Luke 42239 Posted July 22, 2016 Author Posted July 22, 2016 And yes, just to follow up, I'm pretty sure the Emby for Kodi add-on will display a dynamic path such as you're asking. So it sounds like you're good to go then actually.
bluemonkey07 590 Posted July 22, 2016 Posted July 22, 2016 (edited) FYI you could get away with only the one path sub to freenas media and define your library's to point to the sub folders The path the emby plugin will use depends on how you configure it Edited July 22, 2016 by Vidman
Hisma 15 Posted July 23, 2016 Posted July 23, 2016 I have the latest emby server plugin for freenas. My server now cannot seem to finish a library update. It is continually hanging around 75%. Restarting the plugin and jail leads to the same result. I have attached my log to this message, as it's gigantic, and I am not sure where to start. There are tons of errors, almost all of them seem to mention some variation of mono and ffmpeg. Here is an example - 2016-07-23 16:28:01.7886 Error App: Error in Nfo *** Error Report *** Version: 3.0.5986.0 Command line: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/pbi/emby-amd64/bin/ffmpeg -ffprobe /usr/pbi/emby-amd64/bin/ffprobe -programdata /var/db/mediabrowser Operating system: Unix 10.3.0.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/mediabrowser Mono: 4.2.1 (Stable 4.2.1.124/39edf24 Sun Jan 10 05:27:13 UTC 2016) Application Path: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe Data at the root level is invalid. Line 4, position 40. System.Xml.XmlException at System.Xml.XmlTextReaderImpl.Throw (System.Exception e) <0x818bb14a0 + 0x000b1> in <filename unknown>:0 at System.Xml.XmlTextReaderImpl.Throw (System.String res, System.String arg) <0x818bb0e00 + 0x000bd> in <filename unknown>:0 at System.Xml.XmlTextReaderImpl.Throw (System.String res) <0x818bb0dc0 + 0x0002f> in <filename unknown>:0 at System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace () <0x8040294f0 + 0x002a7> in <filename unknown>:0 at System.Xml.XmlTextReaderImpl.ParseDocumentContent () <0x804028b70 + 0x005b0> in <filename unknown>:0 at System.Xml.XmlTextReaderImpl.Read () <0x8040203f0 + 0x0007c> in <filename unknown>:0 at System.Xml.XmlReader.MoveToContent () <0x804020280 + 0x00084> in <filename unknown>:0 at MediaBrowser.XbmcMetadata.Parsers.BaseNfoParser`1[T].Fetch (MediaBrowser.Controller.Providers.MetadataResult`1 item, System.String metadataFile, System.Xml.XmlReaderSettings settings, CancellationToken cancellationToken) <0x817d82480 + 0x000e1> in <filename unknown>:0 at MediaBrowser.XbmcMetadata.Parsers.BaseNfoParser`1[T].Fetch (MediaBrowser.Controller.Providers.MetadataResult`1 item, System.String metadataFile, CancellationToken cancellationToken) <0x817d82190 + 0x00100> in <filename unknown>:0 at MediaBrowser.XbmcMetadata.Parsers.EpisodeNfoParser.Fetch (MediaBrowser.Controller.Providers.MetadataResult`1 item, System.Collections.Generic.List`1 images, System.String metadataFile, CancellationToken cancellationToken) <0x818bb03c0 + 0x0002b> in <filename unknown>:0 at MediaBrowser.XbmcMetadata.Providers.EpisodeNfoProvider.Fetch (MediaBrowser.Controller.Providers.MetadataResult`1 result, System.String path, CancellationToken cancellationToken) <0x818bb01a0 + 0x000fd> in <filename unknown>:0 at MediaBrowser.XbmcMetadata.Providers.BaseNfoProvider`1+<GetMetadata>c__async0[T].MoveNext () <0x817d81970 + 0x0017e> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x818bb2890 + 0x00038> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x818bb24d0 + 0x00118> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x818bb2400 + 0x000b3> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x80847fb70 + 0x00042> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x808eca900 + 0x0001f> in <filename unknown>:0 at MediaBrowser.Providers.Manager.MetadataService`2+<RefreshWithProviders>c__async5[TItemType,TIdType].MoveNext () <0x8177dc4e0 + 0x0189f> in <filename unknown>:0 If someone can help point me in the right direction as to what may be going on, I'd greatly appreciate it. Thanks!Log.zip
llygoden 6 Posted August 3, 2016 Posted August 3, 2016 @@woodsb02 @@josh4trunks Do you have any of the older versions of Emby available as a PBI? The series issue I'm having with 3.0.5986 is making watching TV shows impossible, I'm thinking if you have an older PBI I could upload it to my jail and perform a downgrade. Is that even possible? Regards, llygoden
rubenverhoef 11 Posted August 3, 2016 Posted August 3, 2016 @@woodsb02 @@josh4trunks Do you have any of the older versions of Emby available as a PBI? The series issue I'm having with 3.0.5986 is making watching TV shows impossible, I'm thinking if you have an older PBI I could upload it to my jail and perform a downgrade. Is that even possible? Regards, llygoden Older versions of the plugins: https://download.freenas.org/plugins/9/x64/ 1
llygoden 6 Posted August 4, 2016 Posted August 4, 2016 Thanks @rubenverhoef I'll give this a go over the weekend.
