mallison01 25 Posted July 24, 2024 Posted July 24, 2024 I have an issue with emby on Unraid 6.12.11 running the official Emby template and container on Intel 4th gen cpu with Nvidia 1660 where emby will randomly stop being able to identify items and load metadata. It will also not be able to load a person when i click on an actor to see more info or other content they may be in. I also notice on the dashboard that emby will stop populating thumbnails for "On Now" content. I can restart the container from Unraid and this will fix it, restarting from emby itself does not seem to work. I did not have this issue when i ran emby on windows and started having it after i moved to unraid. I was using linuxserver's emby container and moved to the emby one and it still does the same thing. I tried deleting the cache folder and metadata folder and made no change. It was happening around 0830 on 7/24/24 before i restarted the container. I noticed the Movie the Mechanic (2016) was not identified and most all of my On Now programs were not loading images. hardware_detection-63857406384.txt embyserver-63857406348.txt
Neminem 1623 Posted July 24, 2024 Posted July 24, 2024 Hmm from you screenshots i don't see GIDLIST Try adding this to you Docker setup
Neminem 1623 Posted July 24, 2024 Posted July 24, 2024 Also you logs are littered with Movie Theme Songs errors. Try disabling that.
Neminem 1623 Posted July 24, 2024 Posted July 24, 2024 22 minutes ago, mallison01 said: I did not have this issue when i ran emby on windows and started having it after i moved to unraid. I was using linuxserver's emby container and moved to the emby one and it still does the same thing. When doing that did you clear Appdata / config storage, to ensure that the old linuxserver's emby was cleared out ?
mallison01 25 Posted July 24, 2024 Author Posted July 24, 2024 I did not use GIDLIST as i didn't need any other groups added to this container and i see no other reason why to use it. Emby works fine for a while until it starts doing the above. Even when it is having the issues listed above. I am still able to play all media and do hardware transcoding just fine. My only issues are with Identifying content and certain thumbnails, after which a reboot will solve the issue. Ive been using the Theme song plugins for a while now, even on windows. I can try disabling that and seeing if it has any effect. And no i did not clear everything in my Appdata / config. I did not want to try multiple things at once. Then you wouldn't know what solved your problem. That was one of my next steps to try, and then restore from a backup in emby.
Happy2Play 9812 Posted July 24, 2024 Posted July 24, 2024 Looks like something is going on with your network as external communications work then stop working. It stopped after 0300ish and external connections start timing out but before that appear to work fine.
mallison01 25 Posted July 24, 2024 Author Posted July 24, 2024 I could understand that if! i was trying to use emby at 0300 and was not able to identify a movie or refresh metadata etc. but we are talking about after emby runs for a certain period of time, it stops working and refuses to work until i restart the container. I don't see any external connections around 0300? I see some errors that it cannot find some cache files but i dont see anything else. Those cache files and all media files are local. I see where one of my users was on their laptop at 0300? I see the Theme song errors, all of that would be local except for when the plugin actually goes to grab that from the internet. I did see where it was downloading some theme songs about 0345. There are no backups or anything scheduled at 0300. Only thing that might be running at that time would be the cache mover, but i have emby setup to run on its own dedicated nvme cache drive and it does not get moved to the array. I am about to disable the theme song plugins and wipe the appdata folder and then i will restore from a backup and see what happens.
Luke 42243 Posted July 24, 2024 Posted July 24, 2024 It is exactly what is happening though. Requests to MovieDb, Omdb and others are timing out and failing. Typical causes of this are firewall, security software or VPN. Can you look into those and let us know what you find?
