming day to day tasks. I'll check my Emby server later. That'll be why I can't find it! So I stand corrected about it being updated regularly. Most stuff is to be fair - but I guess with the docker it was easier to let people use that. No point doubling efforts. @@/Ky I would use the .deb if you are ok with the command line. To install: wget https://github.com/MediaBrowser/Emby/releases/download/3.3.0.0/emby-server-deb_3.3.0.0_amd64.deb dpkg -i emby-server-deb_3.3.0.0_amd64.deb rm emby-server-deb_3.3.0.0_amd64.deb To remove: apt remove emby-server Or to clean up all config files too: apt remove --purge emby-server Awesome thanks, that was the command I was looking for it's all coming back now lol. I'll take a look when I get the time. Thanks hoppel - I'll take a look at that too. Looks like I'll go with the .deb package install seems the better way for me. Just a quick side not as it wont be integrated into OMV as such how will I enter credentials when Emby attempts to access my shares (will it ask for credentials?) Edited February 25, 2018 by /Ky 2
ellnic 26 Posted February 25, 2018 Posted February 25, 2018 On a side note, isn't this a bit slow for AWS? 1
/Ky 3 Posted February 25, 2018 Posted February 25, 2018 Gonna have a play tomorrow if I get time after work as ready for bed now .
arkim 1 Posted March 3, 2018 Posted March 3, 2018 Docker is not very complicated under omv. 1. activate the docker ce repo under "OMV-Extras": Bildschirmfoto 2018-02-25 um 21.24.34.png 2. install openmediavault-docker-gui from "Plugins": Bildschirmfoto 2018-02-25 um 21.28.02.png 3. pull the emby image under "Docker - Docker images repo": Bildschirmfoto 2018-02-25 um 21.33.06.png 4. run the image and configure your container settings: Bildschirmfoto 2018-02-25 um 21.37.23.png I configured my container the following way: Bildschirmfoto 2018-02-25 um 21.39.27.png Bildschirmfoto 2018-02-25 um 21.47.54.png Bildschirmfoto 2018-02-25 um 21.48.26.png Greetings Hoppel Thanx a lot to you, it Works very good !! 1
jakotaki007 0 Posted July 27, 2018 Posted July 27, 2018 Hi guys, There is any person here using emby container in docker and reverse proxy on OMV? I'm trying to setup but nothing work as i'd like to work or maybe I'm approaching it from a different side. For now i have my server OMV working with domain buyed form namecheap. I used letsencrypt to generate certificate to my omv domain and have A+ grade from https://securityheaders.io/ For now i have some questions: 1. Do I have to do some subdomains for example emby.x.com to reverse proxy work or only have x.com with my certificate from letsencrypt? 2. If i must have some subdomain what should i setup in dns in namecheap? Record A? Cname? I'm trying to use this guide https://emby.media/community/index.php?/topic/47508-how-to-nginx-reverse-proxy/ but for now i have only errors. Best regards Jako
jakotaki007 0 Posted July 28, 2018 Posted July 28, 2018 (edited) Hi, I have expressed myself badly:) It's won't work for me without any erros or something like that. So i'm, looking for a person who has tihs system and using emby docker container and would share its settings or help me with setting this up. I'm using OMV 4.x Best regards Edited July 28, 2018 by jakotaki007
hoppel118 37 Posted July 29, 2018 Posted July 29, 2018 Hi, I have expressed myself badly:) It's won't work for me without any erros or something like that. So i'm, looking for a person who has tihs system and using emby docker container and would share its settings or help me with setting this up. I'm using OMV 4.x Best regards Hi, can’t help you with reverse proxy, but maybe you also need to configure the emby docker container. Have a look at the following post: https://emby.media/community/index.php?/topic/13117-openmediavault/page-9&do=findComment&comment=549283 Regards Hoppel
indyjones 3 Posted September 23, 2019 Posted September 23, 2019 Hi all, I was not sure if to post this here or instead on the OMV site. I am running emby 4.2.1.0 inside the docker within the latest build of OMV. The problem I am having is after the initial setup everything works fine for a while and a a day or so later, emby will not connect to the internet. I get check for application updates failed (and plugins) and it will not connect to the media sites to scrape images, (error code below). Does anybody have a clue please? OMV still has internet connectivity. No such device or address at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at MediaBrowser.Common.Updates.GithubUpdater.CheckForUpdateResult(String organzation, String repository, Version minVersion, PackageVersionClass updateLevel, String assetFilename, String packageName, String targetFilename, TimeSpan cacheLength, CancellationToken cancellationToken) at Emby.Server.Implementations.ApplicationHost.CheckForApplicationUpdate(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.SystemUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options)
Luke 42242 Posted September 23, 2019 Author Posted September 23, 2019 Hi all, I was not sure if to post this here or instead on the OMV site. I am running emby 4.2.1.0 inside the docker within the latest build of OMV. The problem I am having is after the initial setup everything works fine for a while and a a day or so later, emby will not connect to the internet. I get check for application updates failed (and plugins) and it will not connect to the media sites to scrape images, (error code below). Does anybody have a clue please? OMV still has internet connectivity. No such device or address at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at MediaBrowser.Common.Updates.GithubUpdater.CheckForUpdateResult(String organzation, String repository, Version minVersion, PackageVersionClass updateLevel, String assetFilename, String packageName, String targetFilename, TimeSpan cacheLength, CancellationToken cancellationToken) at Emby.Server.Implementations.ApplicationHost.CheckForApplicationUpdate(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.SystemUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) I believe this is an issue in the netcore runtime. We'll be updating to 3.0 soon, so let's keep an eye on it. Thanks.
Luke 42242 Posted September 24, 2019 Author Posted September 24, 2019 Thanks Luke, Is there a work around for the moment please? I don't really want to have to wipe emby everyone I add something to the library Restarting the server?
indyjones 3 Posted September 24, 2019 Posted September 24, 2019 Restarting the server? I wish it was that simple, either restarting emby, or cold rebooting both OMV and emby does not help. Update checks are failing and I cannot acquire metadata
Luke 42242 Posted September 24, 2019 Author Posted September 24, 2019 I wish it was that simple, either restarting emby, or cold rebooting both OMV and emby does not help. Update checks are failing and I cannot acquire metadata Ok then I think I was mistaken. I thought you had said this was a problem where initially the requests work fine and then after a period of time they stop working. If you're saying they're never working then i don't think that is a problem we can fix. That most likely means you need to configure the network connection in OMV/Docker or you may have something blocking the outgoing communications.
indyjones 3 Posted September 24, 2019 Posted September 24, 2019 To hopefully clarify, when I do a fresh install everything works fine I can even restart emby for plugin installs. Then after a day or so it stops working with the internet, restarting the server does not help, OMV can connect to the internet with no problems, and none of the settings have changed within docker. Fresh installing emby again still get it running again but no idea why it stops. I set all of the gods and uids up so it should not be access problems. Plus like I said it works perfectly initially.
Luke 42242 Posted September 24, 2019 Author Posted September 24, 2019 Have you tried rebooting the machine?
adamericson 0 Posted January 18, 2020 Posted January 18, 2020 Hello, I'm running Emby on OMV with a docker and a 3200g APU I'm struggling to get hardware transcoding to work and CPU only transcoding is to slow, I've looked at the links given here but sadly I’m a noob and can't get it to work. any help will be greatly appreciated.
