Luke 42237 Posted May 9, 2018 Author Posted May 9, 2018 Hi , is there any update on when the following issue will be resolved for the Freenas version, I am currently unable to use Emby https://emby.media/community/index.php?/topic/56481-securechannelfailure-on-freenas/page-2&do=findComment&comment=563950 The server update won't resolve it. It's the mono runtime that has to be updated in the package.
bluemonkey07 590 Posted May 10, 2018 Posted May 10, 2018 its on my todo list to update the freenas plugin to emby version 3.4.1.0Will there be any fixes for the next version?
josh4trunks 70 Posted May 10, 2018 Posted May 10, 2018 Will there be any fixes for the next version? I will attempt to by updating mono to v4.8.1, adding boringSSL, and reapply the realtime filesystem scanning patches. But building plugins, especially with updated dependencies is getting really convoluted for FreeNAS 9 based plugins (which is what FreeNAS still uses). So I can't guarantee if/when I will get this update done.
Luke 42237 Posted May 10, 2018 Author Posted May 10, 2018 I will attempt to by updating mono to v4.8.1, adding boringSSL, and reapply the realtime filesystem scanning patches. But building plugins, especially with updated dependencies is getting really convoluted for FreeNAS 9 based plugins (which is what FreeNAS still uses). So I can't guarantee if/when I will get this update done. I think there is a little more beyond updating as well, probably some configuration required to the runtime. We can use whatever was done for the Synology builds. We are also very soon to put up a FreeBSD package for testing based on .NET Core. It will be a FreeBSD plugin, not specific to FreeNAS, but if that goes well we'll look at a FreeNAS plugin after that.
adrianwi 279 Posted May 11, 2018 Posted May 11, 2018 Don't really know much about the jail systems, other than what I read on the FreeNAS forums, but with the change from warden to iocage it appears scripts can be used to build jails using the appropriate port/pkg dependencies.
xtralives 0 Posted May 22, 2018 Posted May 22, 2018 I seem to be having issues backing up my config and accessing app updates. I opened the shell from the jail and can ping 8.8.8.8 and google.com. I'm backing up to local storage on the FreeNAS server mounted in /media/backup from within the storage tab under "jails-emby_1-storage". I can access and play media files with no problem. I've attached my log file too. If there's anything else I can do to help please let me know. Thanks for all the hard work on such an awesome system!
Luke 42237 Posted May 22, 2018 Author Posted May 22, 2018 I seem to be having issues backing up my config and accessing app updates. I opened the shell from the jail and can ping 8.8.8.8 and google.com. I'm backing up to local storage on the FreeNAS server mounted in /media/backup from within the storage tab under "jails-emby_1-storage". I can access and play media files with no problem. I've attached my log file too. If there's anything else I can do to help please let me know. Thanks for all the hard work on such an awesome system! Hi there, did you forget to attach the log? Thanks !
Luke 42237 Posted May 23, 2018 Author Posted May 23, 2018 IembyLog.txt didn't hit “attach this file” Ok, you can follow this issue here: https://emby.media/community/index.php?/topic/56481-securechannelfailure-on-freenas/ Short answer: the mono runtime in the freenas package needs to be updated, however, this is only affecting the check for updates and a couple other things so in the meantime it's not likely to impact your usage very much.
bluemonkey07 590 Posted June 1, 2018 Posted June 1, 2018 Ok I can't put up with my emby plugin crashing everytime I add content any longer. It seems everytime a scan finds something new or I try to record live TV the my emby freenas plugin needs to be restarted, it takes hours of constant monitoring to add 1 season of a TV show. Please help! Attached log2018-06-02 02_09_51.260.txt
Luke 42237 Posted June 1, 2018 Author Posted June 1, 2018 Ok I can't put up with my emby plugin crashing everytime I add content any longer. It seems everytime a scan finds something new or I try to record live TV the my emby freenas plugin needs to be restarted, it takes hours of constant monitoring to add 1 season of a TV show. Please help! Attached log2018-06-02 02_09_51.260.txt You're running a really old version of the mono runtime. I would suggest updating that, and/or disabling the realtime monitor if the crashes are associated with new content. Please let us know if this helps. Thanks.
bluemonkey07 590 Posted June 1, 2018 Posted June 1, 2018 I have disabled all scheduled tasks (and real-time monitoring I think) that cause crashing but that still leaves me with the problem that I can't record anything or add content without issues. I am using the latest freenas plugin that has not been updated in some time and I've had this issue since I first updated to this version
Luke 42237 Posted June 1, 2018 Author Posted June 1, 2018 The mono runtime is a dependency, it is not part of the plugin. It is something you can update independently on your own.
