EmYaj 25 Posted July 24, 2024 Posted July 24, 2024 I enabled recording and setup a library and path but for some reason having permissions issues. I've attached a log included screenshots. The error from the log is below. Also attached a screenshot from inside the Emby container showing that i have permission to create a file and a directory in this path. I even chmod 777 this directory just for testing with no luck. 2024-07-23 22:36:42.662 Error LiveTV: Error recording to /media/oplink/drive1/EmbyRecordings/Dr. Jeff Rocky Mountain Vet/Dr. Jeff Rocky Mountain Vet 2024_07_23_22_00_00.ts *** Error Report *** Version: 4.8.8.0 Command line: /app/emby/system/EmbyServer.dll -programdata /config -ffdetect /app/emby/bin/ffdetect -ffmpeg /app/emby/bin/ffmpeg -ffprobe /app/emby/bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-113-generic (buildd@lcy02-amd64-072) (gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #123-Ubun Framework: .NET 6.0.25 OS/Process: x64/x64 Runtime: app/emby/system/System.Private.CoreLib.dll Processor count: 4 Data path: /config Application path: /app/emby/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/media/oplink/drive1/EmbyRecordings/Dr. Jeff Rocky Mountain Vet' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.FileSystem.CreateDirectory(String fullPath) at System.IO.Directory.CreateDirectory(String path) at Emby.Server.Implementations.IO.ManagedFileSystem.CreateDirectory(String path) at Emby.LiveTV.DirectRecorder.RecordUsingCopyTo(ILiveStream liveStream, Nullable`1 wallClockStartTime, String targetFile, Action onStarted, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.RecordStream(TimerInfo timer, DateTimeOffset recordingEndDate, InternalActiveRecordingInfo activeRecordingInfo) Source: System.Private.CoreLib TargetSite: Void CreateDirectory(System.String) InnerException: System.IO.IOException: Permission denied Source: TargetSite: embyserver(32).txt
sa2000 697 Posted July 24, 2024 Posted July 24, 2024 I am not a linux expert but is that user write permission not set just for root ? See if this helps https://emby.media/support/articles/Linux-Unix-Permissions.html?q=linux
EmYaj 25 Posted July 24, 2024 Author Posted July 24, 2024 5 hours ago, sa2000 said: I am not a linux expert but is that user write permission not set just for root ? See if this helps https://emby.media/support/articles/Linux-Unix-Permissions.html?q=linux Thanks for your reply. I'm pretty bad with linux stuff and docker throws in extra confusion for me. On the host machine, the directory is not owned by root, it is owned by "media" which is the same user that the docker container uses. The screenshot above is from within the docker container, I assume thats why it shows as root. If I try to chown it, nothing happens. This may be the root of the problem, but I'm not clear on how to fix it if I cant change the permissions or ownership within the container. What user does Emby run as inside of the docker container?
sa2000 697 Posted July 25, 2024 Posted July 25, 2024 18 hours ago, EmYaj said: On the host machine, the directory is not owned by root, it is owned by "media" which is the same user that the docker container uses. See if this support page helps https://emby.media/support/articles/Linux.html I don't know if it is different for docker
Q-Droid 1011 Posted July 25, 2024 Posted July 25, 2024 21 hours ago, EmYaj said: Thanks for your reply. I'm pretty bad with linux stuff and docker throws in extra confusion for me. On the host machine, the directory is not owned by root, it is owned by "media" which is the same user that the docker container uses. The screenshot above is from within the docker container, I assume thats why it shows as root. If I try to chown it, nothing happens. This may be the root of the problem, but I'm not clear on how to fix it if I cant change the permissions or ownership within the container. What user does Emby run as inside of the docker container? It shows as root because it is root. When you exec into a container shell your session will run as root unless you specify a different user:group. The user running the application inside the container is the same as on the host. At least the UID:GID will be the same. It is possible to have the name look different in the container if there are /etc/passwd and /etc/group entries for the user. Either way it's the UID/GID that matter and dictate what ownership and permissions you need on the filesystem. Make sure the user running the container app has access to all of the directories which make up /media/oplink/drive1/EmbyRecordings/ and write permissions on EmbyRecordings. Then make the permissions on any other media paths used by Emby match this one. The path /media/oplink/drive1/EmbyRecordings/ seems pretty long. Is this the internal container side of the bind mapping? 2
EmYaj 25 Posted July 25, 2024 Author Posted July 25, 2024 Thansk for the help all. After trying all of this with no luck I eventually stumbled in to the solution. As always, this was a misunderstanding of Linux stuff on my part. I had thought that authenticating my SMB mount with user "media" that I use for all of my media related apps and containers would mount it as user media but that was not the case, I also needed to specify the UID and GID for that user in fstab. 2
EmYaj 25 Posted July 26, 2024 Author Posted July 26, 2024 For future reference in case anyone finds themselves in this thread looking for the solution, here is what my /etc/fstab entry looks like now that this is fixed: //xx.xx.xx.xx/share /local/mountpoint/ cifs uid=1337,gid=1337,credentials=/root/.smbcredentials-file 2
