Luke 42242 Posted November 23, 2017 Author Posted November 23, 2017 @@DeepQuasar, please see my post above. Also please note, that when you change the settings inside Emby, it only applies to new metadata going forward. it will not move existing metadata.
DeepQuasar 2 Posted November 23, 2017 Posted November 23, 2017 @@DeepQuasar, please see my post above. Also please note, that when you change the settings inside Emby, it only applies to new metadata going forward. it will not move existing metadata. I had enabled this setting earlier the files keep getting moved into the config folder even with new content.
hoppel118 37 Posted November 23, 2017 Posted November 23, 2017 (edited) @@DeepQuasar Try this: http://forum.openmediavault.org/index.php/Thread/11243-Emby-spielt-keine-Videos-ab-zeigt-keine-Bilder-an/?postID=96520#post96520 and show us the output of the following command: ls -n /path/to/your/media/folderWe only need to see the "uid gid" and not all content of your folder. But the „uid gid“ should be the same for all of your media folders. The same values (at least the same gid) should be configured in your docker variables (APP_UID / APP_GID). Greetings Hoppel Edited November 23, 2017 by hoppel118
DeepQuasar 2 Posted November 23, 2017 Posted November 23, 2017 (edited) @@DeepQuasar Try this: http://forum.openmediavault.org/index.php/Thread/11243-Emby-spielt-keine-Videos-ab-zeigt-keine-Bilder-an/?postID=96520#post96520 and show us the output of the following command: ls -n /path/to/your/media/folder I only need to see the "uid gid" and not all content of your folder. The same values should be configured in your docker variables (APP_UID / APP_GID). Greetings Hoppel I found out what the problem was every time I change my config to 1002 in modify emby kicks pack to 1000 permission. With all my other dockers I use ID 1002. Does emby need to use 1000 because everytime I change it to 1002 it changes back to 1000. emby config:drwxr-sr-x 1 1000 1000 media:drwxrwsr-x+ 1 1002 1002 Edited November 23, 2017 by DeepQuasar
hoppel118 37 Posted November 23, 2017 Posted November 23, 2017 Ok, so is the problem solved for you or do you think that there is a bug? My media user has uid:1000 and gid:1000. I never had a problem with that configuration.
Luke 42242 Posted November 24, 2017 Author Posted November 24, 2017 emby changes what back to 1000? 1
DeepQuasar 2 Posted November 24, 2017 Posted November 24, 2017 emby changes what back to 1000? It changes the permission back to 1000.
DeepQuasar 2 Posted November 24, 2017 Posted November 24, 2017 Ok, so is the problem solved for you or do you think that there is a bug? My media user has uid:1000 and gid:1000. I never had a problem with that configuration. No its not solved yet it might be a bug because I cant get the same permission for emby as my media share will try some more.
Luke 42242 Posted November 24, 2017 Author Posted November 24, 2017 It changes the permission back to 1000. permission of what? 1
DeepQuasar 2 Posted November 24, 2017 Posted November 24, 2017 permission of what? Permission for emby every time I change to 1002 for my ID it changes back to 1000.
hoppel118 37 Posted November 24, 2017 Posted November 24, 2017 (edited) Only the uid or only the gid or both for which files or folders? Please, show us a screenshot of your container config from the omv webui and the output of the following command: ln -n /path/to/your/media/folder Edited November 24, 2017 by hoppel118
DeepQuasar 2 Posted November 27, 2017 Posted November 27, 2017 Only the uid or only the gid or both for which files or folders? Please, show us a screenshot of your container config from the omv webui and the output of the following command: ln -n /path/to/your/media/folder Here is a image of my docker config https://s2.postimg.org/lzetcvzx5/Docker_image.png I tried using that command just kept getting hardlink not allowed. In the my config folder I need to change my permission to 1002 instead emby changes to 1000. This is how the config permission output of emby is: drwxrwsr-x+ 1 1000 1000 As an example with transmission docker this is the permission output: drwxrwsr-x+ 1 1002 1002.
DeepQuasar 2 Posted November 29, 2017 Posted November 29, 2017 I solved the issue now by getting the metadata into the media folders by using a different emby docker. It becomes a fundamental problem with the offical emby docker when 1000 is added as permission by default to both PUID & PGID. 1
mika91 0 Posted January 21, 2018 Posted January 21, 2018 Hi, Is Emby capable of hardware transcoding (vaapi or intel quicksync) on OMV 3.x (based on Debian Jessie kernel) ? Using native plugin or docker image ? Thanks
Luke 42242 Posted January 21, 2018 Author Posted January 21, 2018 Hi, Is Emby capable of hardware transcoding (vaapi or intel quicksync) on OMV 3.x (based on Debian Jessie kernel) ? Using native plugin or docker image ? Thanks @@mika91, our Docker image includes VAAPI.
mika91 0 Posted January 21, 2018 Posted January 21, 2018 @@mika91, our Docker image includes VAAPI. Awesome!
