soloam 3 Posted December 6, 2018 Posted December 6, 2018 I used the one from the plugin section off freenas 11.2 (that was passed to stable today) what should I use?
makarai 109 Posted December 6, 2018 Posted December 6, 2018 I used the one from the plugin section off freenas 11.2 (that was passed to stable today) what should I use? Go to this https://emby.media/community/index.php?/topic/60971-new-freenas-package-for-testing/page-7&do=findComment&comment=619899 And read the post
makarai 109 Posted December 6, 2018 Posted December 6, 2018 On my mobilephone sorry for being so short with you
makarai 109 Posted December 9, 2018 Posted December 9, 2018 (edited) @@Luke At present the Emby-Server Stable 5.3.5.0 will not properly install on Freenas-Stable release a couple of days ago. https://www.freenas....-2-has-arrived/ The reason seems to be the FreeBSD version used in your installation json (11.1_p11) if changed to 11.2 the installation functions properly! Secondly could you create a beta branch on your repository and change it to whatever i have so you could have a stable version installation on your repo and a beta version installation via iocage fetch -P dhcp=on vnet=on bpf=yes allow_raw_sockets=1 -n emby-server.json --branch 'master' # or iocage fetch -P dhcp=on vnet=on bpf=yes allow_raw_sockets=1 -n emby-server-beta.json --branch 'beta' Edited January 6, 2019 by makarai 1
Eddie 12 Posted February 19, 2019 Posted February 19, 2019 I have not had success using emby on freenas 11.2 for a while so i have been using a second computer with ubuntu on it running great... Today i updated my FreeNAS 11.2-U2 and tried the instructions mentioned by @@makarai and got this error Any ideas? root@freenas:~ # cd /tmp root@freenas:/tmp # wget https://raw.githubusercontent.com/bott0r/iocage-plugin-emby/master/emby-server.json --2019-02-18 23:32:57-- https://raw.githubusercontent.com/bott0r/iocage-plugin-emby/master/emby-server.json Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 199.232.32.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|199.232.32.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 798 [text/plain] Saving to: ‘emby-server.json’ emby-server.json 100%[==================================================================================================================================================================>] 798 --.-KB/s in 0s 2019-02-18 23:32:57 (91.6 MB/s) - ‘emby-server.json’ saved [798/798] root@freenas:/tmp # iocage fetch -P dhcp=on vnet=on bpf=yes allow_raw_sockets=1 -n emby-server.json --branch 'master' Plugin: emby-server Official Plugin: False Using RELEASE: 11.2-RELEASE Using Branch: master Post-install Artifact: https://github.com/bott0r/iocage-plugin-emby.git These pkgs will be installed: - lang/mono - multimedia/libass - x11-fonts/fontconfig - print/freetype2 - converters/fribidi - security/gnutls - converters/iconv - audio/opus - net/samba48 - databases/sqlite3 - multimedia/libtheora - multimedia/libva - audio/libvorbis - graphics/webp - multimedia/libx264 - graphics/libraw - devel/libzvbi Exception: UnboundLocalError:local variable 'bridge_cmd' referenced before assignment occured, destroyed emby-server. root@freenas:/tmp #
makarai 109 Posted February 19, 2019 Posted February 19, 2019 (edited) Hey @@Eddie, I have not yet update to U2, will do so soon. In the mean time could you: install the irrsi from the plugin catalog and check if that properly installs. (leave it installed, for the time being) send me the print out from ifconfig try installing Emby in a jail from scratch: codebox Create an empty jail -> use GUI and enter jail shell #enter the jail shell pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi libraw pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.0.2.0/emby-server-freebsd_4.0.2.0_amd64.txz sysrc -f /etc/rc.conf emby_server_enable="YES" service emby-server start 2>/dev/null restart jail Edited February 19, 2019 by makarai
hjason7812 35 Posted February 19, 2019 Posted February 19, 2019 Looks like he's having the same issue i had. I had to reset the network settings from the freenas console ( direct from freenas server via monitor)
Eddie 12 Posted February 19, 2019 Posted February 19, 2019 @@hjason7812 Freenas is accessible on the network and was able to download emby package fine.... What led you to decide to reset your network settings?
adrianwi 279 Posted February 19, 2019 Posted February 19, 2019 There are reports of VNET issues with 11.2-U2 on the FreeNAS forums.
