vanespop 0 Posted August 5, 2024 Posted August 5, 2024 Bonjour, J'ai bien recu ma premier clé mais je n'arrive pas a trouver ou je doit la rentrer pour débuté mon abonnement J'ai bien lu les instruction mais je trouve pas le tableau Merci
Abobader 3484 Posted August 5, 2024 Posted August 5, 2024 Hello vanespop, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42184 Posted August 5, 2024 Posted August 5, 2024 Hi, please email billingsupport@emby.media Thanks !
Gilgamesh_48 1243 Posted August 5, 2024 Posted August 5, 2024 1 hour ago, vanespop said: Bonjour, J'ai bien recu ma premier clé mais je n'arrive pas a trouver ou je doit la rentrer pour débuté mon abonnement J'ai bien lu les instruction mais je trouve pas le tableau Merci I am going to answer in English because my French is weak. I hope that is OK. The premier key is entered in "settings" about four lines into the server section of the "settings" menu on your server. You just enter it there and you should be fully functional for all "premier" functions. Good Luck.
Vanesspop 0 Posted August 5, 2024 Posted August 5, 2024 Je vais retourner voir car jai rien trouver qui resemble a sa
pwhodges 2023 Posted August 5, 2024 Posted August 5, 2024 Are you running an Emby server? If not, then it was not appropriate for you to get a Premiere key. Note that Emby is a software supplier, not a streaming provider. Paul