Happy2Play 9812 Posted July 24, 2024 Posted July 24, 2024 48 minutes ago, mallison01 said: I don't see any external connections around 0300? I see some errors that it cannot find some cache files but i dont see anything else. Those cache files and all media files are local. Okay to be exact first time out was at 0349 but before that it appear connections where fine. So around that time your network stopped communication with external sites. Search "timed" (126 hits in 1 file of 1 searched) C:\Users\Media\Downloads\embyserver-63857406348 (1).txt (126 hits) Line 7751: 2024-07-24 03:49:01.975 Error HttpClient: Connection to https://mb3admin.com/admin/service/registration/validate timed out Line 7763: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://mb3admin.com/admin/service/registration/validate timed out Line 12535: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://connect.emby.media/service/ServerAuthorizations?serverId=08ac1c591f5fec15dde58ca1a651d494 timed out Line 13573: 2024-07-24 06:48:54.796 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 13585: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 13688: 2024-07-24 06:49:01.975 Error HttpClient: Connection to https://mb3admin.com/admin/service/registration/validate timed out Line 13700: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://mb3admin.com/admin/service/registration/validate timed out Line 13957: 2024-07-24 06:49:14.799 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt1515091&plot=short&r=json timed out Line 13969: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt1515091&plot=short&r=json timed out Line 14255: 2024-07-24 06:49:35.764 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0105793&plot=short&r=json timed out Line 14267: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0105793&plot=short&r=json timed out Line 14601: 2024-07-24 06:49:56.038 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/8873?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 14613: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/8873?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 14753: 2024-07-24 06:50:16.041 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0108525&plot=short&r=json timed out Line 14765: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0108525&plot=short&r=json timed out Line 14917: 2024-07-24 06:50:42.119 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt1515091&plot=short&r=json timed out Line 14929: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt1515091&plot=short&r=json timed out Line 15008: 2024-07-24 06:51:03.132 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/8872?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 15020: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/8872?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 15068: 2024-07-24 06:51:23.135 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0105793&plot=short&r=json timed out Line 15080: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0105793&plot=short&r=json timed out Line 15184: 2024-07-24 06:51:43.392 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0108525&plot=short&r=json timed out Line 15196: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0108525&plot=short&r=json timed out Line 15278: 2024-07-24 06:52:09.449 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 15290: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 15340: 2024-07-24 06:52:29.452 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt1515091&plot=short&r=json timed out Line 15352: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt1515091&plot=short&r=json timed out Line 15452: 2024-07-24 06:52:50.563 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0105793&plot=short&r=json timed out Line 15464: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0105793&plot=short&r=json timed out Line 15538: 2024-07-24 06:53:10.818 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/8873?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 15550: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/8873?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 15596: 2024-07-24 06:53:30.820 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0108525&plot=short&r=json timed out Line 15608: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0108525&plot=short&r=json timed out Line 15705: 2024-07-24 06:53:56.938 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt1515091&plot=short&r=json timed out Line 15717: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt1515091&plot=short&r=json timed out Line 15791: 2024-07-24 06:54:17.916 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/8872?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 15803: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/8872?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 15849: 2024-07-24 06:54:37.917 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0105793&plot=short&r=json timed out Line 15861: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0105793&plot=short&r=json timed out Line 15959: 2024-07-24 06:54:58.172 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0108525&plot=short&r=json timed out Line 15971: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0108525&plot=short&r=json timed out Line 16044: 2024-07-24 06:55:24.114 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 16056: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 16212: 2024-07-24 06:56:07.361 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0108525&plot=short&r=json timed out Line 16224: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&i=tt0108525&plot=short&r=json timed out Line 16297: 2024-07-24 06:56:33.324 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 16309: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 17052: 2024-07-24 06:57:23.369 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/8872?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 17064: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/8872?