Barlog9511 17 Posted January 13, 2016 Posted January 13, 2016 where are those errors showing? did you stop emby before applying the update? what happens when you try 'service emby-server start' in the jail? 1. this error show me on dmesg 2. yes 3. services not found I just install fresh new install of emby and link all of folders etc. to new jail and everything work fine ... but it will be fine just update plugin from WebUI 1
josh4trunks 70 Posted January 13, 2016 Posted January 13, 2016 1. this error show me on dmesg 2. yes 3. services not found I just install fresh new install of emby and link all of folders etc. to new jail and everything work fine ... but it will be fine just update plugin from WebUI so the update still doesn't work for you? please test the command from the jail not the host
rubenverhoef 11 Posted January 14, 2016 Posted January 14, 2016 maybe a stupid question but i cannot find the library monitoring option. It is not at the Library/advanced tab... any idea?
josh4trunks 70 Posted January 14, 2016 Posted January 14, 2016 maybe a stupid question but i cannot find the library monitoring option. It is not at the Library/advanced tab... any idea? the option was hidden from most OS's since it wasn't working/causing crashes. it's not available in the settings file only, but if this works @@Luke we may wasn't to add the option back
Luke 42238 Posted January 14, 2016 Author Posted January 14, 2016 it's being added back for linux but not yet for bsd until we confirm this works
razzfazz 11 Posted January 14, 2016 Posted January 14, 2016 It's been working fine for me for almost a week now on FreeBSD. 1
razzfazz 11 Posted January 14, 2016 Posted January 14, 2016 maybe a stupid question but i cannot find the library monitoring option. It is not at the Library/advanced tab... any idea? You have to edit config/system.xml and set EnableLibraryMonitor to "Enabled": <EnableLibraryMonitor>Enabled</EnableLibraryMonitor>
rubenverhoef 11 Posted January 14, 2016 Posted January 14, 2016 You have to edit config/system.xml and set EnableLibraryMonitor to "Enabled": <EnableLibraryMonitor>Enabled</EnableLibraryMonitor> Yeah i found it, changed it (and disabled every one hour library scan) and it works, my new movie is showing ! Thanks! 1
Kakistocrtor 0 Posted January 15, 2016 Posted January 15, 2016 I recently installed the 3.0.5785.0 PBI from the FreeNAS repository. ffmpeg is included in the PBIs, isn't it? The ffmpeg version shipped with the PBI seems to have been compiled without opus encoder support, preventing music streaming via the web client. (In my case at least) The transcode log looks like this http://hastebin.com/qigigibeza.mel Note "Encoder (codec opus) not found for output stream #0:0" and "--disable-libopus". Opus decoding works without libopus, but not the encoding. I compiled ffmpeg myself with opus support and it fixed the problem, but I think I messed up aac instead... I didn't notice anyone else having the problem, is it just me? And by the way, since it's my first post, thank you all very much for the great work! I love the new opus support, as soon as we can set encoding parameters manually its perfect
josh4trunks 70 Posted January 15, 2016 Posted January 15, 2016 I recently installed the 3.0.5785.0 PBI from the FreeNAS repository. ffmpeg is included in the PBIs, isn't it? The ffmpeg version shipped with the PBI seems to have been compiled without opus encoder support, preventing music streaming via the web client. (In my case at least) The transcode log looks like this http://hastebin.com/qigigibeza.mel Note "Encoder (codec opus) not found for output stream #0:0" and "--disable-libopus". Opus decoding works without libopus, but not the encoding. I compiled ffmpeg myself with opus support and it fixed the problem, but I think I messed up aac instead... I didn't notice anyone else having the problem, is it just me? And by the way, since it's my first post, thank you all very much for the great work! I love the new opus support, as soon as we can set encoding parameters manually its perfect I'll add opus in next release I build.
keyboard99 0 Posted January 15, 2016 Posted January 15, 2016 Yeah i found it, changed it (and disabled every one hour library scan) and it works, my new movie is showing ! Thanks! How do you find it? My library isn't updating so think I need to enable it Also tried the update from the GUI, got stuck at 50%
pprezzla 2 Posted January 15, 2016 Posted January 15, 2016 On my install, system.xml is in /var/db/emby-server/config Sent from my iPhone using Tapatalk
keyboard99 0 Posted January 16, 2016 Posted January 16, 2016 On my install, system.xml is in /var/db/emby-server/config Sent from my iPhone using Tapatalk newbie here, how do you find that path, is in via the shell?
spencerisadog 4 Posted January 16, 2016 Posted January 16, 2016 On my install, system.xml is in /var/db/emby-server/config Sent from my iPhone using Tapatalk newbie here, how do you find that path, is in via the shell? Yes, go to your FreeNAS gui, go to jails, highlight Emby, then click on the shell button on the bottom taskbar. Then use the "cd" commands to get you there. "ls -l" will show you what "folders" you have in that directory you're currently in.