grizlyadams 19 Posted August 11, 2016 Posted August 11, 2016 Hi, just updated to v 6030 of the pbi and again the updte failed necessitating delete and manual install and full re-scan of library. Is there something I can do to diagnose the pbi upgrade woes I have? clicking "update" next to the plugin just never works for me... cheers Griz
Eddie 12 Posted August 11, 2016 Posted August 11, 2016 You may have already done this but.... I used to have upgrade problems with emby... one day I clicked the delete button for the jail and after manually deleted the entire jail folders .... it took a while and lots of tries but once I did that I restarted freenas installed emby through plug-ins and started from scratch... i haven't had any issues upgrading emby through the plug-ins section... just my 2 cents
PhilWhite 64 Posted August 12, 2016 Posted August 12, 2016 I used to have the same problem before I destroyed my jails and restarted and now all works great. Previous to this I followed this other option: http://emby.media/community/index.php?/topic/13083-freenas-plugin/?p=313539
grizlyadams 19 Posted August 13, 2016 Posted August 13, 2016 thanks Eddie and PhilWhite - the last update I did I ended up destroying the original emby jail, and this first update since that has gone wrong too. I ended up doing it the manual way as per that post you linked to ( keep the jail, delete emby and manually install it) - maybe i'll just go straight to that and skip trying to do the upgrade in future. planning to install a new freenas box in the near future, which I as hoping just to move the old disks in to, guess i'll try building it from scratch.
Eddie 12 Posted August 13, 2016 Posted August 13, 2016 I don't know if it matters but freenas 10 is coming out eventually with a whole new way to virtualize and I don't know how compatible old jails are going to be when upgrading to 10
josh4trunks 70 Posted August 19, 2016 Posted August 19, 2016 Filed as PR 206593. @@razzfazz I updated the version of mono bundled with the FreeNAS plugin to 4.4, but then realized I didn't include the patches for realtime filesystem monitoring. Should I still use the patches you provided or should I use these instead? https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=198727 Thanks
razzfazz 11 Posted August 19, 2016 Posted August 19, 2016 @@razzfazz I updated the version of mono bundled with the FreeNAS plugin to 4.4, but then realized I didn't include the patches for realtime filesystem monitoring. Should I still use the patches you provided or should I use these instead? https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=198727 I just uploaded an updated patch version for 4.4.2.11 to PR 206593. Working fine for me on my FreeBSD box. I haven't tried the patch in 198727 myself.
llygoden 6 Posted August 29, 2016 Posted August 29, 2016 Hi @@josh4trunks, do you know when the next release of the plugin will be? @@Luke has made changes that fixes issues some users where having with TV Series which I'm keen to have on my freeNAS server. Regards, Llygoden
josh4trunks 70 Posted August 29, 2016 Posted August 29, 2016 Hi @@josh4trunks, do you know when the next release of the plugin will be? @@Luke has made changes that fixes issues some users where having with TV Series which I'm keen to have on my freeNAS server. Regards, Llygoden I can get something out in the next few days. I didn't even hear of this release in the release announcement thread we have for package maintainers.
Eddie 12 Posted August 29, 2016 Posted August 29, 2016 I noticed on my emby dashboard a few updates had come out but I never see anything about them in the announcement page in the emby forum http://emby.media/community/index.php?/forum/17-announcements/ so i dont even know if it's worth the upgrade... is there somewhere else I should go to find information about the latest update?
gmacman 3 Posted August 29, 2016 Posted August 29, 2016 I noticed on my emby dashboard a few updates had come out but I never see anything about them in the announcement page in the emby forum http://emby.media/community/index.php?/forum/17-announcements/ so i dont even know if it's worth the upgrade... is there somewhere else I should go to find information about the latest update? Yep, I seem to get some messages that say "A new version of Emby server..." within the dashboard but if you try to click on it, it does not open a page with descriptions. The ones that usually do have details about (I'll call them "true") updates is where I see "Emby Server X.X.XXX released" and then you can click on that and see what changes/updates were done. So those are now the only messages I actually look at. Don't know if it's a bug or whatever that keeps throwing up the other server updates messages. And of course, it should be noted that the plugin is not updated with every single update to the server version (which I kinda like BTW). So I typically only update when I see that the plugin has been updated. I have lots of respect for josh4trunks.
Luke 42239 Posted August 29, 2016 Author Posted August 29, 2016 The release notes are always attached to github releases. https://github.com/MediaBrowser/Emby/releases Sometimes the blog announcement is just a little delayed after that. thanks. 1
Eddie 12 Posted August 29, 2016 Posted August 29, 2016 Thank you Luke.. ill bookmark that website to keep up with the latest and greatest...
gmacman 3 Posted August 29, 2016 Posted August 29, 2016 The release notes are always attached to github releases. https://github.com/MediaBrowser/Emby/releases Sometimes the blog announcement is just a little delayed after that. thanks. Interesting, thanks. And how does that tie into what is seen in the server's dashboard messages?
Luke 42239 Posted August 29, 2016 Author Posted August 29, 2016 The server queries github to find the releases so that's where the dashboard message is coming from.
llygoden 6 Posted August 29, 2016 Posted August 29, 2016 No worries, I only noticed as I have been tracking the TV series issue.
gmacman 3 Posted August 30, 2016 Posted August 30, 2016 (edited) The server queries github to find the releases so that's where the dashboard message is coming from. Got it, and that makes sense as to why I see those (vs what I then see here as to what plugin version is avail), thanks again. Edited August 30, 2016 by gmacman
llygoden 6 Posted August 31, 2016 Posted August 31, 2016 The plugin has been updated to 3.0.6400 thanks @@josh4trunks and @@Luke
