podonnell 48 Posted August 9, 2024 Posted August 9, 2024 Received the error Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. when I was attempting to delete a folder within a library. I had moved the library down one child folder path. Here is my server log for when the error appeared. My library looks fine now, and only monitors the single folder I want it to. However, are there any lingering issues I should be aware of? Trying not to have a corrupt database or such. Thanks. errors.txt
Happy2Play 9814 Posted August 9, 2024 Posted August 9, 2024 You may have broke the db adding child library and parent libraries. 2024-08-08 22:25:16.917 Info LibraryMonitor: S:\CIPHER\Other\LG 4k is already being watched by watcher for S:\CIPHER\Other. Adding item 6332 2024-08-08 22:25:16.926 Info App: Sqlite: 787 - abort at 36 in [insert or ignore into ItemLinks2 (ItemId, Type, LinkedId, LinkOrder) values (6330,8,6332,0)]: FOREIGN KEY constraint failed 2024-08-08 22:25:16.964 Error SqliteItemRepository: Error saving items *** Error Report *** Version: 4.8.8.0 Command line: Desktop\emby\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19045 Framework: .NET 6.0.30 OS/Process: x64/x64 Runtime: C:/Users/Pat/Desktop/emby/system/System.Private.CoreLib.dll Processor count: 8 Data path: Desktop\emby\programdata Application path: Desktop\emby\system SQLitePCL.pretty.SQLiteException: Constraint: FOREIGN KEY constraint failed SQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. at SQLitePCL.pretty.SQLiteException.CheckOk(sqlite3 db, Int32 rc) at SQLitePCL.pretty.StatementImpl.MoveNext() at SQLitePCL.pretty.DatabaseConnection.Execute(IDatabaseConnection This, String sql) at Emby.Server.Implementations.Data.SqliteItemRepository.SaveItemsInTranscation(IDatabaseConnection db, List`1 tuples, MetadataRefreshOptions metadataRefreshOptions) at Emby.Server.Implementations.Data.SqliteItemRepository.SaveItems(List`1 items, MetadataRefreshOptions metadataRefreshOptions, Action`1 afterSave, Boolean disableForeignKeys, CancellationToken cancellationToken) Source: SQLitePCL.pretty TargetSite: Void CheckOk(SQLitePCLEx.sqlite3, Int32) But the same a other topics sometime removing libraries works and other have to create a new db. Dev needs to make this not possible or a Big warning that you many break your install.
podonnell 48 Posted August 9, 2024 Author Posted August 9, 2024 11 hours ago, Happy2Play said: You may have broke the db adding child library and parent libraries. 2024-08-08 22:25:16.917 Info LibraryMonitor: S:\CIPHER\Other\LG 4k is already being watched by watcher for S:\CIPHER\Other. Adding item 6332 2024-08-08 22:25:16.926 Info App: Sqlite: 787 - abort at 36 in [insert or ignore into ItemLinks2 (ItemId, Type, LinkedId, LinkOrder) values (6330,8,6332,0)]: FOREIGN KEY constraint failed 2024-08-08 22:25:16.964 Error SqliteItemRepository: Error saving items *** Error Report *** Version: 4.8.8.0 Command line: Desktop\emby\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19045 Framework: .NET 6.0.30 OS/Process: x64/x64 Runtime: C:/Users/Pat/Desktop/emby/system/System.Private.CoreLib.dll Processor count: 8 Data path: Desktop\emby\programdata Application path: Desktop\emby\system SQLitePCL.pretty.SQLiteException: Constraint: FOREIGN KEY constraint failed SQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. at SQLitePCL.pretty.SQLiteException.CheckOk(sqlite3 db, Int32 rc) at SQLitePCL.pretty.StatementImpl.MoveNext() at SQLitePCL.pretty.DatabaseConnection.Execute(IDatabaseConnection This, String sql) at Emby.Server.Implementations.Data.SqliteItemRepository.SaveItemsInTranscation(IDatabaseConnection db, List`1 tuples, MetadataRefreshOptions metadataRefreshOptions) at Emby.Server.Implementations.Data.SqliteItemRepository.SaveItems(List`1 items, MetadataRefreshOptions metadataRefreshOptions, Action`1 afterSave, Boolean disableForeignKeys, CancellationToken cancellationToken) Source: SQLitePCL.pretty TargetSite: Void CheckOk(SQLitePCLEx.sqlite3, Int32) But the same a other topics sometime removing libraries works and other have to create a new db. Dev needs to make this not possible or a Big warning that you many break your install. What can I do to troubleshoot further? Emby is working perfectly well today. 1
Luke 42287 Posted August 9, 2024 Posted August 9, 2024 Hi, please see this topic for more info: Thanks.
