DemonI 5 Posted July 25, 2024 Posted July 25, 2024 I'm seeing this with many 4K movies, with basically every audio format, Dolby 5.1 to Atmos, TrueHD, DTS, DTS-HD, in both MP4 and MKV containers, HDR and Dolby Vision, H.265 and H.264. I've yet to find a common denominator other than 4K media. This is also device independent. If it does it on my Fire Cube, it does it on my 4K Max sticks and even on my laptop that has Ryzen 9 5900 HX and RTX 3808. Thoughts? Latest movie to do this, using both the DTS-HD track and the first AC3 track: Spoiler General Unique ID : 336449597734469048575928289091075144803 (0xFD1DD5E3AE51DC1EA52A476BAF037C63) Complete name : Movies\4k\Sherlock\Sherlock.Holmes.2009.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT.mkv Format : Matroska Format version : Version 4 File size : 55.6 GiB Duration : 2 h 8 min Overall bit rate mode : Variable Overall bit rate : 61.9 Mb/s Movie name : Sherlock.Holmes.2009.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT Encoded date : UTC 2020-08-31 23:26:48 Writing application : mkvmerge v49.0.0 ('Sick Of Losing Soulmates') 64-bit Writing library : libebml v1.4.0 + libmatroska v1.6.1 Cover : Yes Attachments : small_cover.jpg / small_cover_land.jpg / cover.jpg / cover_land.jpg Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 8 min Bit rate : 54.9 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.276 Stream size : 49.3 GiB (89%) Title : Sherlock.Holmes.2009.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT Writing library : ATEME Titan File 3.9.0 (4.9.0.0) Language : English Default : No Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Maximum Content Light Level : 343 cd/m2 Maximum Frame-Average Light Level : 106 cd/m2 Original source medium : Blu-ray Audio #1 ID : 2 ID in the original source medium : 4352 (0x1100) Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec ID : A_DTS Duration : 2 h 8 min Bit rate mode : Variable Bit rate : 2 272 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless Stream size : 2.04 GiB (4%) Title : Sherlock.Holmes.2009.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT Language : English Default : Yes Forced : No Original source medium : Blu-ray Audio #2 ID : 3 ID in the original source medium : 4353 (0x1101) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 8 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 4 s 671 ms Stream size : 411 MiB (1%) Title : Sherlock.Holmes.2009.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT Language : English Service kind : Complete Main Default : No Forced : No Original source medium : Blu-ray Audio #3 ID : 4 ID in the original source medium : 4354 (0x1102) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 8 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 4 s 671 ms Stream size : 411 MiB (1%) Title : Sherlock.Holmes.2009.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT Language : French Service kind : Complete Main Default : No Forced : No Original source medium : Blu-ray Audio #4 ID : 5 ID in the original source medium : 4355 (0x1103) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 8 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 4 s 671 ms Stream size : 411 MiB (1%) Title : Sherlock.Holmes.2009.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT Language : French Service kind : Complete Main Default : No Forced : No Original source medium : Blu-ray Audio #5 ID : 6 ID in the original source medium : 4356 (0x1104) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 8 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 4 s 671 ms Stream size : 411 MiB (1%) Title : Sherlock.Holmes.2009.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT Language : German Service kind : Complete Main Default : No Forced : No Original source medium : Blu-ray Audio #6 ID : 7 ID in the original source medium : 4357 (0x1105) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 8 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 4 s 671 ms Stream size : 411 MiB (1%) Title : Sherlock.Holmes.2009.