josh4trunks 70 Posted June 1, 2018 Posted June 1, 2018 @@Luke actually for the old plugins you usually can't update dependencies without doing any hacking. It probably could be done with a few commands though. I do plan on updating the Emby plugin soon, and will try updating the version of mono bundled but it keeps getting delayed on my todo list. Got a baby on the way, so finishing some home project have taken a priority at the moment. as another data point, i am using the emby plugin as well on 3 different systems (with realtime monitoring enabled) and have never experienced a crash on those. but i may not be updated to the latest available freenas version, so maybe their is an issue with that. 1
Luke 42237 Posted June 1, 2018 Author Posted June 1, 2018 My mistake, thanks @@josh4trunks for clearing that up.
bluemonkey07 590 Posted June 1, 2018 Posted June 1, 2018 @@Luke actually for the old plugins you usually can't update dependencies without doing any hacking. It probably could be done with a few commands though. I do plan on updating the Emby plugin soon, and will try updating the version of mono bundled but it keeps getting delayed on my todo list. Got a baby on the way, so finishing some home project have taken a priority at the moment. as another data point, i am using the emby plugin as well on 3 different systems (with realtime monitoring enabled) and have never experienced a crash on those. but i may not be updated to the latest available freenas version, so maybe their is an issue with that. Sorry to bug you but I've had this issue for some time, do you have some eta or is there a way to revert to an older version of the plugin?
josh4trunks 70 Posted June 1, 2018 Posted June 1, 2018 Sorry to bug you but I've had this issue for some time, do you have some eta or is there a way to revert to an older version of the plugin? i do not know if emby itself is ok with downgrading. since it maintains its own database that might not be downgradeable. I am running version 3.2.60 on my personal freenas, haven't bothered to update, but do upgrade occasionally. * you can download a version of the emby PBI here. https://download.freenas.org/plugins/9/x64/ * i would also download another PBI like for resilio * upload the resilio PBI to the emby_1 jail on the jails tab * stop the emby plugin on the plugins > installed tab * delete the emby plugin * upload the emby PBI to the emby_1 jail on the jails tab * delete the resilio plugin on the Plugins > installed tab * start the emby plugin
Luke 42237 Posted June 1, 2018 Author Posted June 1, 2018 I think it would be better to update the sever manually to 3.4.1, then turn off features you aren't using such as the dlna server, dlna play to, automatic port mapping, etc. I am not sure the downgrade will be safe due to database changes made by the newer version that the older version will not be expecting.
Luke 42237 Posted June 1, 2018 Author Posted June 1, 2018 You can also try that without updating, so turn off features, then restart the server. I only mentioned updating because 3.4.1 will do a better job of disabling more internal functions when they're not being used.
makarai 109 Posted June 3, 2018 Posted June 3, 2018 1st add tuneables so jail can run with vnet and can multicast 2nd #create jail iocage create -n "emby_foo" -r 11.1-RELEASE ip4_addr="vnet0|192.168.0.107/24" defaultrouter="192.168.0.1" vnet="on" allow_raw_sockets="1" boot="on" iocage console emby_foo pkg update pkg upgrade pkg install emby-server service emby-server onestart sysrc 'emby_server_enable=YES' sysrc 'emby_server_user=emby' service emby-server onestop pw groupmod emby -n emby -g 1000 #1000 is my UID and GID pw usermod emby -n emby -u 1000 -g 1000 chown -R emby:emby /var/db/emby-server #skip this if you are interested in just the latest stable //skip from here #or keep going for the latest stable cd /tmp fetch https://github.com/MediaBrowser/Emby/releases/download/3.4.1.10/Emby.Mono.zip #(swap with address of latest file found here: https://github.com/MediaBrowser/Emby/releases) unzip -d /tmp/emby Emby.Mono.zip cp -Rfp /tmp/emby/ /usr/local/lib/emby-server rm -r /tmp/emby rm /tmp/Emby.Mono.zip service emby-server onestart #skip to here exit #add storage (replace with your actual storage) iocage fstab -a emby_foo /mnt/volume01/multimedia /multimedia01 nullfs rw 0 0 iocage fstab -a emby_foo /mnt/volume02/multimedia /multimedia02 nullfs rw 0 0 iocage fstab -a emby_foo /mnt/volume01/db/ssl/user-certs /certs nullfs rw 0 0 1
