zandr 4 Posted February 23, 2020 Posted February 23, 2020 The FreeNAS plugin is still sitting at 4.2.1.0.The 'official' iocage pulls packages from http://pkg.cdn.trueos.org/iocage/unstable/ which doesn't look like it's been touched since 10 December. Has anyone looked at moving over to the community side? 1
Eddie 12 Posted February 23, 2020 Posted February 23, 2020 dont know if this will make much of a difference but according to the developers they are working on a freenas with a linux base https://www.reddit.com/r/freenas/comments/e21l6g/freenas_plans_2020_and_beyond/ hopefully we wont have to deal with plugins anymore and just use docker in the future 1
Luke 42237 Posted February 23, 2020 Author Posted February 23, 2020 dont know if this will make much of a difference but according to the developers they are working on a freenas with a linux base https://www.reddit.com/r/freenas/comments/e21l6g/freenas_plans_2020_and_beyond/ hopefully we wont have to deal with plugins anymore and just use docker in the future Well that would be fantastic.
Eddie 12 Posted February 25, 2020 Posted February 25, 2020 Do you know that for certain or just guessing?
eraser8 55 Posted February 25, 2020 Posted February 25, 2020 (edited) The package is so easy to update/install with "pkg add -f" that I don't see the real need to give effort on the freenas plugin. Just my opinion! The guy (or girl) who decide to install freenas should "normally" be able to use some command in iocage.... If not, they should learn it or return in windows Edited February 25, 2020 by eraser8
zandr 4 Posted February 26, 2020 Posted February 26, 2020 The guy (or girl) who decide to install freenas should "normally" be able to use some command in iocage.... If not, they should learn it or return in windows Ah, GIFT rears its head again. I'll probably end up recreating the iocage plugin, as there isn't much to it, and it does integrate nicely with the FreeNAS UI if it can identify the management interface. That's most of the point of the plugin. 1
zandr 4 Posted March 1, 2020 Posted March 1, 2020 (edited) For anyone else running FreeNAS who would like to run directly from the FreeBSD Package repository instead of the TrueOS repo, here's a manifest file.All I've changed is the repo URL and fingerprint, and switched to DHCP for the jail network interface. Nothing in the artifact needed to change, so I've left the manifest pointing at the FreeNAS artifact repo. { "name": "Emby", "release": "11.3-RELEASE", "artifact": "https://github.com/freenas/iocage-plugin-emby.git", "properties": { "dhcp": 1 }, "pkgs": [ "emby-server", "ffmpeg" ], "packagesite": "http://pkg.FreeBSD.org/FreeBSD:11:amd64/latest", "fingerprints": { "iocage-plugins": [ { "function": "sha256", "fingerprint": "b0170035af3acc5f3f3ae1859dc717101b4e6c1d0a794ad554928ca0cbb2f438" } ] }, "revision": "0", "official": false } Install with: sudo iocage fetch -P emby.json -Zandr Edited March 1, 2020 by zandr 1
wbravin 3 Posted March 12, 2020 Posted March 12, 2020 I am not sure whom you are replying too. However, I am quite sure i never said you need more understanding of linux in order to get emby running. I might have said that FreeNAS is a storage solution first and a VM solution second, so you need to figure some things out. Back to your problem. When i read problems with "cant see folder" i always think its a permission problem, because thats what my experience tells me. Typically it boils down to that emby is installed with the user UID 989 and GID 989 and the first user of freenas has the UID 1000 with the GID 1000, naturally your first user (if you are not inclined to deal with permissions) creates datasets and creates the movie folders and what not. When you mount these datasets they can not be seen from the emby side. There are two solutions that i can fathom. 1. Change the UID and GID the emby user is running as (easy requires 4 lines copy and paste in the emby shell) or. 2. Create a seperate user emby in freenas with UID:GID 989:989 that owns your media datasets. For 1. open the emby plugin shell and replace 1101 with the userid you want service emby-server stop pw groupmod emby -n emby -g 1101 pw usermod emby -n emby -u 1101 -g 1101 chown -R emby:emby /var/db/emby-server sysrc 'emby_server_user=emby' service emby-server start The 2nd. one is more involved with clicking through the GUI, I posted a simple terribly written pdf a day or so ago here https://emby.media/community/index.php?/topic/42569-freenas-emby-setup-guide/page-2&do=findComment&comment=794468 Most of these permission problems happen with all the plugins that need access to data, thats just the nature of the jail/freenas system and the option for the user to give each individual tool access to specific data. My personal data security is just terrible, as i am also just a click through the gui user so I have one user with the uid 1101 that does pretty much everything. hello @@makarai i seem to have issues with the 5th line of your code i tries to wright this in jail shell in freenas 11.3 are there quote involved thank you for responding
makarai 109 Posted March 13, 2020 Posted March 13, 2020 Hi @@wbravin sorry I have not been partaking in the conversation. I am only on the phone right now, did you replace 1101 with the userid that owns your media? I'll will read the thread tomorrow and see if I can help
wbravin 3 Posted March 13, 2020 Posted March 13, 2020 thank you for your reply yes i did By deleting the media and copy it back from my redundant server seamed to have resolved the problem. now i have a permission issue in my windows explorer. this will be my dilemma for tomorrow thank you
makarai 109 Posted March 15, 2020 Posted March 15, 2020 thank you for your reply yes i did By deleting the media and copy it back from my redundant server seamed to have resolved the problem. now i have a permission issue in my windows explorer. this will be my dilemma for tomorrow thank you Well, to be honest from your last reply you are having permission issues. The problem i see here is that you direct mount in freenas and use the standard freebsd permission scheme, when you share that same dataset to windows utilizing SMB typically the permissions will be changed. Long time ago i tried to deal with having two permission schemes in parallel, it never worked for me. So my solution is not mounting in windows and just installing a sftp program.