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT Language : Spanish Service kind : Complete Main Default : No Forced : No Original source medium : Blu-ray Audio #7 ID : 8 ID in the original source medium : 4358 (0x1106) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 8 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 4 s 671 ms Stream size : 411 MiB (1%) Title : Sherlock.Holmes.2009.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT Language : Spanish Service kind : Complete Main Default : No Forced : No Original source medium : Blu-ray Audio #8 ID : 9 ID in the original source medium : 4359 (0x1107) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 8 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 4 s 671 ms Stream size : 411 MiB (1%) Title : Sherlock.Holmes.2009.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT Language : Czech Service kind : Complete Main Default : No Forced : No Original source medium : Blu-ray Audio #9 ID : 10 ID in the original source medium : 4360 (0x1108) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 8 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 4 s 671 ms Stream size : 411 MiB (1%) Title : Sherlock.Holmes.2009.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT Language : Hungarian Service kind : Complete Main Default : No Forced : No Original source medium : Blu-ray Audio #10 ID : 11 ID in the original source medium : 4361 (0x1109) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 8 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 4 s 671 ms Stream size : 411 MiB (1%) Title : Sherlock.Holmes.2009.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT Language : Polish Service kind : Complete Main Default : No Forced : No Original source medium : Blu-ray Audio #11 ID : 12 ID in the original source medium : 4362 (0x110A) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 8 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 4 s 671 ms Stream size : 411 MiB (1%) Title : Sherlock.Holmes.2009.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT Language : Thai Service kind : Complete Main Default : No Forced : No Original source medium : Blu-ray Text #1 ID : 13 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 58 min Bit rate : 57 b/s Frame rate : 0.210 FPS Count of elements : 1499 Stream size : 50.1 KiB (0%) Title : English-SRT Language : English Default : Yes Forced : No Text #2 ID : 14 ID in the original source medium : 4769 (0x12A1) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 0 min Bit rate : 32.8 kb/s Frame rate : 0.418 FPS Count of elements : 3016 Stream size : 28.2 MiB (0%) Title : English-PGS Language : English Default : No Forced : No Original source medium : Blu-ray Text #3 ID : 15 ID in the original source medium : 4771 (0x12A3) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 23.5 kb/s Frame rate : 0.392 FPS Count of elements : 2980 Stream size : 21.3 MiB (0%) Title : French-PGS Language : French Default : No Forced : No Original source medium : Blu-ray Text #4 ID : 16 ID in the original source medium : 4772 (0x12A4) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 0 min Bit rate : 39.1 kb/s Frame rate : 0.433 FPS Count of elements : 3124 Stream size : 33.6 MiB (0%) Title : German-PGS Language : German Default : No Forced : No Original source medium : Blu-ray Text #5 ID : 17 ID in the original source medium : 4773 (0x12A5) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 59 min Bit rate : 30.1 kb/s Frame rate : 0.397 FPS Count of elements : 2844 Stream size : 25.7 MiB (0%) Title : Spanish-PGS Language : Spanish Default : No Forced : No Original source medium : Blu-ray Text #6 ID : 18 ID in the original source medium : 4774 (0x12A6) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 59 min Bit rate : 25.5 kb/s Frame rate : 0.312 FPS Count of elements : 2232 Stream size : 21.8 MiB (0%) Title : Dutch-PGS Language : Dutch Default : No Forced : No Original source medium : Blu-ray Text #7 ID : 19 ID in the original source medium : 4775 (0x12A7) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 25.0 kb/s Frame rate : 0.381 FPS Count of elements : 2892 Stream size : 22.6 MiB (0%) Title : Chinese-PGS Language : Chinese Default : No Forced : No Original source medium : Blu-ray Text #8 ID : 20 ID in the original source medium : 4776 (0x12A8) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 58 min Bit rate : 25.1 kb/s Frame rate : 0.408 FPS Count of elements : 2912 Stream size : 21.3 MiB (0%) Title : Chinese-PGS Language : Chinese Default : No Forced : No Original source medium : Blu-ray Text #9 ID : 21 ID in the original source medium : 4777 (0x12A9) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 21.5 kb/s Frame rate : 0.376 FPS Count of elements : 2860 Stream size : 19.5 MiB (0%) Title : Chinese-PGS Language : Chinese Default : No Forced : No Original source medium : Blu-ray Text #10 ID : 22 ID in the original source medium : 4778 (0x12AA) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 17.4 kb/s Frame rate : 0.370 FPS Count of elements : 2810 Stream size : 15.7 MiB (0%) Title : Korean-PGS Language : Korean Default : No Forced : No Original source medium : Blu-ray Text #11 ID : 23 ID in the original source medium : 4779 (0x12AB) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 28.4 kb/s Frame rate : 0.387 FPS Count of elements : 2946 Stream size : 25.7 MiB (0%) Title : Spanish-PGS Language : Spanish Default : No Forced : No Original source medium : Blu-ray Text #12 ID : 24 ID in the original source medium : 4780 (0x12AC) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 16.0 kb/s Frame rate : 0.379 FPS Count of elements : 2884 Stream size : 14.5 MiB (0%) Title : Arabic-PGS Language : Arabic Default : No Forced : No Original source medium : Blu-ray Text #13 ID : 25 ID in the original source medium : 4781 (0x12AD) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 25.1 kb/s Frame rate : 0.373 FPS Count of elements : 2834 Stream size : 22.8 MiB (0%) Title : Czech-PGS Language : Czech Default : No Forced : No Original source medium : Blu-ray Text #14 ID : 26 ID in the original source medium : 4782 (0x12AE) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 26.6 kb/s Frame rate : 0.341 FPS Count of elements : 2592 Stream size : 24.1 MiB (0%) Title : Danish-PGS Language : Danish Default : No Forced : No Original source medium : Blu-ray Text #15 ID : 27 ID in the original source medium : 4783 (0x12AF) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 28.5 kb/s Frame rate : 0.350 FPS Count of elements : 2664 Stream size : 25.8 MiB (0%) Title : Finnish-PGS Language : Finnish Default : No Forced : No Original source medium : Blu-ray Text #16 ID : 28 ID in the original source medium : 4784 (0x12B0) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 24.2 kb/s Frame rate : 0.353 FPS Count of elements : 2688 Stream size : 22.0 MiB (0%) Title : Hungarian-PGS Language : Hungarian Default : No Forced : No Original source medium : Blu-ray Text #17 ID : 29 ID in the original source medium : 4785 (0x12B1) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 59 min Bit rate : 28.3 kb/s Frame rate : 0.399 FPS Count of elements : 2854 Stream size : 24.1 MiB (0%) Title : Norwegian-PGS Language : Norwegian Default : No Forced : No Original source medium : Blu-ray Text #18 ID : 30 ID in the original source medium : 4786 (0x12B2) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 58 min Bit rate : 25.8 kb/s Frame rate : 0.304 FPS Count of elements : 2166 Stream size : 21.9 MiB (0%) Title : Polish-PGS Language : Polish Default : No Forced : No Original source medium : Blu-ray Text #19 ID : 31 ID in the original source medium : 4787 (0x12B3) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 29.7 kb/s Frame rate : 0.381 FPS Count of elements : 2900 Stream size : 26.9 MiB (0%) Title : Romanian-PGS Language : Romanian Default : No Forced : No Original source medium : Blu-ray Text #20 ID : 32 ID in the original source medium : 4788 (0x12B4) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 59 min Bit rate : 30.6 kb/s Frame rate : 0.386 FPS Count of elements : 2762 Stream size : 26.1 MiB (0%) Title : Swedish-PGS Language : Swedish Default : No Forced : No Original source medium : Blu-ray Text #21 ID : 33 ID in the original source medium : 4789 (0x12B5) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 