Happy2Play 9814 Posted August 24, 2024 Posted August 24, 2024 5 minutes ago, Luke said: Did you try deleting the cached data? Yes only way I can get Alternate Title is TVDB then TMDB. If any other way English Title is used in my tests.
Luke 42288 Posted August 25, 2024 Posted August 25, 2024 2 hours ago, Happy2Play said: Yes only way I can get Alternate Title is TVDB then TMDB. If any other way English Title is used in my tests. With my language set to zh-cn, and only tvdb, i get a non-english title. do you?
Luke 42288 Posted August 25, 2024 Posted August 25, 2024 Even though the zh-cn title on the movie db website might be empty, it is coming out of their api as "Severance". Therefore there is no way to fallback to something else because they are telling us what the title should be. Not an issue with tvdb though.
Happy2Play 9814 Posted August 25, 2024 Posted August 25, 2024 5 minutes ago, Luke said: With my language set to zh-cn, and only tvdb, i get a non-english title. do you? Yes from a TVDB standpoint there is a zh-cn assume they can use TVDB. I see you just commented so the Alternate Title query info is not used at all?
Happy2Play 9814 Posted August 25, 2024 Posted August 25, 2024 But I guess as you mentioned a value is returned via zh-cn so there is no way to know it is an incorrect value to fallback to something else. So if the value was blank it would be do able. So a defect in the way TMDB is handling Name as it should be blank per translation page. A issue should be raise with TMDB about why their api returns a name for zh-cn if site does not show one.
Luke 42288 Posted August 25, 2024 Posted August 25, 2024 1 hour ago, Happy2Play said: Yes from a TVDB standpoint there is a zh-cn assume they can use TVDB. I see you just commented so the Alternate Title query info is not used at all? Well how would we know when to use it? If they left the name field empty then that would be one way, but they're not doing that.
Luke 42288 Posted August 25, 2024 Posted August 25, 2024 52 minutes ago, Happy2Play said: But I guess as you mentioned a value is returned via zh-cn so there is no way to know it is an incorrect value to fallback to something else. So if the value was blank it would be do able. So a defect in the way TMDB is handling Name as it should be blank per translation page. A issue should be raise with TMDB about why their api returns a name for zh-cn if site does not show one. Their website is most likely making it's own direct calls to their database and not using the api.
Happy2Play 9814 Posted August 25, 2024 Posted August 25, 2024 (edited) Yes mismatching information doesn't help but since info is returned by default there is nothing that can be done on Emby side. Edited August 25, 2024 by Happy2Play 1
