Eddie 12 Posted March 29, 2018 Posted March 29, 2018 did you add storage to the jail? add storage in the jail /mnt/volume/PATH/TO/YOUR/MEDIA/IN/FREENAS /media/NAMEOFFOLDERINSIDEYOURJAIL
hjason7812 35 Posted April 1, 2018 Posted April 1, 2018 no problem. ill look into the tls error too, and see if an updated mono/openssl version fixes it and update the plugin. Thanks they pop up more and more as you use emby.. Like right now i have 12 of those errors and i used the server maybe 20 minutes..
hjason7812 35 Posted April 1, 2018 Posted April 1, 2018 did you add storage to the jail? add storage in the jail /mnt/volume/PATH/TO/YOUR/MEDIA/IN/FREENAS /media/NAMEOFFOLDERINSIDEYOURJAIL Yes i thought i did and Josh reminded me, thanks though...
hjason7812 35 Posted April 3, 2018 Posted April 3, 2018 @@josh4trunks Here are the latest errors just after login...
Luke 42239 Posted April 3, 2018 Author Posted April 3, 2018 @@hjason7812 you can monitor that issue here: https://emby.media/community/index.php?/topic/56481-securechannelfailure-on-freenas/?view=getnewpost Thanks.
ebike 13 Posted April 13, 2018 Posted April 13, 2018 (edited) Hi, I am having issues of late with the plugin for iocage. I am running version 3.3.0.0 After immediate installation and directing it to my media all the folders obtained poster art just fine, but I wanted to re-do the media type to Movies for my TV recordings, so following instruction I removed that library and re-did it with that media type. However, the poster art is missing and won't download ... no matter what I do, I try re-scanning, tried re-obtaining metadata ... nothing works. How do I get my art back again? Cheers PS: I get jason's error as well .. Edited April 13, 2018 by ebike
Luke 42239 Posted April 14, 2018 Author Posted April 14, 2018 Hi, I am having issues of late with the plugin for iocage. I am running version 3.3.0.0 After immediate installation and directing it to my media all the folders obtained poster art just fine, but I wanted to re-do the media type to Movies for my TV recordings, so following instruction I removed that library and re-did it with that media type. However, the poster art is missing and won't download ... no matter what I do, I try re-scanning, tried re-obtaining metadata ... nothing works. How do I get my art back again? Cheers PS: I get jason's error as well .. Can you please attach the emby server log from the timeframe that you had a problem? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
ebike 13 Posted April 15, 2018 Posted April 15, 2018 Hi Luke, File is attached .... now that I have found out how to attached a file to this post File is only part of the 12Mb log file, but shows the errors
ebike 13 Posted April 15, 2018 Posted April 15, 2018 (edited) I did attach it, but I am having issues with adding files in this forum/firefox ... I will try again. Also, I notice that the latest recordings I did, fetched it's artwork fine, it is just the old ones in that lib that are missing .. EDIT: I notice I can do an "identify" and fetch the posterart fine for each one, ..but I don't want to do that to recover 200 odd movies ... there must be a better way .. emeby_error.txt Edited April 16, 2018 by ebike
Luke 42239 Posted April 16, 2018 Author Posted April 16, 2018 Have you configured a network connection for your jail? All outgoing http requests to the metadata providers are timing out. At least the ones in this log.
josh4trunks 70 Posted April 16, 2018 Posted April 16, 2018 Have you configured a network connection for your jail? All outgoing http requests to the metadata providers are timing out. At least the ones in this log.this can be tested with "ping google.com", and "ping 8.8.8.8"
hjason7812 35 Posted April 16, 2018 Posted April 16, 2018 i had the same problem where i couldn't get internet all the way through freenas. i changed the dns servers from blank to what i want to use and made sure my gateway was right. after i did that everything worked fine for internet.
ebike 13 Posted April 16, 2018 Posted April 16, 2018 (edited) Yes, I think that was it. At the time I think a fresh boot of FreeNAS did not give a nameserver, a re-boot fixed it. As noted in my edit to my last post. Recodings done now are ok. But still the Posterart for the older recordings are not there ... how do I force it to re-load posterart? Edited April 16, 2018 by ebike
Luke 42239 Posted April 16, 2018 Author Posted April 16, 2018 You can try right clicking on one of them and selecting refresh metadata. You can also try doing that on a folder.
ebike 13 Posted April 18, 2018 Posted April 18, 2018 Hmm, that did not work on a lot of them. Re-typing the movie name into "identify" was the only way to get the artwork .. (They did not have a strange name either .. )
Luke 42239 Posted April 18, 2018 Author Posted April 18, 2018 Probably because they had no identifying information to download such artwork, and the Identify process helped get that information added. Thanks for reporting back.
Validar 1 Posted May 8, 2018 Posted May 8, 2018 (edited) Hi everyone. I have the same problem as was posted here https://emby.media/community/index.php?/topic/50674-no-titles-in-dlna-after-upgrade-from-jessie-to-stretch/On my TV i can see Library folders, but it is empty. By the web interface, everything work fine. Freenas plugin version 3.3.1.0. TV Model is Samsung UE48H6200.In logs i have this error: "Error UpnpContentDirectory: Error parsing item Id: V. Returning user root folder."Is any way to fix this problem? Thanx. Edited May 8, 2018 by Validar 1
Luke 42239 Posted May 8, 2018 Author Posted May 8, 2018 Hi everyone. I have the same problem as was posted here https://emby.media/community/index.php?/topic/50674-no-titles-in-dlna-after-upgrade-from-jessie-to-stretch/ On my TV i can see Library folders, but it is empty. By the web interface, everything work fine. Freenas plugin version 3.3.1.0. TV Model is Samsung UE48H6200. In logs i have this error: "Error UpnpContentDirectory: Error parsing item Id: V. Returning user root folder." Is any way to fix this problem? Thanx. Hi, can you please attach the emby server log? thanks.
hjason7812 35 Posted May 8, 2018 Posted May 8, 2018 @@Validar it sounds like you didn't properly add the media into emby. i have found on freenas you have to add your media in media also add storage to the media file and mount it. i have found out that if you don't moubt it, it will disappear like it was never there. sorry if this doesn't make sense, i just woke up.. hope this all helps you.
Validar 1 Posted May 9, 2018 Posted May 9, 2018 @@Validar it sounds like you didn't properly add the media into emby. i have found on freenas you have to add your media in media also add storage to the media file and mount it. i have found out that if you don't moubt it, it will disappear like it was never there. sorry if this doesn't make sense, i just woke up.. hope this all helps you. Hi Hjason7812, I don't think so. In the Firefox, IE and my very old TV (Philips) all work perfectly. Hi, can you please attach the emby server log? thanks. Hi Luke, sorry I didn't do it early. IP address which ends on 21 is my problem TV. emby_log.txt
weaselwebb 0 Posted May 9, 2018 Posted May 9, 2018 Hi , is there any update on when the following issue will be resolved for the Freenas version, I am currently unable to use Emby https://emby.media/community/index.php?/topic/56481-securechannelfailure-on-freenas/page-2&do=findComment&comment=563950
josh4trunks 70 Posted May 9, 2018 Posted May 9, 2018 Hi , is there any update on when the following issue will be resolved for the Freenas version, I am currently unable to use Emby https://emby.media/community/index.php?/topic/56481-securechannelfailure-on-freenas/page-2&do=findComment&comment=563950 its on my todo list to update the freenas plugin to emby version 3.4.1.0
weaselwebb 0 Posted May 9, 2018 Posted May 9, 2018 its on my todo list to update the freenas plugin to emby version 3.4.1.0 Thanks Josh,