26.5 kb/s Frame rate : 0.378 FPS Count of elements : 2874 Stream size : 24.0 MiB (0%) Title : Thai-PGS Language : Thai Default : No Forced : No Original source medium : Blu-ray Text #22 ID : 34 ID in the original source medium : 4790 (0x12B6) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 3 s 441 ms Bit rate : 95.9 kb/s Frame rate : 0.581 FPS Count of elements : 2 Stream size : 40.3 KiB (0%) Title : French-FORCED-PGS Language : French Default : No Forced : No Original source medium : Blu-ray Text #23 ID : 35 ID in the original source medium : 4791 (0x12B7) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 11 min Bit rate : 468 b/s Frame rate : 0.009 FPS Count of elements : 38 Stream size : 247 KiB (0%) Title : French-FORCED-PGS Language : French Default : No Forced : No Original source medium : Blu-ray Text #24 ID : 36 ID in the original source medium : 4792 (0x12B8) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 56 min 13 s Bit rate : 583 b/s Frame rate : 0.011 FPS Count of elements : 38 Stream size : 240 KiB (0%) Title : German-FORCED-PGS Language : German Default : No Forced : No Original source medium : Blu-ray Text #25 ID : 37 ID in the original source medium : 4793 (0x12B9) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 54 min Bit rate : 386 b/s Frame rate : 0.007 FPS Count of elements : 46 Stream size : 323 KiB (0%) Title : Spanish-FORCED-PGS Language : Spanish Default : No Forced : No Original source medium : Blu-ray Text #26 ID : 38 ID in the original source medium : 4794 (0x12BA) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 41 min Bit rate : 482 b/s Frame rate : 0.008 FPS Count of elements : 50 Stream size : 360 KiB (0%) Title : Spanish-FORCED-PGS Language : Spanish Default : No Forced : No Original source medium : Blu-ray Text #27 ID : 39 ID in the original source medium : 4795 (0x12BB) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 54 min Bit rate : 514 b/s Frame rate : 0.009 FPS Count of elements : 60 Stream size : 431 KiB (0%) Title : Czech-PGS Language : Czech Default : No Forced : No Original source medium : Blu-ray Text #28 ID : 40 ID in the original source medium : 4796 (0x12BC) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 0 min Bit rate : 501 b/s Frame rate : 0.011 FPS Count of elements : 42 Stream size : 224 KiB (0%) Title : Hungarian-PGS Language : Hungarian Default : No Forced : No Original source medium : Blu-ray Menu 00:00:00.000 : en:Chapter 01 00:06:51.160 : en:Chapter 02 00:11:34.819 : en:Chapter 03 00:15:46.278 : en:Chapter 04 00:19:13.485 : en:Chapter 05 00:23:33.453 : en:Chapter 06 00:27:54.464 : en:Chapter 07 00:32:05.840 : en:Chapter 08 00:37:12.939 : en:Chapter 09 00:40:54.910 : en:Chapter 10 00:44:41.804 : en:Chapter 11 00:47:44.278 : en:Chapter 12 00:50:56.553 : en:Chapter 13 00:55:22.193 : en:Chapter 14 00:59:09.045 : en:Chapter 15 01:03:09.160 : en:Chapter 16 01:06:12.635 : en:Chapter 17 01:11:18.565 : en:Chapter 18 01:14:43.896 : en:Chapter 19 01:17:40.906 : en:Chapter 20 01:23:39.681 : en:Chapter 21 01:26:11.541 : en:Chapter 22 01:31:01.414 : en:Chapter 23 01:35:19.964 : en:Chapter 24 01:39:50.567 : en:Chapter 25 01:44:25.259 : en:Chapter 26 01:48:26.541 : en:Chapter 27 01:54:07.298 : en:Chapter 28 01:56:12.090 : en:Chapter 29 02:00:30.765 : en:Chapter 30
ebr 16337 Posted July 26, 2024 Posted July 26, 2024 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Also, one thing to try is remuxing and stripping out most of those subtitle tracks - just as a test. Thanks!
DemonI 5 Posted August 5, 2024 Author Posted August 5, 2024 On 7/26/2024 at 12:01 PM, ebr said: Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Also, one thing to try is remuxing and stripping out most of those subtitle tracks - just as a test. Thanks! Hey, sorry for the delay in replying. I finally got around to stripping out all but one subtitle track and now I can resume it without issue. It still gets stuttery if I skip forward and/or back, which I'm beginning to think is due to my ageing hard drive. Replacements are on the list, but replacing ~60TB of drives is not cheap so I've been putting it off. 2