adrianwi 279 Posted June 3, 2018 Posted June 3, 2018 (edited) 1st add tuneables so jail can run with vnet and can multicast Capture.PNG 2nd #create jail iocage create -n "emby_foo" -r 11.1-RELEASE ip4_addr="vnet0|192.168.0.107/24" defaultrouter="192.168.0.1" vnet="on" allow_raw_sockets="1" boot="on" iocage console emby_foo pkg update pkg upgrade pkg install emby-server service emby-server onestart sysrc 'emby_server_enable=YES' sysrc 'emby_server_user=emby' service emby-server onestop pw groupmod emby -n emby -g 1000 #1000 is my UID and GID pw usermod emby -n emby -u 1000 -g 1000 chown -R emby:emby /var/db/emby-server #skip this if you are interested in just the latest stable //skip from here #or keep going for the latest stable cd /tmp fetch https://github.com/MediaBrowser/Emby/releases/download/3.4.1.10/Emby.Mono.zip #(swap with address of latest file found here: https://github.com/MediaBrowser/Emby/releases) unzip -d /tmp/emby Emby.Mono.zip cp -Rfp /tmp/emby/ /usr/local/lib/emby-server rm -r /tmp/emby rm /tmp/Emby.Mono.zip service emby-server onestart #skip to here exit #add storage (replace with your actual storage) iocage fstab -a emby_foo /mnt/volume01/multimedia /multimedia01 nullfs rw 0 0 iocage fstab -a emby_foo /mnt/volume02/multimedia /multimedia02 nullfs rw 0 0 iocage fstab -a emby_foo /mnt/volume01/db/ssl/user-certs /certs nullfs rw 0 0 What version of Mono and FFMpeg does this pkg install leave you with? Although it takes a little longer (a few hours pressing enter to accept defaults, with only 2 ports requiring changes), I think installing emby with cd /usr/ports/multimedia/emby-server/ && make clean install is better as you end up with the latest version installed with the appropriate properties checked. Certainly, from my experience, this tends to provide the best performance and emby experience. Edited June 3, 2018 by adrianwi
makarai 109 Posted June 3, 2018 Posted June 3, 2018 (edited) ffmpeg 3.4.2 mono 5.2.0.215 both the latest from freshports after i Add folder pkg/repos/ vi /usr/local/etc/pkg/repos/FreeBSD.conf FreeBSD: { url: "pkg+http://pkg.FreeBSD.org/${ABI}/latest" } pkg update pkg upgrade i know mono 5.8 is recommended but i have not run into any problems as of yet. ffmpeg: with these flags ffmpeg -v ffmpeg version 3.4.2 Copyright (c) 2000-2018 the FFmpeg developers built with FreeBSD clang version 4.0.0 (tags/RELEASE_400/final 297347) (based on LLVM 4.0.0) configuration: --prefix=/usr/local --mandir=/usr/local/man --datadir=/usr/local/share/ffmpeg --pkgconfigdir=/usr/local/libdata/pkgconfig --enable-shared --enable-pic --enable-gpl --enable-postproc --enable-avfilter --enable-avresample --enable-pthreads --cc=cc --disable-alsa --disable-libopencore-amrnb --disable-libopencore-amrwb --disable-libass --disable-libbs2b --disable-libcaca --disable-libcdio --disable-libcelt --disable-chromaprint --disable-libdc1394 --disable-debug --enable-htmlpages --disable-libdrm --disable-libfdk-aac --enable-ffserver --disable-libflite --enable-fontconfig --enable-libfreetype --enable-frei0r --disable-libfribidi --disable-libgme --disable-libgsm --enable-iconv --disable-libilbc --disable-jack --disable-libkvazaar --disable-ladspa --disable-libmp3lame --disable-libbluray --disable-librsvg --disable-libxml2 --enable-mmx --disable-libmodplug --disable-libmysofa --disable-openal --disable-opencl --enable-libopencv --disable-opengl --disable-libopenh264 --disable-libopenjpeg --enable-optimizations --enable-libopus --disable-libpulse --enable-runtime-cpudetect --disable-librubberband --disable-sdl2 --disable-libsmbclient --disable-libsnappy --disable-sndio --disable-libsoxr --disable-libspeex --enable-sse --disable-libssh --disable-libtesseract --enable-libtheora --disable-libtwolame --enable-libv4l2 --enable-vaapi --enable-vdpau --disable-libvidstab --enable-libvorbis --disable-libvo-amrwbenc --enable-libvpx --disable-libwavpack --disable-libwebp --enable-libx264 --enable-libx265 --disable-libxcb --enable-libxvid --disable-outdev=xv --disable-libzimg --disable-libzmq --disable-libzvbi --disable-gcrypt --enable-gmp --disable-librtmp --enable-gnutls --disable-openssl --enable-version3 --disable-nonfree libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavformat 57. 83.100 / 57. 83.100 libavdevice 57. 10.100 / 57. 10.100 libavfilter 6.107.100 / 6.107.100 libavresample 3. 7. 0 / 3. 7. 0 libswscale 4. 8.100 / 4. 8.100 libswresample 2. 9.100 / 2. 