wbravin 3 Posted March 16, 2020 Posted March 16, 2020 thank you for your reply what is an sftp program would this add an additional complexity level? I like to keep things simple here is a copy (just for your information ) of a post i did on the freenas forum since the post below i copied and pasted from my redundant server my tv shows and now I see them. However i cannot load these file into the emby library. hello alli am totally frustrated with permission issues since upgrading to freenas 11.3. everything was working well in 11.2 u8. now the emby plugin did not work so i fix it. I must have screwed something up. what i do not know.preface;I have a user UID wbravin with full control who is part of gid wheel, wbravin, embyi have a user uid emby with full control who is part of gid wheel wbravin embymy pool datasets are owned by wbravinmy smd shares are owned by wbravinmy windows credentials are set for freenas to wbravini see my shares in windows explorer network freenass, media, then my shares music, document, movies and tv shows.for whatever reason in music documents and movies i can access the share and the sub folder and play the media. as it should behowever for tv shows i can see the tv show share i can see the sub folders but i cannot access the sub solder and play the media.it tells me that i need permission from freenas\root where do i change this?all permission for all share look the samewhat am i missing?on a more developed note I would like to know how to eliminate all permissions. I live alone and i am the only one who has access to the solution. hence i would like to access all with out login in.I tried to follow this thread and looked at the videos before doing this
hjason7812 35 Posted March 16, 2020 Posted March 16, 2020 thank you for your reply what is an sftp program would this add an additional complexity level? I like to keep things simple here is a copy (just for your information ) of a post i did on the freenas forum since the post below i copied and pasted from my redundant server my tv shows and now I see them. However i cannot load these file into the emby library. hello all[/size]i am totally frustrated with permission issues since upgrading to freenas 11.3. everything was working well in 11.2 u8. now the emby plugin did not work so i fix it. I must have screwed something up. what i do not know.[/size]preface;[/size]I have a user UID wbravin with full control who is part of gid wheel, wbravin, emby[/size]i have a user uid emby with full control who is part of gid wheel wbravin emby[/size]my pool datasets are owned by wbravin[/size]my smd shares are owned by wbravin[/size]my windows credentials are set for freenas to wbravin[/size]i see my shares in windows explorer network freenass, media, then my shares music, document, movies and tv shows.[/size]for whatever reason in music documents and movies i can access the share and the sub folder and play the media. as it should be[/size]however for tv shows i can see the tv show share i can see the sub folders but i cannot access the sub solder and play the media.[/size]it tells me that i need permission from freenas\root where do i change this?[/size]all permission for all share look the same[/size]what am i missing?[/size]on a more developed note I would like to know how to eliminate all permissions. I live alone and i am the only one who has access to the solution. hence i would like to access all with out login in.[/size]I tried to follow this thread and looked at the videos before doing this[/size] I had an issue with permissions too. All i did was go through everything and set all permissiins to nobody. Set everything from your pool, dataset, shares, emby, etc etc to nobody and save everything and restart then you should be ok after. I had to redo the permission every so often but i think it was a bug in freenas haven't had to mess with it the last 3 updates. Good luck
wbravin 3 Posted March 16, 2020 Posted March 16, 2020 Thank you all for your responses so far i deleted the tv shows on my main freenas box (where i had the problem) and copied and paste fro from my freenas2 (my backup server) and when folder to the tv library in emby I pointed it to the mapped drive in my windows machine and its working. It is in the middle of copying all the tv series and it still has 11 hours to go. Once this is complete I will try to change ownership to nobody with full control once again thank you for this
ddywz 2 Posted May 29, 2020 Posted May 29, 2020 Hello there. Was running Emby on my Ubuntu server for a long time and as we all get bored when things do work and would like to cause issues I decided to give FreeNAS a try. Well to make it short have installed everything ok and the backend looks healthy with the arsenal of plugins for sab, sonarr and radarr all in their jails. So far so good. I had to go through a hell with permissions in UNIX and have servers in jail talk to each other and datasets out of jail. but was determined to not switch to CIFS and use NFS only for this purpose. I'm now trying to setup Emby plugin from iXstystems collection. that shows to have emby version 4.4.2.0. Question? Is it recommended to install from iXsystems or from community? I tried the plugin from iXsystems and installed fine. Configured some paths for media but then needed to do too many changes to fit my environment so I decided to delete the plugin and start fresh. When I try to re-install the plugin I get this: I believe I had the source unmounted and the service was stopped when I deleted the plugin. It appears like is still remembering from the first install that the path to dataset is unmounted. Is there a fix for this? I don't see any traces of the previous installation in the jail or when I visit iocage, Rebooted everything but did not help. I'm running OS Version:FreeNAS-11.3-U3.1 Anyone has seen this?
