nospotify 186 Posted July 19, 2024 Posted July 19, 2024 Do music albums have to be downloaded individually? I went into music library, sorted by albums, filtered by genre, and then in the screen of results I multi-selected a half-dozen albums and clicked "download" - but only the first album downloaded to my device. Shouldn't download work for multiple selections, or is there a different way to make that work?
Luke 42184 Posted July 20, 2024 Posted July 20, 2024 HI, what Emby app and device were you doing the downloading from?
nospotify 186 Posted July 20, 2024 Author Posted July 20, 2024 Windows server. Android app on a Pixel phone. All Emby software is updated to latest versions.
Luke 42184 Posted July 25, 2024 Posted July 25, 2024 HI, did you check manage downloads to see what was queued up for download?
nospotify 186 Posted July 25, 2024 Author Posted July 25, 2024 They are all still queued there with "0 items" next to them - none were actually downloaded except the first album.
Luke 42184 Posted July 29, 2024 Posted July 29, 2024 On 7/19/2024 at 9:28 PM, wordlover said: Windows server. Android app on a Pixel phone. OK I tested with the same combination and it worked just fine. Both were downloaded. So perhaps something may have been resolved in an update that will be coming your way. 1