9.100 libpostproc 54. 7.100 / 54. 7.100 speaking of mono: On Friday, 1 June 2018 07:10:22 my name wrote:> Hey DBN,Hi my name> I am writing you in order to convince you to update the> https://www.freshports.org/lang/mono port, is there anything i can do,> maybe a bounty? There are several tools that i personally use that now> require mono 5.8+Thank you for expressing an interest in mono :-). You don't need to convince me to update mono, I'm happy to do it :-D. Unfortunately the limiting factor for me time. Work of late has been very time consuming leaving me with little energy and time for working on FreeBSD related stuff. Thank you also for considering a bounty, but given what is limiting me a bounty won't help me specifically. A bounty, however, may help with motivating other members of the community? Perhaps you can reach out to Romain Tartiere?One area that would help me is updating the ancially ports relating to mono. Please see portscout [1] for a list of ports that need updating. The best way would be to create a PR [2] and assign that to me. I can then run an exp-run to test the update. I suggest starting with xsp, mod_mono and libgdiplus. Regards[1] https://portscout.freebsd.org/mono@freebsd.org.html[2] https://bugs.freebsd.org/bugzilla/enter_bug.cgi?component=Individual%20Port(s)&product=Ports%20&%20Packages Edited June 4, 2018 by makarai 1
makarai 109 Posted June 4, 2018 Posted June 4, 2018 What version of Mono and FFMpeg does this pkg install leave you with? Although it takes a little longer (a few hours pressing enter to accept defaults, with only 2 ports requiring changes), I think installing emby with cd /usr/ports/multimedia/emby-server/ && make clean install is better as you end up with the latest version installed with the appropriate properties checked. Certainly, from my experience, this tends to provide the best performance and emby experience. What are the differences, in the methods? i mean technically you could also load the plugin in freenas which is by far the easiest/fastest. Maybe you could whip up a quick tutorial.
adrianwi 279 Posted June 4, 2018 Posted June 4, 2018 All the instructions that you need are in this thread, although pulling them together in one place might be a good idea. As I see it, there are 2 main ways of getting emby running on FreeNAS: 1. create and configure a jail, or 2. install the plugin (which pretty much does option 1 for you) To complicate things, and depending on the version of FreeBSD you are running, there are two ways to create a jail: 1.1 the old method using Warden (which is still available in the current 11.1 version, although the resulting jail would be created with a FreeBSD 11.0 template which is EOL so not recommended). This is also what you'd get running the plugin on 11.1 1.2 the new method using iocage, which still has a few teething problems (around networking) and the beta GUI in 11.1 doesn't have all the functionality so you need to use the CLI Once you've picked your jail method (which really should be iocage), you can then configure it in 2 different ways: 1.2.1 using ports to compile emby and its dependencies, which ensures you have the latest versions available but takes some time (90-120 mins for me) and requires regular intervention (hitting enter) 1.2.2 using the pkg manager to download emby and its dependencies, which downloads the latest version of the dependencies packaged with emby (last time I did this it was a 4.x version of Mono and a 3.x version of FFMpeg) but only takes a few minutes So for me, it's pretty much down to: A. speed of installation (Plugin > Jail > Pkg > Port) B. timeliness of the software updates (Port > Pkg > Jail > Plugin) In defence of the plugin, as this is a plugin thread and I'm not trying to crap over the great work Josh does to maintain, it also has some changes to Mono so library scans are performed when new content is added to the FreeNAS datasets. This is great, although for me not worth the other components being out of date. In my humble opinion, 1.2.1 is the best option, and if you want an even newer version of emby use the fetch and copy method as described above, otherwise update the ports as things are notified via freshports.org. I suppose another option is to run emby in a VM on FreeNAS, but you're adding complexity and overhead when it runs pretty well natively on FreeBSD. I've tried it running an Ubuntu VM and then the emby Docker container, but didn't see any real benefit.
