zenobit06 5 Posted August 1, 2024 Author Posted August 1, 2024 21 hours ago, GrimReaper said: "In the go menu in finder you can type ‘ ~/.config/Emby-server’ and it will take you to that hidden location" Thank you very much, this trick actually helped to find the hidden folder with the subfolder userplaylists, in which the Punk-Rock playlist (m3u format) that I created on emby is located. (screenshot 1) So I proceeded as @Luke and @Happy2Play recommended: 1. Exported a test playlist (name: Drum & Bass) with five songs from Apple Music in m3u format 2. Copied the playlist in a folder created for this purpose into the userplaylists folder. (screenshot 2) 3 Restarted emby server Result: the emby server only shows the Punk-Rock playlist that it created. The inserted playlist called Drum & Bass is not recognized. (screenshot 3)
Solution Happy2Play 9811 Posted August 1, 2024 Solution Posted August 1, 2024 4 hours ago, zenobit06 said: Thank you very much, this trick actually helped to find the hidden folder with the subfolder userplaylists, in which the Punk-Rock playlist (m3u format) that I created on emby is located. (screenshot 1) So I proceeded as @Luke and @Happy2Play recommended: 1. Exported a test playlist (name: Drum & Bass) with five songs from Apple Music in m3u format 2. Copied the playlist in a folder created for this purpose into the userplaylists folder. (screenshot 2) 3 Restarted emby server Result: the emby server only shows the Punk-Rock playlist that it created. The inserted playlist called Drum & Bass is not recognized. (screenshot 3) As I previously said only Emby created playlists can go into userplaylists as they are Emby user controlled via usershares in the database. You can edit existing Emby created playlists or dump your custom playlist into /data/playlists folder and will be visible to all Emby users. 1 1
Happy2Play 9811 Posted August 1, 2024 Posted August 1, 2024 Alternatively, you have the library import options and can dump your m3u into a folder within your music library also.
zenobit06 5 Posted August 1, 2024 Author Posted August 1, 2024 16 minutes ago, jaycedk said: Did you do a music library scan ? Yes, I did.
zenobit06 5 Posted August 1, 2024 Author Posted August 1, 2024 32 minutes ago, Happy2Play said: As I previously said only Emby created playlists can go into userplaylists as they are Emby user controlled via usershares in the database. You can edit existing Emby created playlists or dump your custom playlist into /data/playlists folder and will be visible to all Emby users. I did another test and copied three playlists (one with a folder, two without, one in m3u8 format and two in m3u format) into the playlist folder. After another library scan, all lists were recognized and can be played. PROBLEM SOLVED! Thank you for the great support! 2
Luke 42238 Posted August 1, 2024 Posted August 1, 2024 You can't copy playlist files into userplaylists. Those are user-specific, so although the server will scan it, no user will have access to see it. 1
