josh4trunks 70 Posted March 6, 2018 Posted March 6, 2018 I hate to nag, but any chance we could get a plugin update to 3.3? Sure, I'll try to get to it tonight.
eraser8 55 Posted March 11, 2018 Posted March 11, 2018 Hi Folks, I wonder if someone get the same behaviour. So, I was on version 3.2.70.0. I also had samba server installed in my jail because I like to have netbios feature for my emby server. Since I updated to version 3.3.1.0, something have change. Now the Samba server does'nt work anymore. It seems that some libraries are affected to run samba. When I try to start samba server, it give me a FAILED sanity check and this is the problem: ---- /usr/pbi/emby-amd64/lib/libndr.so.0: version NDR_0.0.6 required by /usr/local/lib/samba4/private/libsecrets3-samba4.so not found ---- After some testing and try/error. I could see that this file: /usr/pbi/emby-amd64/lib/libndr.so.0 was not existing on version 3.2.70.0 but was installed when updated to version 3.3.1.0 of plugin. (not only this file but many other in the same directory) I'm looking forward a solution to make samba run with 3.3.1.0 version of plugin. Someone have clue for that? Thanks
bluemonkey07 590 Posted March 12, 2018 Posted March 12, 2018 I am finding this version 3.3.1.0 very unstable
adrianwi 279 Posted March 12, 2018 Posted March 12, 2018 And I was thinking 3.3.1.0 was a big improvement, as everything seems much more responsive!
Eddie 12 Posted March 12, 2018 Posted March 12, 2018 The few times I have ever had issues with emby over the last few years a simple nuke and pave and reinstall of emby completely resolves my issue....just my 2 cents
eraser8 55 Posted March 12, 2018 Posted March 12, 2018 (edited) Believe me, not this time.... I tried many different installs from scratch, even reinstall all my freenas.... doesn't works anymore with samba Edited March 12, 2018 by eraser8
hjason7812 35 Posted March 28, 2018 Posted March 28, 2018 hello, i have bit the bullet and installed freenas and have just installed the emby plugin.. there is only one gripe abd that is an error every time i log in to emby. I'm tired my eyes hurt from trying to figure it out. I'll post a screen shot tomorrow..
Luke 42239 Posted March 28, 2018 Author Posted March 28, 2018 Can you tell us what the error is? Thanks.
hjason7812 35 Posted March 29, 2018 Posted March 29, 2018 (edited) now it has not been able to turn on in gui. it worked for a day and now it stays off even after a full server reboot. Edited March 29, 2018 by hjason7812
Eddie 12 Posted March 29, 2018 Posted March 29, 2018 Try deleting your jails folder and restarting Freeman and try again.... deleting the jails folder will delete all your jails in Freenas just a fyi
josh4trunks 70 Posted March 29, 2018 Posted March 29, 2018 Try deleting your jails folder and restarting Freeman and try again.... deleting the jails folder will delete all your jails in Freenas just a fyii do not recommend you do this method. if you want to delete all your jails and start over (which may not actually fix his issue if it is networking related)- delete all the plugins on the plugins>installed tab. - delete any remaining non-plugin jails - then delete the jail dataset 1
josh4trunks 70 Posted March 29, 2018 Posted March 29, 2018 now it has not been able to turn on in gui. it worked for a day and now it stays off even after a full server reboot. this command will show if emby actually is working, and the issue is only limited to the guijexec emby_1 service emby-server onestart the plugins gui relies on the jail's networking working. test if you can login to the jail and ping another computer on your network
hjason7812 35 Posted March 29, 2018 Posted March 29, 2018 this command will show if emby actually is working, and the issue is only limited to the gui jexec emby_1 service emby-server onestart the plugins gui relies on the jail's networking working. test if you can login to the jail and ping another computer on your network Just tried to turn on emby again and it says some error has occurred at the top in a green box..
Luke 42239 Posted March 29, 2018 Author Posted March 29, 2018 Can you tell us what the error is? Thanks.
josh4trunks 70 Posted March 29, 2018 Posted March 29, 2018 Just tried to turn on emby again and it says some error has occurred at the top in a green box..can you post the error we can help with it? can you log into the emby jail's command line and try the following commands. sysrc emby_server_enable=YES service emby-service start
hjason7812 35 Posted March 29, 2018 Posted March 29, 2018 can you post the error we can help with it? can you log into the emby jail's command line and try the following commands. sysrc emby_server_enable=YES service emby-service start Ok i got it working finally again.. i went through everything after deleting emby and the jails.. And found that for some odd reason freenas was trying to connect through ip 192.168.0.1 instead of my actual router ip... I changed everything to what it should be restarted freenas and bam turned on.. Now once i logged into emby there were alerts and i have attached a screen shot.. mind you this is all a brand new install nothing has been added yet...
Luke 42239 Posted March 29, 2018 Author Posted March 29, 2018 Ok i got it working finally again.. i went through everything after deleting emby and the jails.. And found that for some odd reason freenas was trying to connect through ip 192.168.0.1 instead of my actual router ip... I changed everything to what it should be restarted freenas and bam turned on.. Now once i logged into emby there were alerts and i have attached a screen shot.. mind you this is all a brand new install nothing has been added yet... That is a new thing due to api changes from github. You can follow that issue here: https://emby.media/community/index.php?/topic/56481-securechannelfailure-on-freenas/ Thanks.
hjason7812 35 Posted March 29, 2018 Posted March 29, 2018 This one as well after installing plug ins?
Luke 42239 Posted March 29, 2018 Author Posted March 29, 2018 Correct. This was just solved for Synology so we can probably learn something from that.
hjason7812 35 Posted March 29, 2018 Posted March 29, 2018 even though it doesn't hurt anything i don't think anyways, it is still worrisome to know there are errors being produced.. hopefully it is resolved soon.. Thanks Oh an Luke ps4 just updated the media player this am, and we got a new firmware update but emby still doesn't work right on there.. Any news on a fix? Thanks
hjason7812 35 Posted March 29, 2018 Posted March 29, 2018 now when i try to put in my media emby doesn't see the networked map drive, nor does it find my folders. How do i fix this?
josh4trunks 70 Posted March 29, 2018 Posted March 29, 2018 now when i try to put in my media emby doesn't see the networked map drive, nor does it find my folders. How do i fix this?you shouls mount your media dataset(s) into the emby jail on the Jails > Storage tab. 1
hjason7812 35 Posted March 29, 2018 Posted March 29, 2018 Got it i thought i made them but they weren't there.. sorry, thanks
josh4trunks 70 Posted March 29, 2018 Posted March 29, 2018 Got it i thought i made them but they weren't there.. sorry, thanks no problem.ill look into the tls error too, and see if an updated mono/openssl version fixes it and update the plugin. 1