MRobi 161 Posted May 31, 2020 Posted May 31, 2020 install from community. Instead of deleting the plugin and re-installing, destroy the jail and start from scratch. All you should have to do is install the plugin (which creates the jail), mount your storage and set permissions. And I see you're on 11.3 so permissions are now real simple. Check out this guide, you can apply it to all your plugins: https://emby.media/community/index.php?/topic/85123-setting-permissions-in-freenas-113/
ddywz 2 Posted May 31, 2020 Posted May 31, 2020 install from community. Instead of deleting the plugin and re-installing, destroy the jail and start from scratch. Thanks for the reply Mrobi.. Are you saying to destory all Jails and detete the dataset for iocage? I have 4 other Jails with other stuff that are working great. I don't see any jail for emby in particular. The only option to remove a plugin is by Deleting it. Is there another way or removing a plugin and re-installing it back if you wanted? Deleting the whole dataset for iocage for the sake of one plugin does not seem like a solution or fix for me.
MRobi 161 Posted May 31, 2020 Posted May 31, 2020 Thanks for the reply Mrobi.. Are you saying to destory all Jails and detete the dataset for iocage? I have 4 other Jails with other stuff that are working great. I don't see any jail for emby in particular. The only option to remove a plugin is by Deleting it. Is there another way or removing a plugin and re-installing it back if you wanted? Deleting the whole dataset for iocage for the sake of one plugin does not seem like a solution or fix for me. No, definitely don't destroy them all or the iocage dataset. In FreeNAS when you install a plugin it creates a jail. A jail isolates itself from every other part of the system (hence the name jail). You say it's still remembering settings from your previous install which would mean you likely deleted the plugin and re-installed it in the same jail. Instead, delete the jail (just your emby jail) and then re-install. I personally do it through shell using iocage destroy JAILNAMEHERE It can also be done in the GUI. Right below plugins you'll see jails. When you click on that you get a list of all your jails. If you click on the ">" to the right it will expand and you'll see the delete button. Delete any Emby jails you may have created, then go back to plugins and install via the community installer.
ddywz 2 Posted May 31, 2020 Posted May 31, 2020 Mrobi - that is what I did, I just deleted the jail for emby, (I called it mdserver). If I go on shell and do iocage list I see only the jails that I use and there is no trace of emby or mdserver jail that was created from the Emby plugin install. Yet when I go to install Emby plugin I get that error. I tried with CLI too.. Here is what I get:
MRobi 161 Posted June 2, 2020 Posted June 2, 2020 Mrobi - that is what I did, I just deleted the jail for emby, (I called it mdserver). If I go on shell and do iocage list I see only the jails that I use and there is no trace of emby or mdserver jail that was created from the Emby plugin install. Yet when I go to install Emby plugin I get that error. I tried with CLI too.. Here is what I get: Yup, from what I can see there, the emby jail is gone. You should be good for a clean install and there is no possible way for any traces of previous settings to be present.
ddywz 2 Posted June 3, 2020 Posted June 3, 2020 No, the error is still there. Although the jail for emby is gone the installation of the plugin still fails with that error. I'm unable to re-install the plugin again. Not sure what to do at this point.
MRobi 161 Posted June 3, 2020 Posted June 3, 2020 No, the error is still there. Although the jail for emby is gone the installation of the plugin still fails with that error. I'm unable to re-install the plugin again. Not sure what to do at this point. Are you able to SSH/SFTP into your FreeNAS server, browse to your iocage directory and see if there's a leftover directory in there? Usually it's stored in YOURDATASET/iocage/jails I use winscp or putty for this. It could be causing a conflict while trying to install. If that doesn't work we can probably walk you through a manual install instead of the plugins section
roshynet 0 Posted June 3, 2020 Posted June 3, 2020 hola, que tal, sou nuevo en el uso de Emby me agrada mucho, pero me tope con un problema, o quiza algo estoy haciendo mal, tengo emby en un plugin de freenas, funciona perfecto con las peliculas y videos, pero cuando coloco imagenes o fotografias en alguna de las carpetas, la imagenes no se muestran, aun dando clic en fotos, ojala y me pudieran ayudar.
