Eddie 12 Posted November 21, 2017 Posted November 21, 2017 Let's say i am able to get emby running in a new plugin... is there an easy way to update it or will i have to repeat this 30 min process for every update?
adrianwi 279 Posted November 21, 2017 Posted November 21, 2017 Assuming you mean running in a jail, and not using the plugin, you can just update the emby port as soon as it's released. Just a couple of commands and it shouldn't take more than 5-10 minutes
Baenwort 119 Posted November 22, 2017 Posted November 22, 2017 I thought Josh had done some additional customizations to fix things and add features that didn't translate to the FreeBSD port because they were FreeNAS specific that leveraged the ZFS file system?
josh4trunks 70 Posted November 22, 2017 Posted November 22, 2017 I thought Josh had done some additional customizations to fix things and add features that didn't translate to the FreeBSD port because they were FreeNAS specific that leveraged the ZFS file system?I compile ffmpeg with the options mentioned in the emby for freebsd instructions. I also include a patch for mono for realtime filesystem monitoring. 2
dolphin 17 Posted November 28, 2017 Posted November 28, 2017 Thanks Josh, I just updated the FreeNAS Emby plug-in to 3.2.36.0! Inviato dal mio ONEPLUS A3003 utilizzando Tapatalk
Baenwort 119 Posted December 9, 2017 Posted December 9, 2017 So I've started to learn more about FreeBSD that FreeNAS is based upon and have now signed up at Freeports.org to monitor when software I've installed gets updated. I've noticed that Josh always updates the pbi plug in after someone has updated the base FreeBSD package. @@Josh, is the bottle neck for our releases the version of the program on FreeBSD? If so is there somewhere we can donate to help speed that process? We're getting a rather large number of versions behind the main Emby and I've noticed an increase in issues with some of the apps that have been updating in concert with the main release when I use them with my FreeNAS emby server. I don't see the same issues when connecting to a test Windows server so I think it has something to do with the difference between expected server version and the one we have available.
josh4trunks 70 Posted December 9, 2017 Posted December 9, 2017 So I've started to learn more about FreeBSD that FreeNAS is based upon and have now signed up at Freeports.org to monitor when software I've installed gets updated. I've noticed that Josh always updates the pbi plug in after someone has updated the base FreeBSD package. @@Josh, is the bottle neck for our releases the version of the program on FreeBSD? If so is there somewhere we can donate to help speed that process? We're getting a rather large number of versions behind the main Emby and I've noticed an increase in issues with some of the apps that have been updating in concert with the main release when I use them with my FreeNAS emby server. I don't see the same issues when connecting to a test Windows server so I think it has something to do with the difference between expected server version and the one we have available. No, I don't need to wait for the official port to update. I update my own local version of the port in my build environment and can do this as soon as a new version of emby is released. I see only 2 (non-beta) releases since the FreeNAS version (3.2.36), 3.2.40 and 3.2.50. Is that what you consider the rather large amount? I just want to make sure I am understanding the versioning properly and not missing some. I can work on getting 3.2.50 built/uploaded today, which would be available tomorrow. If I got notified of non-beta versions, that could help me getting new FreeNAS builds out when I have time. Posting to this thread would notify me by email. And if anyone did want to donate to keep me motivated to work on these updates here's a link. https://www.paypal.com/cgi-bin/webscr?cmd=_donations&business=joshruehlig%40gmail%2ecom&item_name=JRuehlig%20Technologies 1
Eddie 12 Posted December 9, 2017 Posted December 9, 2017 Josh usually stays within a couple of releases of the whatever is the latest release for emby not a huge deal for me even though my OCD always wants the latest and greatest... i think the problem isnt josh but the update mechanism... Emby updates for all major platforms like windows and linux and freebsd.... freenas isnt really included in that and has to be done manually via a plugin that relies soley on the available freetime of josh... freenas needs a better way to sync to the freebsd port instead of relying on plugins but they just cant seem to get rid of them... I thought freenas was going to get rid of plugins for version 10 and 11 but they seem to stick around. on a side note madsonic has an update dont really know what method to use to let you know in the future if you would prefer a pm or not https://www.freshports.org/www/madsonic/ thanks in advance
Luke 42238 Posted December 9, 2017 Author Posted December 9, 2017 I think once there is a .NET Core runtime available for BSD, then we will look to revamp both the FreeBSD and FreeNAS packages. Thanks guys.
dolphin 17 Posted December 9, 2017 Posted December 9, 2017 I just made a donation to Josh for his work on the FreeNAS Emby plug-in. I believe work should be compensated. Inviato dal mio ONEPLUS A3003 utilizzando Tapatalk 1
josh4trunks 70 Posted December 9, 2017 Posted December 9, 2017 I appreciate it @@dolphin @@Luke I was trying to run 3.2.50.0 using mono 4.6.1 and getting the below crash. Is there a minimum version of mono needed for emby 3.2.50.0? I was able to run emby 3.2.40.0 fine. /usr/local/bin/mono /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server Info Main: Emby Command line: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 9.3.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.6.1 (Stable 4.6.1.5/ef43c15 Mon Jun 12 05:20:14 UTC 2017) Processor count: 1 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server * Assertion at threadpool-ms-io.c:344, condition `fd >= 0' not met Stacktrace: ================================================================= Got a SIGABRT while executing native code. This usually indicates a fatal error in the mono runtime or one of the native libraries used by your application. ================================================================= Abort trap (core dumped)
Luke 42238 Posted December 9, 2017 Author Posted December 9, 2017 @@josh4trunks is any emby log file created at all?
