Webdoc 2 Posted July 31, 2024 Posted July 31, 2024 Hello, I'm noticing a problem with my emby server running in docker (Latest version) on fedora 40 server, Tv guide data is not auto updating via the task in emby, but it does work if I do it manually. I do have another emby server running on another machine but not in docker that seems to update fine. Any ideas? Thanks
Luke 42243 Posted July 31, 2024 Posted July 31, 2024 Hi there @Webdoc let’s look at a specific example of your issue: How to Report a Problem Thanks !
Webdoc 2 Posted August 1, 2024 Author Posted August 1, 2024 Hello, I don't know why the scheduled task which was set at on an interval every one day was not working, I had not touched this setting it was like it from entering TV data. I have now changed this setting to daily at 5:15 and now seems to be working as it should. Just thought I would let you know. Thanks again
Luke 42243 Posted August 1, 2024 Posted August 1, 2024 4 hours ago, Webdoc said: Hello, I don't know why the scheduled task which was set at on an interval every one day was not working, I had not touched this setting it was like it from entering TV data. I have now changed this setting to daily at 5:15 and now seems to be working as it should. Just thought I would let you know. Thanks again I would put it back to the interval. When you set it to every X hours, the server will guarantee that it runs. When you set it to a specific time, it becomes your responsibility to make sure your Emby Server is up and running at that specific time. If it's not, then it won't run.
