netzkapitaen 0 Posted August 7, 2024 Posted August 7, 2024 (edited) Hi Leute, ich habe mir heute Casa OS installiert und wollte nun vollumfänglich emby nutzen. Nach der Einrichtung habe ich aber bemerkt das die mp4 Dateien erkannt werden ohne Probleme, jedoch die mkv Dateien nicht. Die werden nicht mal dargestellt. So, als ob es sie einfach nicht gebe. Codecs sind installiert. Sowohl ffmpeg und vlc. Also daran kann es nicht liegen. Doch wo ist das Problem nun? Ich bin echt ratlos. Achso ja, ich habe ein ThinkCentre M710Q Core i3 7Gen. mit 16GB RAM. Edited August 7, 2024 by netzkapitaen
Luke 42239 Posted August 7, 2024 Posted August 7, 2024 Hi there, can you please provide a specific example? Thanks.
netzkapitaen 0 Posted August 7, 2024 Author Posted August 7, 2024 I installed emby on Linux Debian 12. I added the folder with the MKV files to Emby and let it search the library. But it only found mp4. That's weird. Because that just didn't work. I installed Ubuntu with Desktop and emby here too. On the desktop it plays the mkv without any problems. On emby after adding it, it only found mp4 files from the folder that you can play, but no mkv files. As if it doesn't see mkv files at all. The same thing with Linux Mint. All codecs installed. So vlc and ffmpeg. And already done 10 new installations. Still nothing.
Luke 42239 Posted August 14, 2024 Posted August 14, 2024 On 8/7/2024 at 4:45 PM, netzkapitaen said: I installed emby on Linux Debian 12. I added the folder with the MKV files to Emby and let it search the library. But it only found mp4. That's weird. Because that just didn't work. I installed Ubuntu with Desktop and emby here too. On the desktop it plays the mkv without any problems. On emby after adding it, it only found mp4 files from the folder that you can play, but no mkv files. As if it doesn't see mkv files at all. The same thing with Linux Mint. All codecs installed. So vlc and ffmpeg. And already done 10 new installations. Still nothing. Hi there, how are your files named and organized?
rogaven 11 Posted August 14, 2024 Posted August 14, 2024 Hab mal schnell nach CasaOS und Emby gegooglet: Dort ist das Thema wohl eingeschlafen. Läuft Emby denn ohne CasaOS?
Luke 42239 Posted August 16, 2024 Posted August 16, 2024 On 8/14/2024 at 6:29 AM, rogaven said: Hab mal schnell nach CasaOS und Emby gegooglet: Dort ist das Thema wohl eingeschlafen. Läuft Emby denn ohne CasaOS? @rogavenwhat do you mean when you say without CasaOS?
