xiaolulu 4 Posted August 8, 2024 Posted August 8, 2024 There are two audios in the episode, one in Chinese and one in English, both named AAC. I need to use Chinese when playing, but I can't change it uniformly, I can only change it manually when playing. This is too troublesome. It's okay for adults, but it's impossible for children. I think this is obviously a functional defect. After so many versions, this defect has not been solved.
Happy2Play 9798 Posted August 8, 2024 Posted August 8, 2024 Not positive if per client or global per user setting but what is your Playback Audio setting?
xiaolulu 4 Posted August 8, 2024 Author Posted August 8, 2024 21 minutes ago, Happy2Play said: Not positive if per client or global per user setting but what is your Playback Audio setting? chinese simplified,But my video audio track does not have Chinese simplified, the name is aac
GrimReaper 4843 Posted August 8, 2024 Posted August 8, 2024 (edited) 3 hours ago, xiaolulu said: one in Chinese and one in English, both named AAC. 2 hours ago, xiaolulu said: audio track does not have Chinese simplified, the name is aac AAC is not a name but codec and has nothing to do with localization/language. 3 hours ago, xiaolulu said: this is obviously a functional defect. It is not, as you need to mark your audio track(s) with appropriate laguage(s) or flag preferred track as Default. Edited August 8, 2024 by GrimReaper 1
