Hisma 15 Posted March 6, 2015 Posted March 6, 2015 well after trying out mb3 server on my windows VM, along with nextpvr live TV plugin, I decided to uninstall both and revert back to what I had before, my mb3 & mythtv jails. Didn't feel like I gained anything going the windows route... no difference at all on the windows version of mb3 server. and mythtv is superior to nextpvr for live tv (except for the web interface), I couldn't even get nextpvr to work in mb theater either. So sorry for the de-rail earlier. freenas pluginis is definitely awesome .
bluemonkey07 590 Posted April 1, 2015 Posted April 1, 2015 Any idea when this will be updated to the latest stable version?
josh4trunks 70 Posted April 1, 2015 Posted April 1, 2015 (edited) I should have the emby plugin available in a few days. updates from the mediabrowser plugin might not be straight forward, but I'll see what I can do. Edited April 1, 2015 by josh4trunks 1
Baenwort 119 Posted April 4, 2015 Posted April 4, 2015 Thank you Josh, is there anything the community can do to help?
josh4trunks 70 Posted April 4, 2015 Posted April 4, 2015 (edited) double post Edited April 4, 2015 by josh4trunks
josh4trunks 70 Posted April 4, 2015 Posted April 4, 2015 Thank you Josh, is there anything the community can do to help? Not at this time, but thanks for offering. I actually finished it yesterday but didn't post it cause there are a few bugs in the latest emby version. 1
bluemonkey07 590 Posted April 4, 2015 Posted April 4, 2015 So i believe the bug fix release is out now too;)
josh4trunks 70 Posted April 4, 2015 Posted April 4, 2015 (edited) So i believe the bug fix release is out now too;) Yup, I'll get the new plugin in the Repo tonight. I think the best course of action is to.. install the new emby plugin setup any storage mount points copy over your data-diectory, edit paths below as needed cp -r /mnt/tank/jails/mediabrowser_1/var/db/mediabrowser /mnt/tank/jails/emby_1/var/db/emby-server chown -R 989:989 /mnt/tank/jails/emby_1/var/db/emby-server delete mediabrowser plugin (optional) change IP of emby jail, restart jail enable emby plugin EDIT I tried this and it didn't work =[ It looks like some paths are hardcoded in one of the config or database files. So I don't know any way to migrate from mediabrowser to emby automatically at this time =[ Edited April 5, 2015 by josh4trunks
bluemonkey07 590 Posted April 4, 2015 Posted April 4, 2015 Why is this required ? Is it just because of the name change? Or some other reasons?
josh4trunks 70 Posted April 4, 2015 Posted April 4, 2015 (edited) Why is this required ? Is it just because of the name change? Or some other reasons? yeah, name change. The FreeNAS plugin system doesn't know how to update from one to another. Alternatively you could skip some of those steps if you are ok with your jail being named mediabrowser_1. stop mediabrowser plugin upload emby PBI to mediabrowser jail delete mediabrowser plugin start emby plugin EDIT I tried this and it didn't work =[ It looks like some paths are hardcoded in one of the config or database files. So I don't know any way to migrate from mediabrowser to emby automatically at this time =[ Edited April 5, 2015 by josh4trunks
bluemonkey07 590 Posted April 6, 2015 Posted April 6, 2015 OK I have manually migrated over... The only issue I am having ATM is the new dynamic thumbs.... They look great but for TV the tile is blank
josh4trunks 70 Posted April 6, 2015 Posted April 6, 2015 OK I have manually migrated over... The only issue I am having ATM is the new dynamic thumbs.... They look great but for TV the tile is blankyup I got the same issue. movie tile looks great though
josh4trunks 70 Posted April 6, 2015 Posted April 6, 2015 (edited) Yea it does:)..any idea as to a solution? Not sure. Do we know if this works on other operating systems? EDIT I just rescanned my library (playing around with other stuff) and the tv icon appeared. Edited April 6, 2015 by josh4trunks
warhead1999 0 Posted April 6, 2015 Posted April 6, 2015 (edited) hi guys looking to purchase a nas and install emby on it, is there a standard of nas i need to purchase? Edited April 6, 2015 by warhead1999
josh4trunks 70 Posted April 6, 2015 Posted April 6, 2015 hi guys looking to purchase a nas and install emby on it, is there a standard of nas i need to purchase? if you're talking about a freenas you either buy one pre-built from ixsystems or build one yourself. here's some hardware recommendationshttps://forums.freenas.org/index.php?threads/hardware-recommendations-read-this-first.23069/ 1
giga12 0 Posted April 6, 2015 Posted April 6, 2015 I see instructions on how to update emby on FreeNas but then I see "Edits" saying that it doesn't work right. Is there currently any working instructions that I can follow?