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 17837: 2024-07-24 06:58:18.435 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 17849: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 18676: 2024-07-24 06:59:14.305 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 18688: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 19515: 2024-07-24 07:00:09.888 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 19527: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 20354: 2024-07-24 07:01:05.302 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 20366: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 21193: 2024-07-24 07:02:00.563 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 21205: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 22032: 2024-07-24 07:02:56.256 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 22044: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 22821: 2024-07-24 07:03:46.437 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/8873?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 22833: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/8873?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 23437: 2024-07-24 07:07:39.373 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 23449: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 23630: 2024-07-24 07:08:01.500 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Mechanic-+Resurrection&type=movie timed out Line 23642: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Mechanic-+Resurrection&type=movie timed out Line 23719: 2024-07-24 07:08:40.958 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 23731: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 23916: 2024-07-24 07:09:03.175 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Mechanic-+Resurrection&type=movie timed out Line 23928: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Mechanic-+Resurrection&type=movie timed out Line 23973: 2024-07-24 07:09:04.705 Error HttpClient: Connection to https://mb3admin.com/admin/service/registration/validate timed out Line 23985: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://mb3admin.com/admin/service/registration/validate timed out Line 24162: 2024-07-24 07:09:30.985 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/8873?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 24174: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/8873?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 24459: 2024-07-24 07:09:59.852 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Mechanic-+Resurrection&type=movie timed out Line 24471: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Mechanic-+Resurrection&type=movie timed out Line 24546: 2024-07-24 07:10:26.097 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 24558: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 24951: 2024-07-24 07:10:56.131 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Mechanic-+Resurrection&type=movie timed out Line 24963: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Mechanic-+Resurrection&type=movie timed out Line 25038: 2024-07-24 07:11:22.280 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 25050: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 25443: 2024-07-24 07:11:52.442 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Mechanic-+Resurrection&type=movie timed out Line 25455: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Mechanic-+Resurrection&type=movie timed out Line 25530: 2024-07-24 07:12:18.739 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 25542: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 25935: 2024-07-24 07:12:48.670 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Mechanic-+Resurrection&type=movie timed out Line 25947: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Mechanic-+Resurrection&type=movie timed out Line 26022: 2024-07-24 07:13:14.580 Error HttpClient: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 26034: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/movie/58574?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=en-US&include_image_language=en-US,null timed out Line 26245: 2024-07-24 07:17:21.152 Error HttpClient: Connection to https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Mechanic-+Resurrection&language=en-US&include_adult=true&year=2016 timed out Line 26257: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Mechanic-+Resurrection&language=en-US&include_adult=true&year=2016 timed out Line 26303: 2024-07-24 07:17:41.154 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Mechanic-+Resurrection&type=movie timed out Line 26315: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Mechanic-+Resurrection&type=movie timed out Line 26373: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://fcm.googleapis.com/fcm/send timed out Line 26457: 2024-07-24 08:22:37.095 Error HttpClient: Connection to https://emby.tmsimg.com/assets/p17085245_b_v12_aa.jpg?w=480&h=720 timed out Line 26458: 2024-07-24 08:22:37.096 Error HttpClient: Connection to https://emby.tmsimg.com/assets/p9175160_b_v12_ab.jpg?w=480&h=720 timed out Line 26470: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://emby.tmsimg.com/assets/p9175160_b_v12_ab.jpg?w=480&h=720 timed out Line 26529: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://emby.tmsimg.com/assets/p17085245_b_v12_aa.jpg?w=480&h=720 timed out Line 26579: 2024-07-24 08:22:37.120 Error HttpClient: Connection to https://emby.tmsimg.com/assets/p27463940_b_v8_ab.jpg?w=480&h=720 timed out Line 26580: 2024-07-24 08:22:37.120 Error HttpClient: Connection to https://emby.tmsimg.com/assets/p23615398_b_v12_aa.jpg?w=480&h=720 timed out Line 26592: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://emby.tmsimg.com/assets/p27463940_b_v8_ab.jpg?w=480&h=720 timed out Line 26651: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://emby.tmsimg.com/assets/p23615398_b_v12_aa.jpg?w=480&h=720 timed out Line 27299: 2024-07-24 08:22:54.797 Error HttpClient: Connection to