pprezzla 2 Posted January 16, 2016 Posted January 16, 2016 On my install, system.xml is in /var/db/emby-server/config Sent from my iPhone using Tapatalk newbie here, how do you find that path, is in via the shell? As above, you got to jails in freenas then click on your emby jail and open the shell. To edit the xml file you will need an editor so type: pkg update pkg install nano cd /var/db/emby-server/config/ nano system.xml It will open the file and you can either scroll down to find it or i use ctrl+w and search for it. Ctrl+o to save and ctrl+x to exit. Sent from my iPhone using Tapatalk
keyboard99 0 Posted January 16, 2016 Posted January 16, 2016 (edited) As above, you got to jails in freenas then click on your emby jail and open the shell. To edit the xml file you will need an editor so type: pkg update pkg install nano cd /var/db/emby-server/config/ nano system.xml It will open the file and you can either scroll down to find it or i use ctrl+w and search for it. Ctrl+o to save and ctrl+x to exit. Sent from my iPhone using Tapatalk Thanks getting this on the install Updating local repository catalogue... pkg: file:///usr/ports/packages/meta.txz: No such file or directory pkg: repository local has no meta file, using default settings pkg: file:///usr/ports/packages/digests.txz: No such file or directory pkg: Unable to update repository local [root@@freenas ~]# pkg install nano Updating local repository catalogue... pkg: file:///usr/ports/packages/meta.txz: No such file or directory pkg: repository local has no meta file, using default settings pkg: file:///usr/ports/packages/digests.txz: No such file or directory pkg: Unable to update repository local All repositories are up-to-date. The following 2 packages will be affected (of 0 checked): New packages to be INSTALLED: gcc: 4.8.3_1 gcc-ecj: 4.5 The process will require 350 MB more space. 69 MB to be downloaded. Proceed with this action? [y/N]: y Checking integrity... done (0 conflicting) pkg: archive_read_open_filename(/usr/ports/packages/All/gcc-ecj-4.5.txz): Failed to open '/usr/ports/packages/All/gcc-ecj-4.5.txz' Edited January 16, 2016 by keyboard99
pprezzla 2 Posted January 17, 2016 Posted January 17, 2016 You have to either jexec into emby jail or go to jails the launch shell from there. From the main freenas shell type, jexec emby_1 csh Sent from my iPhone using Tapatalk
keyboard99 0 Posted January 17, 2016 Posted January 17, 2016 Thanks all, got in there installed and updated the Xml. I have a feeling it's something up with him my emby via kodi. As I cannot see the actual files but I see the folders when inside of kodi. If I play via the emby app then the files are there. Fun all this, learning a lot. Sent from my SM-G900F using Tapatalk
pprezzla 2 Posted January 17, 2016 Posted January 17, 2016 Thanks all, got in there installed and updated the Xml. I have a feeling it's something up with him my emby via kodi. As I cannot see the actual files but I see the folders when inside of kodi. If I play via the emby app then the files are there. Fun all this, learning a lot. Sent from my SM-G900F using Tapatalk I'm afraid i can't help you there, i've not looked at linking kodi yet. I've only just came to emby from plex and still learning myself Sent from my iPhone using Tapatalk
spencerisadog 4 Posted January 19, 2016 Posted January 19, 2016 Since the new version (3.0.5785.0) I've had to restart the service every couple days. Any one else? Link for most recent log (just after restart)
cormad 0 Posted January 19, 2016 Posted January 19, 2016 Newbie Here, I was in a bit of a panic this morning when I ftp'd into my server to copy some files. I thought I had been hacked! Now that I searched a bit I think it was an emby update. All my files under "media" show as USER:989. This appears to of happened Jan11th and 3:00am. Now I can't see some of my folders and ALL of my movie files. All I can see is the movie folders itself and .nfo. How do I fix this?? Jeff
josh4trunks 70 Posted January 19, 2016 Posted January 19, 2016 Newbie Here, I was in a bit of a panic this morning when I ftp'd into my server to copy some files. I thought I had been hacked! Now that I searched a bit I think it was an emby update. All my files under "media" show as USER:989. This appears to of happened Jan11th and 3:00am. Now I can't see some of my folders and ALL of my movie files. All I can see is the movie folders itself and .nfo. How do I fix this?? Jeff can you show the permissions of the files'ls -l /path/to/media'
sluggo45 47 Posted January 19, 2016 Posted January 19, 2016 Newbie Here, I was in a bit of a panic this morning when I ftp'd into my server to copy some files. I thought I had been hacked! Now that I searched a bit I think it was an emby update. All my files under "media" show as USER:989. This appears to of happened Jan11th and 3:00am. Now I can't see some of my folders and ALL of my movie files. All I can see is the movie folders itself and .nfo. How do I fix this?? Jeff You sure you have/still have a user in *the jail* that has the same UID/GUID as the user in FreeNas (for the volume)? I.e. if your "master" permissions in FreeNas are assigned to user/group media:media with a UID/GUID of 1001:1001 you should have the same user/group and UID/GUID configured in the jail. This is the part that normally throws everybody off but it seems like you had it working at one point so not sure what happened there, unless the jail user got deleted?
cormad 0 Posted January 19, 2016 Posted January 19, 2016 can you show the permissions of the files 'ls -l /path/to/media' I ran that both in root of Freenas and emby jail and it said file or path does not exist...BUT I found my files. I assume Emby created folders and .nfo files in the root of my media share. i.e. media /"all my movie folders"/ "*.nfo in each folder" What I didn't notice was media/movies/ and media/tvshows still existed. Jeff
josh4trunks 70 Posted January 19, 2016 Posted January 19, 2016 I ran that both in root of Freenas and emby jail and it said file or path does not exist...BUT I found my files. I assume Emby created folders and .nfo files in the root of my media share. i.e. media /"all my movie folders"/ "*.nfo in each folder" What I didn't notice was media/movies/ and media/tvshows still existed. Jeff your supposed to replace "/path/to/media" with your actual path =P