Eddie 12 Posted February 19, 2019 Posted February 19, 2019 @@adrianwi Well i found the topic https://forums.freenas.org/index.php?threads/11-2-u2-breaks-vnet.73933/ i am reverting to 11.2 U 1 and will see how it goes.. thank you for updating me
adrianwi 279 Posted February 19, 2019 Posted February 19, 2019 There's a fix described in this thread >https://forums.freenas.org/index.php?threads/11-2-u2-breaks-vnet.73933/page-2#post-513067
hjason7812 35 Posted February 20, 2019 Posted February 20, 2019 updated freenas to the new update and now emby doesn't work.. i get an error called unbound loacal error.. local variable 'bridge_cmd' referenced before assignment Error: concurrent.futures.process._RemoteTraceback:"""Traceback (most recent call last): File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 128, in main_worker res = loop.run_until_complete(coro) File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete return future.result() File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 88, in _run return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call return methodobj(*params) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call return methodobj(*params) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 581, in start iocage.start() File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1663, in start callback=self.callback File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 66, in __init__ self.__start_jail__() File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 415, in __start_jail__ vnet_err = self.start_network(vnet) File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 598, in start_network err = self.start_network_interface_vnet(nic, net_configs, jid) File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 624, in start_network_interface_vnet membermtu = self.find_bridge_mtu(bridge) File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 975, in find_bridge_mtu su.check_call(bridge_cmd, stdout=su.PIPE, stderr=su.PIPE)UnboundLocalError: local variable 'bridge_cmd' referenced before assignment"""The above exception was the direct cause of the following exception:Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 165, in call_method result = await self.middleware.call_method(self, message) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1141, in call_method return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1078, in _call return await self._call_worker(serviceobj, name, *args) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1105, in _call_worker job, File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1036, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1021, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs))UnboundLocalError: local variable 'bridge_cmd' referenced before assignment I restarted emby and freenas server but i still get this error when trying to manage emby
Eddie 12 Posted February 20, 2019 Posted February 20, 2019 @@hjason7812 Literally the post above you talks about this fix There's a fix described in this thread >https://forums.freenas.org/index.php?threads/11-2-u2-breaks-vnet.73933/page-2#post-513067
hjason7812 35 Posted February 20, 2019 Posted February 20, 2019 @@hjason7812 Literally the post above you talks about this fix i fixed it by rolling back the update. the new update breaks the network port so i went ahead and rolled it back to the previous update and deleted the new one.. i don't have time for bs updates from freenas 1
makarai 109 Posted February 20, 2019 Posted February 20, 2019 (edited) /bin/sh -c 'export JAILS="$(iocage list -h | cut -f 2)"; for jail in $JAILS; do iocage set vnet_default_interface=auto $jail; done; iocage set vnet_default_interface=auto default' For Reference to fix the missing bridge, requires a restart. or Stop all jails, edit one jail's properties, go to Network Properties, set vnet_default_interface to auto, from none. Save - you may need to uncheck and recheck DHCP Autoconfigure in Basic before Save becomes available. Start your jail(s). Edited February 20, 2019 by makarai
gbarone123 4 Posted February 22, 2019 Posted February 22, 2019 Freenas 11.2u2 has a bug where it breaks VNET in iocage jails, though the jails do start. Strangely, existing warden jails seem to be unaffected. You should roll back to u1 until they get this fixed. It’s not an Emby issue, it’s a freenas issue.
gbarone123 4 Posted February 22, 2019 Posted February 22, 2019 This thread has a screenshot for those still trying to hack away at u2 jails networking. https://forums.freenas.org/threads/dhcp-not-working-with-jail-since-11-2-u2-upgrade.73993/
sluggo45 47 Posted February 22, 2019 Posted February 22, 2019 (edited) I was the one that opened the bug for U2's VNET problem. It's easy to fix: Update to U2. In the shell (either ssh or open the console from the WebUI) run the following: /bin/sh -c 'export JAILS="$(iocage list -h | cut -f 2)"; for jail in $JAILS; do iocage set vnet_default_interface=auto $jail; done; iocage set vnet_default_interface=auto default' Done. U2 fixed one problem with VNET not correctly picking the right interface but introduced another by not resetting previously created jails. The problem boils down to VNET not being set to auto select for users who didn't specify an interface. The above command corrects that, and will also fix it for new jails you add/modify. The permanent fix is slated for U3 which is 3 weeks away currently if you prefer to wait. Note: The above command will only work if you are on U2 - don't try to run it on U1 or lower before upgrading. Upgrade first. Rolling back in Freenas is dead simple if you mess up, just pick the earlier image at boot. Edited February 22, 2019 by sluggo45 1
lolzor 0 Posted March 4, 2019 Posted March 4, 2019 (edited) 4.1.0.12 is asking about whether you want to ignore a kernel mismatch (i'm running 11.2 U2.1) - and after you go ahead the emby crashes and doesn't recover even if you revert to a previous version. The only fix so far was to delete the jail and recreate and reinstall emby 3.5.3.0 . Edited March 4, 2019 by lolzor
hjason7812 35 Posted March 4, 2019 Posted March 4, 2019 i have a problem with emby now not working at all.. I am on 11.2 u1 i can't go to emby at all for some reason, just says unable to connect. i have restarted the server and emby but still doesn't work.. 1
Luke 42237 Posted March 4, 2019 Author Posted March 4, 2019 i have a problem with emby now not working at all.. I am on 11.2 u1 i can't go to emby at all for some reason, just says unable to connect. i have restarted the server and emby but still doesn't work.. How did you install the server?
hjason7812 35 Posted March 4, 2019 Posted March 4, 2019 (edited) Through shell.. everything worked fine until today it just stopped working on every device can't even go to the url Edited March 4, 2019 by hjason7812
eraser8 55 Posted March 4, 2019 Posted March 4, 2019 How did you install the server? Hi Luke, I do have the same sympthom. I was on 4.1.0.8 and update it by the same way I did from couple of month now. "Pkg add -f .....". I also did try to install the latest version 4.1.0.12 yesterday night and I got the same error than above. I was able to start the server but no movie was playing. I did rollback my instal to 4.1.0.10 and now it's working just like before (4.1.0.8) Thansk