/Ky 3 Posted February 25, 2018 Posted February 25, 2018 Hi, Okay looking at installing Emby Server on my NAS running OMV and just wondered whats the best way to install it? Is it via the offical plugin, docker or by using the Debian DEB package, just wondering which would be my best bet. Thanks.
ellnic 26 Posted February 25, 2018 Posted February 25, 2018 (edited) What do you mean by ‘best bet’? All methods give you Emby. It’s not like betting on a horse race ;-) there is no ‘best’ way to install. There are just several options for you to choose. Unless you mean the easiest? If you have OMV, the plugin via the web UI would be easiest to install/manage and ryecoaaron at OMV keeps the plugins nicely up to date. Sent from my iPhone using Tapatalk Edited February 25, 2018 by ellnic
/Ky 3 Posted February 25, 2018 Posted February 25, 2018 (edited) I mean by in terms of performance and up-to-date'ness as yeah I was looking at the OMV-Extras way but does that get updated regularly or are the updates direct from Emby? -On a side note in OMV I have my HDD's set to spool down after 60min of inactivity just wondering Emby wont interfere with this will it and cause them to spool up randomly when nothing is requested just wondering as I have tested out Emby on my PC and I noticed there was an option to enable realtime mionitoring of my libary and this seems a cool feature if I enable it but any ideas if this would spool up my HDD's or prevent them from sleeping? Edited February 25, 2018 by /Ky
ellnic 26 Posted February 25, 2018 Posted February 25, 2018 (edited) The HDDs will spin up whenever something needs to access them, so don’t worry about that. That’s a system setting, not related to any app/service. They’ll always spin up whenever something requests data on them. The OMV plugin is updated regularly. I wouldn’t worry about being left in the dust of the past. Unless a version increase drastically improves performance, there won’t be a different. Version 1 of Emby via OMV plugin will be the same as version 1 of Emby via official Emby repo, and version 2 will be the same etc. However, if you want updates literally as soon as the Emby guys release them (but you’re not looking at more than a day or so I would imagine) then use the Debian repo the Emby guys provide. But the last time I checked the OMV plugin was always close in tow. Sent from my iPhone using Tapatalk Edited February 25, 2018 by ellnic
Luke 42242 Posted February 25, 2018 Author Posted February 25, 2018 Anyone know what the omv plugin is based on? Can someone provide an emby server log? Thanks.
/Ky 3 Posted February 25, 2018 Posted February 25, 2018 The HDDs will spin up whenever something needs to access them, so don’t worry about that. That’s a system setting, not related to any app/service. They’ll always spin up whenever something requests data on them. The OMV plugin is updated regularly. I wouldn’t worry about being left in the dust of the past. Unless a version increase drastically improves performance, there won’t be a different. Version 1 of Emby via OMV plugin will be the same as version 1 of Emby via official Emby repo, and version 2 will be the same etc. However, if you want updates literally as soon as the Emby guys release them (but you’re not looking at more than a day or so I would imagine) then use the Debian repo the Emby guys provide. But the last time I checked the OMV plugin was always close in tow. Sent from my iPhone using Tapatalk Thank you for the info I'll look at using the offical addon then and yeah I just didnt know if Emby had any services running that would spool up my drives randomly.
ellnic 26 Posted February 25, 2018 Posted February 25, 2018 Anyone know what the omv plugin is based on? Can someone provide an emby server log? Thanks. Will check for you. Thank you for the info I'll look at using the offical addon then and yeah I just didnt know if Emby had any services running that would spool up my drives randomly. I don’t think so, but if Emby does this - it won’t matter how you install it. Sent from my iPhone using Tapatalk
ellnic 26 Posted February 25, 2018 Posted February 25, 2018 @@Luke, sorry will have to correct myself, can’t check until later as all my OMVs are on Stretch now (OMV 4), which is still very young. OMV 3 is still the recommended version for maximum plugin compatibility so Emby isn’t in the 4 repos yet (I use your repos). I have OMV 3 in a VM though, so will check for you later.
Luke 42242 Posted February 25, 2018 Author Posted February 25, 2018 If you see mono near the top of the log then that means it is based on our legacy package and I would instead use either the .Deb or docker.
