Luke 42239 Posted November 16, 2016 Author Posted November 16, 2016 Hi everyone. Some troubles with the plugin version 3.0.8300.0. Both my TV's can't see the Emby server. But all devices can see PowerDVD DLNA. I am update the plugin to version 3.0.8500.0. And that not solve the problem. I tried to remove and re-mark the checkbox DLNA but it did not help. Please help me to solve the problem :о) Hi, we're sorry to hear about this. What checkbox exactly do you mean? Thanks !
Luke 42239 Posted November 16, 2016 Author Posted November 16, 2016 @@spencerisadog Found it thanks! i noticed "place favorite channel at the beginning" was checked... i unchecked it and it resolved my issue.... i don't remember clicking favorite to any of the channels though... maybe that's a bug? It was currently on sort by channel number not most recently watched channel at the top... maybe its confusing most recently watched channel with favorites? This is for Version 3.0.8300.0 In 3.0.8300 that is the default setting. In 3.0.8500 the default was changed back to the more traditional sort by channel number.
Validar 1 Posted November 18, 2016 Posted November 18, 2016 Hi, we're sorry to hear about this. What checkbox exactly do you mean? Thanks ! Hi, I meant the checkbox that enables or disables DLNA server. I can provide log files if needed.
Luke 42239 Posted November 18, 2016 Author Posted November 18, 2016 You're saying you can't uncheck it? What browser are you using?
Validar 1 Posted November 18, 2016 Posted November 18, 2016 (edited) You're saying you can't uncheck it? What browser are you using? No, I uncheck the checkbox DLNA and restart Freenas. Then I marked the checkbox and restart Freenas again. Browser - last firefox. In my case all work fine but only DLNA Server don't work.. Edited November 20, 2016 by Validar
Validar 1 Posted November 22, 2016 Posted November 22, 2016 I solved my problem. Installed plug-in version 3.0.8500. I turn off the plugin with Emby, and then shutdown Freenas server. After that I start Freenas server and when it's start, I enable the plugin with Emby. After few minutes all my devices can see Emby as a dlna server. What was the real problem, I can`t say. But simply turn off and turn on the plugin does not helps.
bluemonkey07 590 Posted December 27, 2016 Posted December 27, 2016 (edited) Log.txt Restarted server and navigated folders on PS3 , as soon as entering "movies" server shutdown This is still happening on 3.1Tested with ps3 and bravia TV (2013 I think) Edited December 27, 2016 by Vidman
Eddie 12 Posted December 27, 2016 Posted December 27, 2016 Just gonna chime in with.... I have fixed many problems in Emby with a nuke and pave approach.... don't know if that is an option for you but worth trying if you haven't....
eraser8 55 Posted January 2, 2017 Posted January 2, 2017 Hi guys, Just a quick question to know how often do you upgrade the FREENAS plugin vs the Windows server. I worked with the Windows server before and it was updating alone but not the FreeNAS plugin. BTW, the FreeNAS plugin works flawlessly just like the Windows server. Just didn't automatic update but it is not a big deal. Thanks all for your work.
josh4trunks 70 Posted January 3, 2017 Posted January 3, 2017 Hi guys, Just a quick question to know how often do you upgrade the FREENAS plugin vs the Windows server. I worked with the Windows server before and it was updating alone but not the FreeNAS plugin. BTW, the FreeNAS plugin works flawlessly just like the Windows server. Just didn't automatic update but it is not a big deal. Thanks all for your work. I update the FreeNAS plugin when I have a chance. if there any major issues/features just tell me and I try to make sure to get an updated build out within a few days. unfortunately we don't have automatic updating on FreeBSD/FreeNAS. 1
Eddie 12 Posted January 3, 2017 Posted January 3, 2017 The FreeNAS plugin will never update automatically... need to access FreeNAS server go to plugins.. turn off the plugin... click the update button and not touch the browser while it updates it can take up to 20 min sometimes for me so be patient... it typically lags behind the windows update around 1 to 2 weeks sometimes
woodsb02 17 Posted January 3, 2017 Posted January 3, 2017 Yes, the auto-update feature is specifically disabled in FreeBSD and FreeNAS, as they use their own package management software. The only reason it lags behind by a week or 2 is because it is a manual process for us to push the updated version to the package repositories (me for FreeBSD and @@josh4trunks for FreeNAS).
eraser8 55 Posted January 3, 2017 Posted January 3, 2017 Hi all's Thank you for all infos. Continue your good work and on my side, I'll be patient Have a nice day and happy new year to everyone!
evox 7 Posted January 17, 2017 Posted January 17, 2017 Yes, the auto-update feature is specifically disabled in FreeBSD and FreeNAS, as they use their own package management software. The only reason it lags behind by a week or 2 is because it is a manual process for us to push the updated version to the package repositories (me for FreeBSD and @@josh4trunks for FreeNAS). this time is emby taking more time to update, i hope is everything good with you guys. i was thinking how we can help to improve the time to update on freenas and don't wait so long as in the others plataforms.
eraser8 55 Posted January 17, 2017 Posted January 17, 2017 Hi evox. Things are going relatively well on my side. I like to be up to date with the latest improvement but I understand the culprit of always compile this manually. So, no rush, do what you have to do!!
evox 7 Posted January 18, 2017 Posted January 18, 2017 good to know you are going well, if more people can help or if you need help doing something, let me know. I can help where i can.
Eddie 12 Posted January 18, 2017 Posted January 18, 2017 In the future this should not be a big deal... freenas is going to use docker so Emby should be directly updating it for you
josh4trunks 70 Posted January 18, 2017 Posted January 18, 2017 I built the update for version 3.1.2 and it should be in the FreeNAS plugin repo within 24 hours. 2
tgessendorfer 7 Posted January 20, 2017 Posted January 20, 2017 I built the update for version 3.1.2 and it should be in the FreeNAS plugin repo within 24 hours. Is it there? I didn't yet see this update still currently running on 3.1.0!?
