pdbear 0 Posted July 21, 2024 Posted July 21, 2024 hi admin, I found emby 4.8.8.0 hardware transcoding failed with this key words: ```bash Could not write header for output file #0 (incorrect codec parameters ?): No such file or directory Error initializing output stream 0:0 -- ``` when i create the dest directory on my hands, the transcoding works fine. pls check the tanscode procedure,ffmpeg need create des path first。 like: ```bash /var/packages/EmbyServer/target/bin/ffmpeg -loglevel +timing -y -print_graphs_file "/var/packages/EmbyServer/var/logs/ffmpeg-transcode-20054eb9-0f59-4360-a8b0-a23543f915df_1graph.txt" -copyts -start_at_zero -init_hw_device "cuda=cuda:0" -f matroska,webm -c:v:0 h264 -threads:v:0 1 -hwaccel:v:0 cuda -hwaccel_output_format:v:0 cuda -noautorotate -c:v:1 mjpeg -i "/volume2/PT/电影/[大话西游之月光宝盒.星光联盟].A.Chinese.Odyssey.Part.One.Pandora's.Box.1995.SUBBED.WEB-DL.4K.H264.50FPS.AAC.Cantonese-OPS.mkv" -filter_complex "[0:0]scale_cuda@f1=w=640:h=360,setsar@f2=sar=sar[f2_out0]" -map [f2_out0] -map 0:1 -sn -c:v:0 h264_nvenc -b:v:0 808001 -g:v:0 150 -maxrate:v:0 808001 -bufsize:v:0 1616002 -keyint_min:v:0 150 -r:v:0 50 -profile:v:0 high -c:a:0 copy -metadata:s:a:0 language=chs -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/volume2/docker/emby_server/transcoding-temp/731266/731266.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/volume2/docker/emby_server/transcoding-temp/731266/731266_%d.ts" ``` the dest dir `/volume2/docker/emby_server/transcoding-temp/731266/` must created by emby but emby not do, especial this 731266 tmp directory.so ffmpeg report error. pls create the dest dir before start ffmpeg.
pdbear 0 Posted July 21, 2024 Author Posted July 21, 2024 sorry,i install a wrong source spk,officail package not have this issue。 @Luke
MarkBear 3 Posted September 9, 2024 Posted September 9, 2024 @LukeI have a suspicion the cause of this (and similar issues i’ve seen on the forums) may be the linuxserver.io docker image. Until moments ago, we were using this image on our linux homelab and were facing this issue. pdbear’s comment (no relation; ha) led me to wonder if it was the image, and swapping to the official image fixed the problem for us - we got 5 episodes of a show to play faultlessly first time. Something perhaps permissions related happening in the linuxserver.io base image perhaps.
Luke 42241 Posted September 9, 2024 Posted September 9, 2024 1 hour ago, MarkBear said: @LukeI have a suspicion the cause of this (and similar issues i’ve seen on the forums) may be the linuxserver.io docker image. Until moments ago, we were using this image on our linux homelab and were facing this issue. pdbear’s comment (no relation; ha) led me to wonder if it was the image, and swapping to the official image fixed the problem for us - we got 5 episodes of a show to play faultlessly first time. Something perhaps permissions related happening in the linuxserver.io base image perhaps. Hi, that's interesting. Thanks for the feedback.
