FrostByte 5453 Posted July 20, 2024 Posted July 20, 2024 57 minutes ago, Happy2Play said: That is the confusing part to me as OP says playback is fine. So the the config just falling back to some system level? If he is using ATV it has an option to direct play media and all it would need is the smb path. Skipping Emby.
bobdobbs 2 Posted July 21, 2024 Author Posted July 21, 2024 19 hours ago, FrostByte said: If he is using ATV it has an option to direct play media and all it would need is the smb path. Skipping Emby. So, the fixes from last night (permission change, and browsing to the folders rather than entering manually) borked it, and the menu then generated thumbnails for thousands of files from the share which emby knew nothing about. I changed it back and still the same, so today I deleted all the libraries and did them again from scratch this time with the permission set from the shared folder as advised and then configured the libraries and rescanned - we are now back to normal ;-). However, I have no idea if it has fixed the erroneous transcoding thumbnails appearing, which was the start of the thread so I will need to see what happens. Thanks for the help everyone. 1
Happy2Play 9811 Posted July 21, 2024 Posted July 21, 2024 2 minutes ago, bobdobbs said: However, I have no idea if it has fixed the erroneous transcoding thumbnails appearing, which was the start of the thread so I will need to see what happens. Easy enough to check but have you looked at new server log to see if it is showing places Emby shouldn't be as previously mentioned?
bobdobbs 2 Posted July 22, 2024 Author Posted July 22, 2024 22 hours ago, Happy2Play said: Easy enough to check but have you looked at new server log to see if it is showing places Emby shouldn't be as previously mentioned? Sorry, I have attached the log - does all look OK? it seems to be working fine, I played the same file as I did the other day which created the thumbnails and is OK this time, I will poast back if it happens again. Thanks embyserver (1).txt 1