https://emby.tmsimg.com/assets/p184072_b_v12_ai.jpg?w=480&h=720 timed out Line 27311: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://emby.tmsimg.com/assets/p184072_b_v12_ai.jpg?w=480&h=720 timed out Line 27360: 2024-07-24 08:22:54.822 Error HttpClient: Connection to https://emby.tmsimg.com/assets/p459763_b_v12_ba.jpg?w=480&h=720 timed out Line 27361: 2024-07-24 08:22:54.822 Error HttpClient: Connection to https://emby.tmsimg.com/assets/p184321_b_v12_bp.jpg?w=480&h=720 timed out Line 27362: 2024-07-24 08:22:54.822 Error HttpClient: Connection to https://emby.tmsimg.com/assets/p7895418_b_v8_aa.jpg?w=480&h=720 timed out Line 27363: 2024-07-24 08:22:54.823 Error HttpClient: Connection to https://emby.tmsimg.com/assets/p7892049_b_v8_aa.jpg?w=480&h=720 timed out Line 27364: 2024-07-24 08:22:54.823 Error HttpClient: Connection to https://emby.tmsimg.com/assets/p184220_b_v12_aa.jpg?w=480&h=720 timed out Line 27365: 2024-07-24 08:22:54.823 Error HttpClient: Connection to https://emby.tmsimg.com/assets/p7891914_b_v8_aa.jpg?w=480&h=720 timed out Line 27366: 2024-07-24 08:22:54.824 Error HttpClient: Connection to https://emby.tmsimg.com/assets/p2180_v_v8_aa.jpg?w=480&h=720 timed out Line 27378: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://emby.tmsimg.com/assets/p184321_b_v12_bp.jpg?w=480&h=720 timed out Line 27437: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://emby.tmsimg.com/assets/p459763_b_v12_ba.jpg?w=480&h=720 timed out Line 27498: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://emby.tmsimg.com/assets/p7895418_b_v8_aa.jpg?w=480&h=720 timed out Line 27558: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://emby.tmsimg.com/assets/p7892049_b_v8_aa.jpg?w=480&h=720 timed out Line 27618: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://emby.tmsimg.com/assets/p184220_b_v12_aa.jpg?w=480&h=720 timed out Line 27678: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://emby.tmsimg.com/assets/p7891914_b_v8_aa.jpg?w=480&h=720 timed out Line 27738: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://emby.tmsimg.com/assets/p2180_v_v8_aa.jpg?w=480&h=720 timed out Line 27941: 2024-07-24 08:23:50.496 Error HttpClient: Connection to https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Mechanic-+Resurrection&language=en-US&include_adult=true&year=2016 timed out Line 27953: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Mechanic-+Resurrection&language=en-US&include_adult=true&year=2016 timed out Line 28029: 2024-07-24 08:24:10.498 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Mechanic-+Resurrection&type=movie timed out Line 28041: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Mechanic-+Resurrection&type=movie timed out Line 28089: 2024-07-24 08:24:15.916 Error HttpClient: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&s=Mechanic+resurrection+&type=movie timed out Line 28101: MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&s=Mechanic+resurrection+&type=movie timed out
mallison01 25 Posted July 24, 2024 Author Posted July 24, 2024 Ok, i see what you are saying now. Sorry i overlooked that. I have been at work and i use a proxy through my network at home and was on it the entire time, I also use teamviewer and was connected to a pc at my house during all of this, and was also able to use emby this entire time remotely without a tunnel. I use pfsense and nothing was changed when i moved to from Windows server to Unraid, i use the same IP's for the servers etc, must be something with the container or unraid etc. I will double check pfsense to see it it was blocking anything, but i doubt it since a restart of the container will fix the problem instantly.
mallison01 25 Posted July 24, 2024 Author Posted July 24, 2024 I do not see any outages or anything being blocked on the firewall. If it happens again, ill see if i can do some trace routes and see if something is going on with the routing / gateways. 1
Happy2Play 9812 Posted July 24, 2024 Posted July 24, 2024 Might be something as simple as a system restart but since it shows working then not working it would suggest something is interfering with communications.
mallison01 25 Posted July 25, 2024 Author Posted July 25, 2024 So last night i wiped the entire appdata folder and restarted it and restored with a backup, i also removed the theme songs/video plugins for now. This morning it was already doing it again. While it was acting up i logged into unraid, got on the console, did some ping test and dns lookups and some traceroutes. All looked good on the host, then i got a console on the emby container and did that same, again all looked good. I could see in the logs that it was failing to connect to https://emby.tmsimg.com/assets. So in the container i pinged it just fine, went to the host in unraid console and pinged it, and noticed it took a second and starting pinging, but it pinged it using ipv6. In the container i have it setup with a static ipv4 using ipvlan and no ipv6 address, so i added static ipv6 to it to see if this helps. I do have a complex network with multiple VLAN's and a dual stack ipv4/ipv6 network. This would make sense for these items to fail if dns was returning a ipv6 address and the container only had a ipv4 address as most browsers and operating systems no prefer ipv6 over ipv4 if available and on their default settings. It also makes sense since the entire time this was happening i was able to connect to emby and use emby without issue. Just not sure why it would work for several hours after a restart and then stop until another restart.
Luke 42243 Posted July 26, 2024 Posted July 26, 2024 HI, please let us know if you find anything. Thanks.
mallison01 25 Posted July 29, 2024 Author Posted July 29, 2024 So far so good, I have not had to restart it yet. Seems like adding an ipv6 address to the container may have fixed it. I guess with unraid have a dual stack setup it was probably causing some dns issues inside the container. I'll give it some more time and look in the logs and see what I find this week. 1