Luke 42238 Posted December 9, 2017 Author Posted December 9, 2017 To answer the question, mono 4.8.1 would be best if possible. Thanks.
josh4trunks 70 Posted December 9, 2017 Posted December 9, 2017 Yes a log file is created with the below only. 2017-12-09 10:14:21.371 Info Main: Emby Command line: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 9.3.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.6.1 (Stable 4.6.1.5/ef43c15 Mon Jun 12 05:20:14 UTC 2017) Processor count: 1 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server Ok, 4.8.1 is available for FreeBSD... but I have been trying to keep this patch which enables filesystem scanning on FreeBSD. https://bugs.freebsd.org/bugzilla/attachment.cgi?id=176608&action=diff I'll see if 4.8.1 works, and try updating this patch. This release will take me longer then normal =/ 1
Baenwort 119 Posted December 10, 2017 Posted December 10, 2017 No, I don't need to wait for the official port to update. I update my own local version of the port in my build environment and can do this as soon as a new version of emby is released. I see only 2 (non-beta) releases since the FreeNAS version (3.2.36), 3.2.40 and 3.2.50. Is that what you consider the rather large amount? I just want to make sure I am understanding the versioning properly and not missing some. I can work on getting 3.2.50 built/uploaded today, which would be available tomorrow. If I got notified of non-beta versions, that could help me getting new FreeNAS builds out when I have time. Posting to this thread would notify me by email. And if anyone did want to donate to keep me motivated to work on these updates here's a link. https://www.paypal.com/cgi-bin/webscr?cmd=_donations&business=joshruehlig%40gmail%2ecom&item_name=JRuehlig%20Technologies I didn't realize that it was only two revisions. I've only recently started paying attention to Emby's versioning and since I did it seemed to increment in smaller ones than that. I had thought it was 14 different versions between as it seemed to be going 3.2.19 to 3.2.20 and 3.2.26 to 3.2.27 to 3.2.30 and I thought I had just missed some version in between as I don't expect a volunteer like Josh to immediately rush to implement.
Luke 42238 Posted December 11, 2017 Author Posted December 11, 2017 Yes a log file is created with the below only. 2017-12-09 10:14:21.371 Info Main: Emby Command line: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 9.3.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.6.1 (Stable 4.6.1.5/ef43c15 Mon Jun 12 05:20:14 UTC 2017) Processor count: 1 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server Ok, 4.8.1 is available for FreeBSD... but I have been trying to keep this patch which enables filesystem scanning on FreeBSD. https://bugs.freebsd.org/bugzilla/attachment.cgi?id=176608&action=diff I'll see if 4.8.1 works, and try updating this patch. This release will take me longer then normal =/ A tester has helped narrow it down to some startup code that uses the Mono.Posix library to make syscalls to query the OS information. This allows us to differentiate between freebsd and linux. The problem is I have no explanation for the sudden failure because the code hasn't changed, nor have the included libraries. So I am just going to remove it and have you guys add a command line param to specify freebsd customizations from the outside in. Might as well do it now because the library will not be usable anyway down the road with .net core.
josh4trunks 70 Posted December 11, 2017 Posted December 11, 2017 A tester has helped narrow it down to some startup code that uses the Mono.Posix library to make syscalls to query the OS information. This allows us to differentiate between freebsd and linux. The problem is I have no explanation for the sudden failure because the code hasn't changed, nor have the included libraries. So I am just going to remove it and have you guys add a command line param to specify freebsd customizations from the outside in. Might as well do it now because the library will not be usable anyway down the road with .net core. great, once there is a stable version with this update i can build an updated emby plugin for freenas. 1
Luke 42238 Posted December 12, 2017 Author Posted December 12, 2017 great, once there is a stable version with this update i can build an updated emby plugin for freenas. One small adjustment will be needed to the startup command line. Please see my comments here: https://github.com/MediaBrowser/Emby/issues/3062 Thanks.
eraser8 55 Posted December 17, 2017 Posted December 17, 2017 Hi guys, I know you working hard on that to improve this. I hope you will be able to find the way to fix this to be able to upgrade to the last version! Thanks a lot
Luke 42238 Posted December 17, 2017 Author Posted December 17, 2017 Hi guys, I know you working hard on that to improve this. I hope you will be able to find the way to fix this to be able to upgrade to the last version! Thanks a lot We have it figured out, thanks
eraser8 55 Posted December 17, 2017 Posted December 17, 2017 We have it figured out, thanks Cool! Thanks! So, can we hope to have plugin updates in the same time than others? THanks
josh4trunks 70 Posted December 23, 2017 Posted December 23, 2017 Emby version 3.2.60.0 update is in my local repo, and should be available from the public FreeNAS repo tomorrow. Thanks for everyone's patience on this one. 2
dolphin 17 Posted December 23, 2017 Posted December 23, 2017 Emby version 3.2.60.0 update is in my local repo, and should be available from the public FreeNAS repo tomorrow. Thanks for everyone's patience on this one. Thanks Josh, that is a Christmas gift we all appreciate! Inviato dal mio ONEPLUS A3003 utilizzando Tapatalk
