RClone connection failing
Go to solution Solved by andrewzhang,
andrewzhang
hi, I'm new here and emby is an awsome App, thanks for all you guys.
I got an emby server on my openwrt router through docker, add a local Rclone webdav mount as media library.
it works fine at first few minutes, but it will crush when finish scaning media library and downloading nfo files.
once it crush , I can't even open my file management addons to open the  /mnt directory ,it will warning “readdir failed: lstat /mnt/mmc1-4/rclone: transport endpoint is not connected”.
I think the Rclone is also crush, and I don't know why,
I guess it should be something with write permission, when Emby download and write nfo files to online drives,
I have tried to make Rclone mount --read only, and set Emby not to save nfo files to the media directory, both not worked.
I have no idea what should do to fix this, is there any hint? thanks a lot.
here's some of my recent log:
 2024-07-07 00:59:04.518 Error ProviderManager: StudiosImageProvider failed in GetImageInfos for type Studio
        *** Error Report ***
        Version: 4.8.8.0
        Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3
        Operating system: Linux version 5.10.201 (build@buildserver) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 11.2.0 2023071019) 11.2.0, GNU ld (GNU Binutils) 2.37) #0 SMP
        Framework: .NET 6.0.25
        OS/Process: arm64/arm64
        Runtime: system/System.Private.CoreLib.dll
        Processor count: 4
        Data path: /config
        Application path: /system
        MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Cancelling connection to https://raw.github.com/MediaBrowser/MediaBrowser.Resources/master/images/imagesbyname/studiothumbs.txt due to a previous timeout.
           at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod)
           at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod)
           at StudioImages.StudiosImageProvider.GetImages(BaseItem item, Boolean posters, Boolean thumbs, CancellationToken cancellationToken)
           at Emby.Providers.Manager.ProviderManager.GetImages(RemoteImageFetchOptions options, CancellationToken cancellationToken, IRemoteImageProvider provider, Int32 providerIndex)
        Source: Emby.Server.Implementations
        TargetSite: Void MoveNext()
2024-07-07 00:59:04.586 Info HttpClient: GET https://raw.github.com/MediaBrowser/MediaBrowser.Resources/master/images/imagesbyname/studiothumbs.txt
2024-07-07 00:59:04.594 Error ProviderManager: StudiosImageProvider failed in GetImageInfos for type Studio
        Version: 4.8.8.0
        Processor count: 4
        Data path: /config
2024-07-07 00:59:04.663 Info HttpClient: GET https://raw.github.com/MediaBrowser/MediaBrowser.Resources/master/images/imagesbyname/studiothumbs.txt
2024-07-07 00:59:04.670 Error ProviderManager: StudiosImageProvider failed in GetImageInfos for type Studio
        Version: 4.8.8.0
        Processor count: 4
        Data path: /config
- embyserver.txt 1936/1936 100%
and all my log is attached if needed.
embyserver.txt
Edited by andrewzhang
  • 2 weeks later...
  • Solution
andrewzhang
Thanks for replying!
Yes! I noticed it was the problem of my SD card, my Openwrt was installed on a SD card, and it is broke and can’t be written.
I just buy a new one and it is solved now!
thanks for your guys!
  • Thanks 1