josh4trunks 70 Posted April 6, 2015 Posted April 6, 2015 I see instructions on how to update emby on FreeNas but then I see "Edits" saying that it doesn't work right. Is there currently any working instructions that I can follow?currently there is no ideal way to migrate over. I might rebuild the plugin and post migration instructions in the future. If you don't want to wait then you'll need to setup Emby from scratch.
giga12 0 Posted April 6, 2015 Posted April 6, 2015 currently there is no ideal way to migrate over. I might rebuild the plugin and post migration instructions in the future. If you don't want to wait then you'll need to setup Emby from scratch. I am having audio issues, (audio goes out for about a second every 10-15 minutes), and I just wanted to eliminate it as a software issue. I don't really think it is though, so i'll wait. Thanks for the swift response.
bluemonkey07 590 Posted April 6, 2015 Posted April 6, 2015 (edited) I don't know if the config backup plugin for emby/MBS is of any help in migrating, but could be worth a shot Edited April 6, 2015 by Vidman
josh4trunks 70 Posted April 7, 2015 Posted April 7, 2015 (edited) @@giga12 I posted a minor revision to the Emby plugin in the FreeNAS Repo, version 3.0.5572.0_1. It should be available tomorrow. Here's migration steps that should work after tomorrow Install Emby copy over your data-directory, edit paths below as needed cp -r /mnt/tank/jails/mediabrowser_1/var/db/mediabrowser /mnt/tank/jails/emby_1/var/db/mediabrowser chown -R 989:989 /mnt/tank/jails/emby_1/var/db/mediabrowser delete the mediabrowser plugin (optional) change IP of emby jail, restart jail set data-directory in emby jail sysrc 'emby_server_data_dir=/var/db/mediabrowser' enable emby plugin Edited April 7, 2015 by josh4trunks 1
Baenwort 119 Posted April 8, 2015 Posted April 8, 2015 @@giga12 I posted a minor revision to the Emby plugin in the FreeNAS Repo, version 3.0.5572.0_1. It should be available tomorrow. Here's migration steps that should work after tomorrow Install Emby copy over your data-directory, edit paths below as needed cp -r /mnt/tank/jails/mediabrowser_1/var/db/mediabrowser /mnt/tank/jails/emby_1/var/db/mediabrowser chown -R 989:989 /mnt/tank/jails/emby_1/var/db/mediabrowser delete the mediabrowser plugin (optional) change IP of emby jail, restart jail set data-directory in emby jail sysrc 'emby_server_data_dir=/var/db/mediabrowser' enable emby plugin Is the User ID used inside the jail still 989 and "mediabrowser"? I had to create a FreeNAS user account when I setup MBS due to saving the metadata with the media so that the permissions would work correctly. FreeNAS recommends that jail UIDs be >1001 (typically you use the same ID# as the jail port number but it isn't a forced requirement) and I'm wondering if when you did the move if you changed the UID to conform to the FreeNAS system?
josh4trunks 70 Posted April 8, 2015 Posted April 8, 2015 Is the User ID used inside the jail still 989 and "mediabrowser"? I had to create a FreeNAS user account when I setup MBS due to saving the metadata with the media so that the permissions would work correctly. FreeNAS recommends that jail UIDs be >1001 (typically you use the same ID# as the jail port number but it isn't a forced requirement) and I'm wondering if when you did the move if you changed the UID to conform to the FreeNAS system? yes, this plugin well by default still use UID 989, but no, the user created in the jail is named "emby". I have never read what you are saying about port numbers corresponding with UIDs. This sounds like something you are misunderstanding. UIDs <1000 are supposed to be reserved for users registered by ports, of which the emby user is registered to 989. port numbers are completely unrelated. 1
Baenwort 119 Posted April 8, 2015 Posted April 8, 2015 yes, this plugin well by default still use UID 989, but no, the user created in the jail is named "emby". I have never read what you are saying about port numbers corresponding with UIDs. This sounds like something you are misunderstanding. UIDs <1000 are supposed to be reserved for users registered by ports, of which the emby user is registered to 989. port numbers are completely unrelated. You are likely correct as I'm not inside the Dev community of FreeNAS. However, the other plugins that I use all use UIDs that corrispond to their port numbers. This is consistent with the UserID Description at: http://doc.freenas.org/9.3/freenas_account.html#users "greyed out if user already created; when creating an account, the next numeric ID will be suggested; by convention, user accounts have an ID greater than 1000 and system accounts have an ID equal to the default port number used by the service" But all that really matters is that it is a known value to those of us who want to store the metadata locally. It isn't difficult to setup once it is known.
